Plans for PD 186 Mid bass |
Aya
Topic: Plans for PD 186 Mid bassPosted: 02 July 2012 at 8:35am |
Hello,
I am searching some mid bass plans for Precision Devices 186 driver.
Even for a double bin or a single bin.
Thanks for your replies !
Aya
Posted: 03 July 2012 at 2:55pm |
I have found a 18 single bass cab from B&C speakers...
Is it ok for PD 186 drivers in a mid Bass (90Hz to 240 Hz) configuration ?
Thanks
Aya
Posted: 04 July 2012 at 12:02pm |
No one ?
soundchippy
Joined: 09 September 2011 Location: Tavistock Status: Offline Points: 770 |
Posted: 04 July 2012 at 12:32pm |
that cab makes a good sub. would be a shame to only run it from 90 up.
ceharden
Posted: 04 July 2012 at 12:39pm |
The PD186 is not a mid-bass driver. In fact it would be more commonly used going up to 90Hz rather than starting at that frequency. It will have too heavy a cone and be far to slow to run up to 240Hz.
You need either a very light coned 18" or you'd be better off with a 15". |
Aya
Posted: 04 July 2012 at 2:15pm |
Thanks for your replies, Yes I know that PD 186 is very good for subs but i change my sub drivers from PD 186 to PD 1850..
so i was wondering if PD 186 could be used in mid tops section, if yes with what kind of plan ?
Thanks for your help.
Aya
Posted: 05 July 2012 at 10:22am |
I need your light please !
Jimmer
Joined: 30 April 2010 Location: Stroud / Glos Status: Offline Points: 2604 |
Posted: 06 July 2012 at 12:59pm |
The PD186 is a sub driver. Sell them and get something suited to the job. simples.
*Edit....infact you should have kept the PD186 on sub, nicer sounding IMO. then spent your monies on getting the correct drivers for a kick/bass section. Edited by Jimmer - 06 July 2012 at 1:01pm |
levyte357
Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Posted: 06 July 2012 at 1:23pm |
Different people have different ideas about about mid bass J... But, aye, PD186 is not all that above 150hz, as a mate is finding out.. Which PD driver is copy of the Fane 18B, is it the PD188? |
Jimmer
Posted: 07 July 2012 at 1:07am |
Eye that's fair enough Lev, I appreciate people have different views. Just putting my opinions across. In the kick section I like the driver to be fast and accurate
![]() yup the PD188 is good for this use, possibly closest to the fane 18b. I nearly went for these but got the RCF L18S801 instead and have been well impressed with them since. |
Ras Loud
Joined: 08 January 2012 Status: Offline Points: 755 |
Posted: 07 July 2012 at 2:11am |
