  New Posts New Posts RSS Feed - Plans for RCF dual 18"
 Post Reply Post Reply Page  <1 2345>
djteknovibe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djteknovibe Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2016 at 3:09pm
So you're jumping to conclusions? *rolls eyes*. I never said I don't wanna learn how to use design software I am trying so gimme a break. I never said I don't wanna learn carpentry either so stop putting words in my mouth mate. I said i'm useless at carpentry.
What's my age and job got to do with me wanting two dual 18" subs? I know a bit about sound systems like what power comrpession is, what RMS actually is (voltage not watts like people think), I know quite a bit but not a hell of a lot, if that makes any sense.
rish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rish Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2016 at 3:22pm
Originally posted by cookie-dj cookie-dj wrote:
Sorry cookie-dj, I just had to repost your pic...... after reading this tread.
Rish
Post Options Post Options   Thanks (0) Thanks(0)   Quote djteknovibe Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2016 at 4:05pm
Rish, if you haven't got anything to add apart from that stupid f**ing picture then don't bother.
Edited by djteknovibe - 27 June 2016 at 4:07pm
sn95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sn95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2016 at 11:40pm
Ok so today I had some time to play around with x451 some more and came up with the following box modeled after the Gsub but a little bigger 16.398 or 464.33 L tune to 33hz .The outside is 1220x610x711 using 24mm ply and the will be 562x 175x505 and a port velocity of 23.5 m/s . It can take 3k at Xmax and will produce 127.7 /30hz and from 40to 100 / 132Dbs .also don't take to hard it's just a joke.
sn95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sn95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2016 at 11:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote djteknovibe Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2016 at 8:21am
A joke is one thing but purposely spamming the thread is annoying, I can't look at that DIY forum i'm not a member and all I get is a log in page come up. Thanks for the help with the G Sub design, the port velocity is extremely high isn't it've been reading about port velocity and i've read anything above 0.10 causes port noise.
sn95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sn95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2016 at 11:43am
The port velocity I'm getting is 23m/s at 3k.but the port can be made big to lower the velocity. By go to a 200mm it go down to 20m/s .
Post Options Post Options   Thanks (0) Thanks(0)   Quote djteknovibe Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2016 at 1:55pm
But 20m/s is still a hell of a loud port noise. When I was using the original G Sub plans as a design the port velocity I got down to 0.16.
sn95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sn95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2016 at 2:05pm
What was your Watt input?
Post Options Post Options   Thanks (0) Thanks(0)   Quote djteknovibe Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2016 at 4:10pm
I can't remember if it was 1 watt or 3,600 watts because that's the combined power of two RCF LF18X451 drivers and in WinISD I did select two drivers so...
Post Options Post Options   Thanks (0) Thanks(0)   Quote djteknovibe Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2016 at 4:14pm
Just checked WinISD just now and yeah it was at 3,600 watts and the port velocity is 0.16 it says.
Edited by djteknovibe - 28 June 2016 at 4:14pm
sn95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sn95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2016 at 4:58pm
Just for comparison I input the Gsub port and 3k it's at 42m/s so either I'm putting some input wrong are you are .I will recheck my input .
