  New Posts New Posts RSS Feed - Please Help Boss R12002
Leonardo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonardo Quote  Post ReplyReply Direct Link To This Post Topic: Please Help Boss R12002
    Posted: 04 January 2020 at 9:57pm
So I have a Boss R12002 car amp, it shuts my power supply off, right when i put the remote cable.
Can someone give me some repair advise?
I made a video see link below.
https://mega.nz/#!iqIigaRa!rCiLf1twrf4WYUeEog42yjLCRFIoeB35xGv3Xi9Wyj8
BJtheDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BJtheDJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 January 2020 at 12:32am
Did you try connecting the remote cable before turning on the power ???
It's a difficult choice, would you rather have:
A: A vegan son.
B: An OnlyFans daughter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonardo Quote  Post ReplyReply Direct Link To This Post Posted: 05 January 2020 at 7:52am
Yes sir I did, but I get the same result
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 05 January 2020 at 10:53am
Check the remote cable is correctly wired for polarity.
jackSpug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jackSpug Quote  Post ReplyReply Direct Link To This Post Posted: 05 January 2020 at 4:30pm
Try putting a link cable between the 12v+ on the amp to the remote input. If amp fires up it's a fault with the remote from the head unit
Edited by jackSpug - 05 January 2020 at 4:31pm
two people use this account
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonardo Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2020 at 10:32am
yes it is
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonardo Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2020 at 10:33am
also tried that, same results
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonardo Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2020 at 10:38am
I had early removed the driver transistors to see if the Power Supply (PS) section is good or not, and as result the PS section is fine. So i checked driver transistors (according to it's datasheet) and they are working as they should. So i went further on to check the output transistors, surprisingly they were also good. Don't see any blown caps or resistors.. So that is wondering me where the heck the problem is. Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2020 at 12:46pm
If the amp is working normally and only faults when you enable the remote input, then it isn't going to be a fault with the amplifiying circuitry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonardo Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2020 at 7:17am
Where should I look then for the fault?
This page was generated in 0.268 seconds.
