  New Posts New Posts RSS Feed - ply wood
ply wood
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 13 July 2011 at 12:46am
Smile
I buy Birch Ply by the crate (22 sheets) and I get it for £31.00 per sheet.
Is that £31 inc or Excl VAT?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 13 July 2011 at 12:50am
Originally posted by mikey bear mikey bear wrote:
Originally posted by hmaudio hmaudio wrote:
...55quid a sheet from b&q and that does get you some free cuts too...
which is fine unless the saw at your nearest b&q is anything like my local...manned by stubborn idiots and not correctly calibrated, ie. cuts will differ as much as +-3mm  from top to bottom.
The best thing I ever did was buying a festool and making all the cuts myself.
I used to work as a scenic chippy building sets for theatre. We would use very cheap ply, like that mentioned previously, as it would only by needed for 3/4 weeks at a time. The quality was so poor you could make it warp just from looking at it! I would also regularly cut through thin pieces of metal found within the laminates. Another problem was screwing into the endgrain because of the large amopunt of voids. Would never consider using it for speaker cabinets. Birch or MDF.
None of this is really an issue as they cut up their own boards and you just take your own tape and measure them, anything they f**k up just dump in the isle and get another ***FREE*** sheet for the quarter-wit to practice on!!!
I have, on several occasions thrown the TW*T off the saw and cut my own boards in BnQ...
18mm birch is £50 inc VAT a sheet and TBH given the option of loosing stuff you don't like can be a very cheap solution....
Smile
SmileSmileSmileSmileSmileSmileSmileSmile
mikey bear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikey bear Quote  Post ReplyReply Direct Link To This Post Posted: 13 July 2011 at 12:57am
LOLLOL
Night Hawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Night Hawk Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2011 at 3:44am
Has anyone had any experience using the Bristol Wood Recycling Project? They have sheet's of 18mm Hardwood listed for 18 quid a sheet. This seems scarily lower than any of the prices posted above, am I missing something?
david View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote david Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2011 at 3:04pm
celco do some good deals on ply 18mm  27 each for hard wood.
they also do cheaper for 17 each but only 7 lamanet and  there are voids in it
mykey- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2011 at 5:47pm
Smile
5 x 5?
Edd Jordan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Edd Jordan Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2011 at 7:32pm
In the Pipe?
