Poplar ply - any good? |
Page 123> |
stevie ![]() Registered User ![]() Joined: 16 March 2008 Location: Dorchester Status: Offline Points: 425 |
![]() ![]() ![]() ![]() ![]() Posted: 10 October 2014 at 6:07pm |
Does anyone have any practical experience of bass cabs made from poplar ply? Do any pro companies use this material for their boxes? The weight savings are attractive but I wonder how they perform in comparison with proper birch.
djyves ![]() Young Croc ![]() ![]() Joined: 06 April 2009 Location: the Netherlands Status: Offline Points: 564 |
I've build a few cabs and cases out of poplar ply. It's much softer and more flexible.
So it will require more bracing, but it is a cheap alternative. I sometimes use it for modular 19'' racks for amps, effects etc. works fine.
TONY.A.S.S. ![]() Old Croc ![]() Joined: 21 February 2007 Location: United Kingdom Status: Offline Points: 6878 |
I've done some guitar and Bass guitar cabs out of it. Not sure about heavy subs. I'd probably double it up just to make it nice and heavy. If the end grain doesn't become a problem, it is certainly alright for non acoustic stuff.
MarjanM ![]() Old Croc ![]() ![]() Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7707 |
Dynacord use poplar in lot of their boxes.
I was thinking of building a reflex cab using a single BMS 500W 15" driver. I don't think poplar is any cheaper than birch but it's much lighter - which is its attraction. I want to keep cabinet vibration to a minimum. Perhaps extra bracing might do the trick then.
I didn't know Dynacord used poplar. Interesting. |
RobinMatrix ![]() Young Croc ![]() Joined: 23 August 2013 Location: Kidderminster Status: Offline Points: 567 |
We use a lot of poplar in our builds, both Italian and Spanish variants, it's more expensive than Birch, but it is light. If you brace it appropriately it is fine. We have built several hundred poplar cabs the past year ...
Matrix Pro Audio ::http://matrixproaudio.com/"
woody2 ![]() Old Croc ![]() Joined: 04 March 2010 Status: Offline Points: 1698 |
burns well
swan ![]() Registered User ![]() Joined: 30 January 2012 Location: Johannesburg Status: Offline Points: 170 |
JBL use poplar ply wood in their PRX range. Very light.
Music is my adiction
bitSmasher ![]() Old Croc ![]() ![]() Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2289 |
Not very poplar as it seems
jazomir ![]() Old Croc ![]() Joined: 20 November 2006 Location: Sunderland UK Status: Offline Points: 1696 |
There are several pallets of the stuff in the Peavey Auction that was highlighted in another thread. (It is referred to as 'popular' ply)
Dub Specialist Sound ![]() Old Croc ![]() Joined: 15 November 2013 Location: Smethwick Status: Offline Points: 4873 |
I have used it before, you can get some good results , bit of extra bracing jobs a gud,un
above all wood burns well to my knowledge....no? , NO perhaps not!!!
Edited by Dub Specialist Sound - 21 November 2014 at 12:12pm |
KidCreole ![]() Old Croc ![]() ![]() Joined: 06 November 2013 Location: London (East) Status: Offline Points: 3599 |
No. Should never be used for speaker cabinets. Too light weight.
Mykey Wattco
Page 123> |
