  New Posts New Posts RSS Feed - Poplar ply - any good?
infrasound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2021 at 6:13pm
Thanks for the link snowflake! Just what I'm after.
Stiffness is determined by the bracing primarily, thickness second.
With proper bracing, "just" 9mm of poplar ply can exceed the stiffness of 24mm birch plywood in cabinet.
Add a CF/GF skin to that and you're fixing that wear resistanceParty
Nb. 'Proper bracing' involves multiple rounds in FEM analysis & isn't a walk in the park. With guessing the bracing, you can go surprisingly far though.
Edited by infrasound - 17 February 2021 at 6:16pm
VECTORDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VECTORDJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2021 at 9:05pm
Why send all the time and work to make custom speaker cabs and use cheapie ply??? The best I have found is "Finland" 3/4" 4 x 8 foot 100 % birch exterior...........Like a Rock....
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2021 at 9:19pm
the good poplar isn't cheap - if anything it's more expensive than birch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote VECTORDJ Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2021 at 8:02pm
I am basing My choice of Finland 4 x 8 sheets as to what is stocked in Maine USA. The Poplar cored ply here has very thin Birch outer layers and is not water proof. Sort of soft too.  Go Finland. Like a Rock.
stevie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevie Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2021 at 1:08pm
How exactly did you reach that conclusion?
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2021 at 12:16pm
deflection of a panel is proportional to the width^3 and inversely proportional to the thickness^3.
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2021 at 1:48pm
FEA and some physical validation Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevie Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2021 at 2:27pm
And did all this FEA and physical validation result in a commercial product?
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2021 at 3:04pm
Nope, only for personal toys
IMO it would be hard to commercialise, specifically due to the cost, assembly complexity, tolerance, wear and definitely overall strength.
I'm happy to manage these personally, but wouldn't scale well upwards from there
This page was generated in 0.184 seconds.
