  New Posts New Posts RSS Feed - Poor PPX
Poor PPX
GAZ. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GAZ. Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2017 at 9:58pm
One of the last ones as JBL man says. I guess hitachi fets were running out at that point and they fitted the BUZ ones instead.
The vent on the back will be different to all the earlier ones too. The heat sinks heat up to just before the point it's uncomfortable to hold your hand on and the fan cuts in.
just got back from the sellers house with a replacement PPX, they had another
Later type power switch but still hitachi fets. Took the top off before I loaded it into the car and apart from a little dust, and the usual resistors going a bit brown this one is perfect.
100% Earth Moving Bass
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2017 at 10:11pm
great stuff. that other one you had.. yeah that wasn't even a project.
GAZ. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GAZ. Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2017 at 10:26pm
I’ve still got it, there will be a few bits salvageable so it will live on in the form of spares for my other ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2017 at 11:36pm
my longest DJ residency was in a PPX-powered venue; a stack of them higher than a man, driving Martin & OHM. They just kept going.
North Staffordshire
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2017 at 11:40pm
I ran a 900 and 450 into solid red lights and covered in condensation every weekend for ages. Sodding amazing things, went through drivers, comps (messy times) and the amps just carried on. Only mod was fans on all time. The G Wagon of amps.
valve head777 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote valve head777 Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2017 at 11:46pm
Was looking at the hire list of a long established hire outfit in Brighton where over 20 years ago I would hire ppx's from, and they still have them!
Eventually got my own, don't have it anymore but miss the thing still, and would consider getting another if the price was right. Great for mid and tops.
Edited by valve head777 - 20 October 2017 at 11:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2017 at 11:49pm
er Land Rover
North Staffordshire
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2017 at 2:00pm
I've said this before on here but when one of my XR3801's went pop one night the only amp I had spare was a PPX900 so that got patched in rather hurriedly. It was running a pair of HD215's and considering the Citronic was 1.5kw down on the C Audio the difference in output wasn't that great, as I said before, it was the loudest 900w I've ever heard. It ran quite happily for the rest of the night stuffed in the gap next to the amps on its side in no flightcase.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2017 at 3:36pm
Originally posted by kedwardsleisure kedwardsleisure wrote:
er Land Rover
Yeah, but if I had said Land Rover someone would have said LandCruiser! Went for the top, ! But I see your point, British....
GAZ. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GAZ. Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2017 at 5:03pm
Put the poorly PPX on the bench earlier. First I gave the burned PCB a scrub with some soapy water.
Didn’t look nearly as bad after a good clean.
Then I did some testing. First off I checked the 2 bridge rectifiers, both ok. Main fuses also ok. Plugged it in, switch works.
Both secondary of +/- 80v present and working. So power supply is still good
Next I removed all the output mosfets and tested them..
Those are all good mosfets amazingly!
Just 3 dead. 2 completely blown and one leaky.
I expected a lot worse than that to be honest.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2017 at 6:11pm
Well Done Gary,would be an epic endevour if you could bring that back to life again.....
We need a "show off your PPX thread"....have a big pile of them here,most are the early mk1's now,so have to be nigh-on thirty years old now.  Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2017 at 6:15pm
Cool
Clap
