Porn Addick |
Post Reply | Page <1234> |
JD01
Young Croc Joined: 23 August 2004 Status: Offline Points: 819 |
I bet my ass those breasts cast a huge shadow...
tendril
Registered User Joined: 22 July 2004 Status: Offline Points: 334 |
Would there be any reason why this design couldn't be altered, so that
there is an access panel at the rear for the mid driver, and then
having the empty space on the horn side between the horn and the
cabinet wall filled with expanding foam, to give support and improve
sound quality?
Tendril
A mistake is a mistake only if one learns nothing from it. |
Mark James
because then the poor lass would die!!!!! |
Mark James
also that plan says for 2x12" porn ahorn and 1x1.5" and only seems to show 1x12" or am i just looking at it wrong? edit. ive just realised it sys for 2x12" [ie If you are doing a 2x12" version] then make it said 12??cm height as opposed to the height on the drawings. Edited by coner - 14 February 2006 at 8:37am |
tendril
why? If I keep the back volume the same then an access panel won't effect the back volume. And the foam was meant to go as in red: Obviously the driver would need to be mounted to the horn differently, but this was just a 'what if' scenario. |
Tendril
Mark James
i was reffering to the girl in the avatar whom if an acces panel was added to her rear and her mid and then filled her with expanding foam..... oh dear that sounds rather rude actualy making an acces panel on her rear and filling with expanding foam.....
tendril
aha!
Tendril
fr3ttch3n
Registered User Joined: 06 June 2007 Location: Austria Status: Offline Points: 1 |
What is the maximum SPL of the Porn horn and respectively what is the f low at full load(+- 3db)? Are there any Plots online?
greez from austria alex |
bitzo
Registered User Joined: 20 November 2007 Location: Italy Status: Offline Points: 977 |
how do you build the phase plug? Is there any plot?
toastyghost
You don't build it, you buy it. As well as the flare. All parts and plots are on proaudioparts.co.uk |
after11
Registered User Joined: 22 January 2008 Status: Offline Points: 64 |
OK just outa curiosity what does it cost in materials to build a pair of porn horns ? any one?
WWW.AFTER11SV.CO.UK
bitzo
What do you mean for build? The porn horn is selled on proaudioparts but....if you mean building the horn uhmmmmm I think you need some foam, a steel wire to model it or antything you need for modelling, poliuretanic resin to get it solid. Another method could be using only wood like this master do http://www.volvotreter.de/roundhorns.htm, I think this is the only method to build a round phase plug. |
