Plywood thinkness, does it make a difference??? |
Post Reply | Page 12> |
stem
Registered User Joined: 14 February 2007 Location: Liverpool Status: Offline Points: 45 |
Posted: 14 February 2007 at 2:13pm |
Hi,
I've been a bit of a nob and ordered the wrong thickness of plywood but does it make a great deal of difference? Im not arsed about it getting a bit batterd, i'm bothered about the sound quality out of it. Could anyone enlighten me??? Thanks Ste |
Insomnia
Old Croc Joined: 06 September 2005 Status: Offline Points: 1721 |
a couple of questions
what thickness have u ordered?and what do u intend on building? Edited by Insomnia - 14 February 2007 at 7:18pm |
jethrocker
Old Croc Joined: 07 June 2006 Location: Chiapas, Mexico Status: Offline Points: 1942 |
You'll probably need to redraw the plans to keep the same internal dimensions for all horn flares etc, but it should work ok... so long as you didn't buy bendy 4mm!!
stem
I have bought 1/2 inch ply instead of 3/4 inch ply.
Im trying to build the 1850 horns. I've have had some problems drawing the plans on the side of cab but I've managed to squeeze them in with one or two mistakes. |
ceharden
If you're using half inch for the 1850 horns you're gonna need A LOT more bracing to stop the whole thing trying to blow itself apart when you fire it up.
stem
The extra bracing isnt going to affect the sound is it?
ceharden
It will affect the sound, it'll stop the panels resonating and make it sound better!
stem
oh right ok snd! Tar for that ppl!
COWFOOT
Registered User Joined: 26 September 2005 Status: Offline Points: 1088 |
Can't you return what you bought and get the right stuff?
stem
No, because timber yards cut to the cutting list I gave them and it isnt there fault that I wrote down the wrong thickness so therefore they wont loose out by wasting a load of ply
COWFOOT
Park the half inch stuff for the time being.Get the thicker ply and move on.No use compromising your efforts by starting out on the wrong foot. |
stem
You meen just scrap the 1/2 inch ply and order a new lot of 3/4 inch?
