  New Posts New Posts RSS Feed - Plans for 2x18 DR TBW100? Please help
Doctajay313 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doctajay313 Quote  Post ReplyReply Direct Link To This Post Topic: Plans for 2x18 DR TBW100? Please help
    Posted: 26 October 2018 at 8:23am
Does anyone have enclosure plans for a standard vented, direct radiating, 2x18 for B&C TBW100 4ohm speakers. I plan on stacking the enclosures about three high with a couple standard PA tops on top of that. It's going to be for mostly heavy music like EDM Dubstep, Hiphop, Metal, Rock. I dont know much about tuning enclosures but I have tools and money. I plan on pairing the speakers with the Behringer NX6000D power amplifiers and running a sub on each channel. That way I can push the amps at most to halfway at just under 1500watts per channel at 4ohms. I heard that if you tune an enclosure to lower than a speaker is specified it will reduce it's power handling. What frequency is it best to tune a subwoofer to for edm. There is a lot of 40hz-100hz rumble and energy in EDM music and hiphop so I dont know what I should do. Recommendation please?:)
Edited by Doctajay313 - 26 October 2018 at 8:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doctajay313 Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2018 at 8:39am
This is for a pro-audio application in a club for dancing and performance. And I plan on making the enclosures out of void free Baltic birch plywood.
Edited by Doctajay313 - 26 October 2018 at 8:52am
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2018 at 9:11am
I do have a dual 18 plan laying around, more like thw SB1000,bur different port configuration. Tuning around 34 Hz
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doctajay313 Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2018 at 9:18am
The tuning wouldn't be tuned to my speaker though right? I dont know what a SB1000 is?
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2018 at 10:12am
I haven't build one yet, so some port adjustment would be neccesary probably.
PS: EAW Sb1000
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2018 at 11:00am
Box it self is tuned the same regardless of which driver you put in it.
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2018 at 1:08pm
If you want an off the shelf design, the 18 Sound dual 18 vented box should be pretty suitable for those drivers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doctajay313 Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2018 at 9:03pm
I mean I've watched people make enclousre using BassBoxPro and enter in all sorts of parameters that correspond to the speaker. They build the entire enclousre around the speaker and tune the enclousre to what kind of responses they want from it. I do understand that with vented enclousres you are tuning the cabinet to adjust where the peak of the bass spectrum sits. I'm definitely looking for enclousre plans built around the B&C TBW100. The specs says that the optimal configuration for a vented enclousre should have a volume of 2.56 cuft and a F3 of 50Hz. But most enclousres I see tune it down a lot lower than that so I'm confused, we definitely use sub energy down to 40hz. I really apprechiate all your help.
Edited by Doctajay313 - 26 October 2018 at 9:03pm
Jo bg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jo bg Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2018 at 9:15pm
Where did you get the 50 Hz from? Specs suggest 200 liters tuned to 32 Hz, there is even a graph showing -3 at 32.
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2018 at 9:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doctajay313 Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2018 at 7:48am
@ JO Bg
Oh great, you're right!! I should have just looked at the manufacturer's website. You think those specs are for a porterd cabinet? Also, do you have any vented 2x18 enclosure plans for those specifications with good bracing for stacking enclosures?
Edited by Doctajay313 - 27 October 2018 at 7:50am
