  New Posts New Posts RSS Feed - Poorly Djm 700.
Poorly Djm 700.
msoundsystem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote msoundsystem Quote  Post ReplyReply Direct Link To This Post Topic: Poorly Djm 700.
    Posted: 18 July 2018 at 8:19am
hi guys. Have a djm 700 mixer. All phono channels have a loud buzz/hum when faders turned up even with no input scorces are connected, only thing that's connected is the xlr outs. The lines on every channel are perfect just seems to be the phono stages. Any thoughts? Cheers.
service dept Steve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote service dept Steve Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2018 at 1:57pm
One or more loose capacitors in the power supply would do that.
We are not "They", We are "The others"http://www.servicedept.co.uk -
Daniel S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel S Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2018 at 4:19pm
Hey, I have one with the same problem but never gotten around to fix it. I'm following this thread with great interest.
Distortion is evil
Post Options Post Options   Thanks (0) Thanks(0)   Quote msoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2018 at 6:47pm
fixed. Was the big capacitors on the bottom board. They had broke the solder joints, Reflowed and tested them with meter, mixer fully working again. Cheers for reply!
Edited by msoundsystem - 18 July 2018 at 6:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote service dept Steve Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2018 at 7:47pm
No Problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel S Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2018 at 4:33pm
Thanks for the help guys. Mine had two bad caps on the botton board. Now the mixer is working the way it should again. :)
Distortion is evil
This page was generated in 0.110 seconds.
