  New Posts New Posts RSS Feed - Porn Horns
Porn Horns
Audiosurge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Audiosurge Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2019 at 9:18am
That woulda been me :)
We are also looking to remake these using different hf section section. Speaking with Rog and he suggested 60-40 around the same size as the old phill horn that was in them. Then he also said this about the low mid section  45 degrees up to around 1kHz. It's a tight 45 degrees down to 500Hz then it gets wider. Vertical dispersion around 30 to 35 degrees. What’s everyone else using above these. I can’t seem to find any horns anywhere near the size needed any help would be much appreciated!!
Ian Mcdermott
Audio surge
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2019 at 12:23pm
The one that was designed for it, I assume. You can rip it out of any Void Stasys Phil cabinet
Apparently Phil uses the same horn as above.
Anyone have Void part number, or know where to locate these?
Originally posted by Aman Gebru Aman Gebru wrote:
Not the same horn but very close.
Phil HF horn has a wider horizontal dispersion than the P horn HF horn.
So, any "Phil" Horns lying around ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Audiosurge Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2019 at 12:53pm
Void won’t sell me any
Edited by Audiosurge - 21 January 2019 at 8:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2019 at 9:57pm
How about LTH142?
https://faitalpro.com/en/products/HF_Horns/product_details/index.php?id=903020105
Put an 18sound NST3 on it....
Edited by toastyghost - 21 January 2019 at 9:58pm
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2019 at 8:36pm
18s nd3st, nd3t, hd3000t + xr1464/xt1464 or the faital horn would get my vote aswell re. HF and output balance + more or less suitable to dispersion requirements..
