Plans for RCF dual 18" |
Page <12345> |
sn95
Joined: 10 March 2013 Location: USA Status: Offline Points: 351 |
Posted: 25 June 2016 at 3:29pm |
Don't give up yet mush like anything in life at appears to be simple at the beginning but it's not .if you are wholeheartedly sit on using that driver maybe look in to a tapped horn I think there are 2 or 3 plans that may be suitable for the x451 .
djteknovibe
Posted: 25 June 2016 at 8:13pm |
I'm absolutely dead set on using that driver I just thought seeing as it's rated at 18,000 watts AES and has a 13.5mm xmax figure that two in an enclosure would give some serious bass. I don't know anyone that could say for definate that the driver could be excellent in a horn or what horn and I don't know anyone that could make the horn enclosures for me. I ideally wanted two dual 18" enclosures to give me some serious powerful sub bass.
Pbg
Joined: 13 January 2015 Location: Wv USA Status: Offline Points: 8 |
Posted: 26 June 2016 at 3:09am |
For the amount you're insisting on spending on drivers, why not spring a little more on a saw, a straight edge, and a screwgun? Building a box is the easy part. Knowing what you actually want and designing one that does it is the trick.
djteknovibe
Posted: 26 June 2016 at 9:13am |
Nah i'm absolutely useless at carpentry.
toastyghost
Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10932 |
Posted: 26 June 2016 at 2:54pm |
Then since you're paying for premium drivers budget for premium built boxes. Plenty of builders out there and a reflex cab is usually easier to knock out.
djteknovibe
Posted: 26 June 2016 at 6:42pm |
I don't know any though
nickyburnell
Joined: 06 February 2005 Status: Offline Points: 4408 |
Posted: 26 June 2016 at 8:41pm |
I can read. The box is just wood, not Fane wood . The idea was as a big enough box for you to start from then play with ports to get to your goal |
DMorison
Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1740 |
Posted: 26 June 2016 at 9:02pm |
So, you haven't even googled "UK Speaker Builders"? Copypasta this into a new post in the "Wanted" section (everything in bold you have to do yourself): Subject: Design, Build & Deliver 4 off single/ 2 off dual (delete as applicable) 18 BR to be loaded with LF18X451 Message: Preferred frequency response: XXHz to YYHz (-3dB) Maximum dimensions: xxx by yyy by zzz mm Material: 18mm Baltic Birch. Finish: Warnex or equivalent Grille required: 1.6mm steel, powder coated, min 60% open area Handles required: <insert your requirements here> <any other requirements you have go here> Just be prepared to give your wallet some exercise
djteknovibe
Posted: 26 June 2016 at 9:21pm |
At the moment I haven't got the money I just wanna get a price for two enclosures for the drivers amd see how much people might charge
cookie-dj
Joined: 09 May 2014 Location: Warwickshire Status: Offline Points: 975 |
Posted: 26 June 2016 at 9:52pm |
You can't polish a turd!
djteknovibe
Posted: 27 June 2016 at 11:24am |
I'm saving up the money and definately wanna buy some subs or get enclosures made but I have no idea what the cost of enclosures being made would cost me.
nickyburnell
Posted: 27 June 2016 at 3:03pm |
So you don't want to learn how to use sims
You don't want to learn how to do carpentry. You have no money. People have been trying to help, spending their time. Perhaps some more background on you? Age, job, background in PA or Music? |
Page <12345> |
