Poplar ply - any good? |
Page <123 |
infrasound ![]() Old Croc ![]() Joined: 13 May 2011 Location: Brizzle Status: Offline Points: 2262 |
Thanks for the link snowflake! Just what I'm after. With proper bracing, "just" 9mm of poplar ply can exceed the stiffness of 24mm birch plywood in cabinet. Add a CF/GF skin to that and you're fixing that wear resistance ![]() Nb. 'Proper bracing' involves multiple rounds in FEM analysis & isn't a walk in the park. With guessing the bracing, you can go surprisingly far though. Edited by infrasound - 17 February 2021 at 6:16pm |
VECTORDJ ![]() Registered User ![]() ![]() Joined: 11 June 2006 Location: United States Status: Offline Points: 489 |
Why send all the time and work to make custom speaker cabs and use cheapie ply??? The best I have found is "Finland" 3/4" 4 x 8 foot 100 % birch exterior...........Like a Rock....
snowflake ![]() Old Croc ![]() Joined: 29 December 2004 Location: Bristol Status: Offline Points: 3061 |
the good poplar isn't cheap - if anything it's more expensive than birch. |
I am basing My choice of Finland 4 x 8 sheets as to what is stocked in Maine USA. The Poplar cored ply here has very thin Birch outer layers and is not water proof. Sort of soft too. Go Finland. Like a Rock.
stevie ![]() Registered User ![]() Joined: 16 March 2008 Location: Dorchester Status: Offline Points: 425 |
How exactly did you reach that conclusion?
deflection of a panel is proportional to the width^3 and inversely proportional to the thickness^3.
FEA and some physical validation
And did all this FEA and physical validation result in a commercial product?
Nope, only for personal toys
IMO it would be hard to commercialise, specifically due to the cost, assembly complexity, tolerance, wear and definitely overall strength. I'm happy to manage these personally, but wouldn't scale well upwards from there
Page <123 |
