Poplar ply - any good? |
Page <123> |
MarjanM ![]() Old Croc ![]() ![]() Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7695 |
I wonder what kind of cardboard wood is used in the JRX range.
Dub Specialist Sound ![]() Old Croc ![]() Joined: 15 November 2013 Location: Smethwick Status: Offline Points: 4873 |
Better than chipboard no?
mini-mad ![]() Old Croc ![]() ![]() Joined: 13 July 2012 Location: london Status: Offline Points: 6903 |
thats like saying titainium is to light for aircraft construction...... |
Poplar plywood is much softer then the birch. That is why it is lighter.
stevie ![]() Registered User ![]() Joined: 16 March 2008 Location: Dorchester Status: Offline Points: 425 |
The information I'm able to glean on the web, which is not much, is that poplar plywood can be as stiff as birch. This one here: http://www.panguaneta.com/en/industrial-plywood/okoume-superior-plywood is faced with okoume to give it a harder exterior surface. Its bending strength is 40NM/m2, which is the same as birch plywood.
That doesn't seem to be the general consensus here though. |
KidCreole ![]() Old Croc ![]() ![]() Joined: 06 November 2013 Location: London (East) Status: Offline Points: 3599 |
Edited by KidCreole - 21 November 2014 at 4:46pm |
Mykey Wattco
bass*en*mass ![]() Old Croc ![]() ![]() Joined: 03 September 2009 Location: "unknown" Status: Offline Points: 4009 |
guess it depends a lot which manufacturer as with many other things?
poplar is poplar, balsa is balsa, some might mix them up and sell as the wrong deal? the sheets available from the peavey auction look quite well made, if they even have a hard outer layer as mentioned above why should they not be usable for small, light cabs, appropriate bracing provided? |
They are used. No one says it can not be used. But it is not as strong as birch.
Many Dynacord boxes are poplar plywood.
I have seen it with birch outer veneers. Made in china. It was about 1/3 the price of birch
poplar ply is not always poplar. What I have seen was always mixed. Soft core rubbish
Mykey Wattco
You can have string and stiff but if its light it will go walkabout
I like bass bins to stay where they are
Mykey Wattco
nickyburnell ![]() Old Croc ![]() Joined: 06 February 2005 Status: Offline Points: 4410 |
Have some here, made from MDF, screwed together OK, wood screws holding drivers in, although I have seen VERY high end cabs do that in the past. As I mentioned before, worst I've seen is OSB in EV cabs of old, apart from chipboard of course. |
snowflake ![]() Old Croc ![]() Joined: 29 December 2004 Location: Bristol Status: Offline Points: 2984 |
anyone looking for poplar ply I think I have FINALLY found somewhere that will deliver small quantities for a reasonable price. And they have a cutting service.
https://www.atlantictimber.co.uk/efficency_ply_int_18mm.html commenting on the above thread: poplar surface is not as hard as birch but is better than spruce or pine. hard surface can be achieved with high quality resin/paint/liner/fibreglass. poplar takes paint very well. poplar is not quite as stiff as birch but it is 40% lighter. If you want really stiff panels then use 24mm poplar instead of 18mm birch - it will be lighter and twice as stiff. If you want heavy cabs then replace some of the wood weight with bigger drivers!
poplar machines very well and reduces tool wear. |
Page <123> |
