  New Posts New Posts RSS Feed - Porn Horn MK2
Porn Horn MK2
COWFOOT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote COWFOOT Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2007 at 11:39pm
The MK2 has a lot going for it. I like it.
How about a Porn sub?
Edited by COWFOOT - 25 January 2007 at 11:42pm
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2007 at 8:24am
Originally posted by COWFOOT COWFOOT wrote:
I wonder if the phase plug is very rigid?Can it withstand the force of flying beer bottles etc.
I take it a speaker grill is recommended?
 nice gig's you attend Cowfoot
cow sh-t can still get through the grill's
Post Options Post Options   Thanks (0) Thanks(0)   Quote COWFOOT Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2007 at 8:46pm
The cow crap probably wouldn't break anything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote COWFOOT Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2007 at 8:51pm
Community had a double fifteen low mid horn called the Boxer.That would probably complement the Porn Horn very well.
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2007 at 12:10am
@ceharden: I don't know whether you could strech some sort of condom over a frame,but a 2500cm^2 mouth would make that a little big.
Phase plug.... mould something over a cellophane coated driver and have it meet a bandsaw to make a sort of radial plug is what I'd do. if you want a master part for a nose you could add an extra step and make something like it on a lathe making sure it can fit and incorporating that into your mould
Personally I'd prototype out of an even-rising 2k expanding polyurethane foam. A nose would be wooden. A silicone mould would probably be the best bet for a phase plug.
Edited by Timber_MG - 27 January 2007 at 12:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote COWFOOT Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2007 at 8:04pm
Maybe one could build a metal framework to hold the 12" horn as well as the compression horn thereby eliminating the wooden cabinet.Something to ponder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2007 at 1:03am
cowfoot! look at my design from a few years ago, metal frame's
unclejam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote unclejam Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2007 at 1:51am
wouldnt that cause resonances?
heavy right really heavey
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2007 at 2:40am
no! actually lighter than a wooden cabinet
hollow square steel tubing
first option was for aluminium, but was too costly
Post Options Post Options   Thanks (0) Thanks(0)   Quote COWFOOT Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2007 at 7:42am
Lots of advantages to having the metal frame.One con though is most of us don't know how to weld or have the equip.I guess we could call on a welder to make the frame.
login4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote login4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2007 at 8:24am
i think its a great idea, lighter, easyer to handle, looks industrial,
CELTIC SUBSONIC SOUND SYSTEMS
cletus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cletus Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2007 at 9:50am
Funny i was only thinking of this day...
alloy is simple,
Mig welder + argon gas :)
Edited by cletus - 28 January 2007 at 9:51am
