  New Posts New Posts RSS Feed - please help me choose my new amp(s)
dj haydn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj haydn Quote  Post ReplyReply Direct Link To This Post Topic: please help me choose my new amp(s)
    Posted: 03 April 2014 at 10:56pm
the amp(s) will be used for bass duty, and likely more often than not, run from standard plug sockets. at the moment i have 10 bins, eventually i want to add another 2 making 12 in total so the amp(s) need to be capable of powering 12 v-18's,
It would also be quite nice if i could run my kicks ( 4x pd 1550's) off one of the channels to save me buying a possible 3rd amp,
Iv shortlisted the amps that are in and just above my price range, and im hoping somebody can help me make up my mind on what will be the best solution and ultimately what will sound best
option 1:
2 matrix xt10000mf's 2ohm version doing 4 v-18's on 3 channels and the pd's on the 4th
option 2:
3 matrix xt10000mf's standard just powering the v-18's 2 per channel at 4 ohm
option 3:
mc2 e100 also doing 4 v-18's on 3 channels and the pd's on the 4th
option 4:
2-3 void infinite 8 v2's or 2-3 crest ca18 if i can find them in good enough condition at a reasonable price
option 5:
6x jbl mpx 1200 bridged per pair of v-18's
will look forward to hearing what you guys think
matt
contact me for booking the Earwax Sound-system
@ Earwaxsoundsystem@hotmail.co.uk
dlyxover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 03 April 2014 at 11:32pm
Would be worth checking out the SAE amps Mr.Wilkes imported.
Contact bee on on here for info.
In the Truth there is no news, and in the News there is no truth
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 03 April 2014 at 11:39pm
cheers, currently im the only person in the uk with stock available.... I have all models of the pcm, pqm and pxm range available, and dbmark lms units. Im also sorting out all bms drivers on behalf of Tonys daughter....
the only model out of stock is the pxm1450... I have 20 units due in in the next week or so...
audiomik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiomik Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2014 at 12:45am
Matt
have a word with Andy at Matrix
Mik
Warning! May contain Nuts
plus springs, washers, screws, etc, etc.
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2014 at 3:36am
i realy want to see/hear these sae amps on paper at least they look incredible! 4 channels of 2kw per channel at 4ohm in a 2u 10kg package costing less than four figures??? if they live up to t paper work then im shocked more people aint using them but i guess itws cos they are a new ish thing dffo keping an eye out for reviews on these :-]
horn loaded for her pleasure
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2014 at 9:08am
Mark I could arrange a demo, or put you in contact with users in your area....
THECANDLEMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote THECANDLEMAN Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2014 at 9:43am
Look at the sae 4 channel big boy............
If you decide against then buy 2x Void Inf8 mk2's or 3x mk1's
Motion Systems - Void Airmotion, Airten & Stasys 218 With Powersoft DSP
tomr_29 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomr_29 Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2014 at 10:04am
I'm actually running comps on one side of my PCM13 and I have to say I'm seriously impressed from my testing so far. I did a direct comparison between the PQM13 and an XT800 running into a pair of BMS 4590p coax comps. Afterwards I sold the XT800...
For running 12 x 18-v1000s I'd probably opt for 3 x SAE PCM18, especially if you're running from 13A sockets. With two drivers per channel there's plenty of power, the amp would have an easy life and in the worst-case scenario the channels are 2-ohm stable. Probably works out the most reliable / cost effective option.
Proper capitalisation is the difference between helping your Uncle Jack off a horse and helping your uncle jack off a horse.
www.facebook.com/tremoracoustics
Post Options Post Options   Thanks (0) Thanks(0)   Quote THECANDLEMAN Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2014 at 10:47am
do sae do a small amp for driving comps ?
the smallest size I can see is the 650 and its 650 a side at 8 ohms and 1000 a side at 4 ohms stereo
any chance of a 5-800 watt amp total ??
250-400 a side  at 4 ohm stereo ??
Edited by THECANDLEMAN - 04 April 2014 at 10:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj haydn Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2014 at 2:36pm
im not too sure about the sae amps, i really like the idea of a uk made amp and im definately considering using matrix again, if the 2ohm 10000mf can do as well as the inf8 then i think a pair of them will be the way to go, plus it should all match nicely as i am using a xt 6004 for my tops already, how would the mc2 e100 compare to a pair of 10k matrix  in 2 ohm?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomr_29 Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2014 at 2:54pm
I was just thinking if you're limited to using 13A sockets you might benefit from using 3 slightly smaller amps than a couple of really big amps so you can spread the load over more sockets. Running more bins per amp will obviously pull more current. Another option could be something like the FFA 10000 which has a separate supply for each channel?
I avoid running amps at 2 ohm anyway. I keep that option for emergencies only! Personal preference of course...
Matching amps is always nice though, it was a good excuse for swapping my XT6004 for the PQM13 Wink
Edited by tomr_29 - 04 April 2014 at 2:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2014 at 3:01pm
have not seen any of the sae amps in full tilt action, but read and heard they can do some damage...
This page was generated in 0.082 seconds.
