Plyboard |
Post Reply | Page 12> |
gingerbiscuit69
Registered User Joined: 23 September 2005 Location: United Kingdom Status: Offline Points: 2540 |
Posted: 23 September 2005 at 5:31pm |
Does someone who has previously made one of these know how many sheets of 8x4ft boards these need?
Im actually planning to construct a Dual X1, Having the tops, bottoms, and back as one, but have a divider in the middle to keep the internals the same. Should be interesting and bloody heavy. Hope the neighbours dont mind.... |
mobiele eenheid
Old Croc Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
I agree, it would be interesting, but why duals? If I am not mistaken it would weight over 200 lbs. I find trouble enough in moving around my 170 lbs bass bins by myself (and I am already quite nuts when it comes to that). I am sure the neighbours will love it tho Wkr Johan Edited by mobiele eenheid |
gingerbiscuit69
sounds sad i know, but its to save on costs of production on a whole and leaves less cutting for me to do.
Also, they are to be used off 1 amp each anyway (ie, one bridged amp per dual cab). By combining them, i cut out the link cable inefficiency, save one side of Ply, Only need one connector panel per cab, One set of handles, and the stick some castors on the back and they should (just) move. They shouldnt be moving around that often anyway. Also, I think it will look quite darn cool! Anyway, who else has ever been mad enough to do this before? |
mobiele eenheid
Well, now and then people come and go that want to make double X1's. Till now everybody has been talked out of doing so. AFAIK you're the first. Wkr Johan |
gingerbiscuit69
hopefully ill be a trend setter! Theres a first for everything!
mobiele eenheid
Of course you understand that you must post pics? Wkr Johan |
gingerbiscuit69
ill post pics, but it will be at least Christmas before i have anything remotely resembling this. Ive finished my plans.
Pretty simple all together, keeping the Bottom, Top and rear as 1194 long sheets, then inserting the two contents. The centre divider will mounted in line with the rest of the insides (20mm) and will have a slot on the front so the 'front panel' is one piece too, making the centre look like another port brace and making them look even fatter. Hopefully cover with Carpet, Metal Corners (cos the amount of weight bashing things cant be good), then metal rightangle along the edges. Should look beefy, and old school! Lets hope they perform as well as people say as im putting a lot of work (and £££) into these! |
gingerbiscuit69
just had a thought, would the divider in the middle be nessasary to keep the design efficiency working (as in having a different volume with 2 drivers?). Or can i just put in what is effectively another port brace on top and bottom to keep the strengh, cos then i can have all the mdf in nice long pieces leaving even less work to do!
mobiele eenheid
Yes, you can. The only benefit of the separated chambers would be, that if one accidently stops, it's not going to function as an acoustic shortcut. It would still damp tho but not as much. Wkr Johan
Dom
Old Croc Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 1700 |
Can I say something??? You're insane. Have you considered how you're going to get this 1194 x 800 x 770 (not including wheels) monster through a door? Do you have any idea how heavy this will be? Personally I don't think an X1 is a one man lift, which to me means a double will a real pain to move with two people. And that's out of ply, never mind MDF. If you're doing it to save wood (one less panel, two less if you don't divide them (which you will need to do if only to brace the other panels)) then you'll save under £3 per panel using MDF and about £7 per panel if you use baltic birch ply... An extra pair of connectors will cost under £3. Handles are free if you cut them into the cab design. Is it really worth the saving??
LunchieTey
Young Croc Joined: 06 February 2005 Location: Australia Status: Offline Points: 934 |
You try to tell them....and they'll say it's all 'cool' and they'll be
'awesome' and 'old school' until....you can't bloody move them cause
your mate got drunk and pissed off and left you to move them yourself.
I have ply 6th order boxes very similar to the x1(slightly smaller) and
they're a pain already. If someone said why don't i join them into
doubles,I'd say see that one? Try and pick it up...
I just don't see how a big stupidly heavy box(the size of a double refridgerator) will be any cooler than two stacked on each other? I personally like the look of multiple cabs linked by those nice little blue collared speakons. Looks nice and professional. In fact it looks 'pro' because it doesn't look like some home-made black fridge with ports... Ask yourself how many massive bassbins you see made by manufacturers,except those marketed for big touring companies with semi's and 20 hairy,tattooed roadies...you'll also notice many have handle spacings to suit 4 man lifts... Well I'm going outside now to combine all my bass and mid/high enclosures into one box and paint it to look like a 30ft ghetto blaster from the 80's cause it'll be cool... Edited by LunchieTey |
Speaker addict
gingerbiscuit69
lol, point taken. . How many kilo's does one of these weigh then?
