  New Posts New Posts RSS Feed - Porn Horns
Porn Horns
boots-hifi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boots-hifi Quote  Post ReplyReply Direct Link To This Post Topic: Porn Horns
    Posted: 10 January 2019 at 4:29pm
Who beat me to it and bought the porn horns from void via eBay?
spongebob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spongebob Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2019 at 4:40pm
There's three left still under auction number 173731465527
Post Options Post Options   Thanks (0) Thanks(0)   Quote boots-hifi Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2019 at 5:02pm
3s no good! I’m greedy and wanted all of them.
Djdarch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Djdarch Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2019 at 5:09pm
they've just sold, not me either!
MattStolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattStolton Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2019 at 5:15pm
What's Lev planning...
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2019 at 10:53pm
I need 1x more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2019 at 10:55pm
Also what''s the recommended compression horn for these?
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2019 at 10:59pm
The one that was designed for it, I assume. You can rip it out of any Void Stasys Phil cabinet
Post Options Post Options   Thanks (0) Thanks(0)   Quote boots-hifi Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2019 at 11:54pm
I’d imagine something like the BMS coaxial HF would work well. The original porn horns I think were loaded with P-Audio although Toasty or Brian M would be able to confirm this. Not to sure what I’d put in the 12” . BMS or B&C spring to mind, maybe Fatial Pro could fit the bill. I’d try and find the most suitable unit for the porn horn, sim it and then choose a HF based on these results. Either way I’d be interested to know what and if the newer drivers outperform the original pornhorns.
pfly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pfly Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2019 at 11:58pm
I think HF was Beyma CP-755Nd when Porn Horn was available
Does anyone have directivity plot for the 12" horn? It would make it quite easy to choose appropriate HF horn to go with the thing
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2019 at 12:14am
Yeah it was. Like I say, the Porn Horn v2 HF horn was repurposed to use in the Stasys Phil
pfly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pfly Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2019 at 12:35am
That I already knew. All things don't quite match though. I think Porn Horn was advertised around 40-60deg nominal while Phil is advertised as 80deg horizontal. If I was in a situation of looking for HF horn to go on top of Porn MF I'd most likely just measure the thing myself and then decide what kind of HF solution I'd like use with it based on MF dispersion, resonance and distortion characteristics.
Edited by pfly - 11 January 2019 at 12:43am
