  New Posts New Posts RSS Feed - Porn Horns
Porn Horns
tdsje View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tdsje Quote  Post ReplyReply Direct Link To This Post Topic: Porn Horns
    Posted: 02 November 2004 at 9:32am
Hi,
I am about to use 4 of those pornhorns for P. Audio's 12B. Is there an dealer for the benelux ? And what kind of rearchamber does the driver need on this horn ?
With Kind Regrets,
Jaap
- It's the size of your horn that counts !-
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 02 November 2004 at 9:46am
Goede Morgen
The only dealer is Proaudioparts as far as I know. Ask them for a quote. The rear chamber should be as small as possible according to Rog.
Kind Regards
Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote tdsje Quote  Post ReplyReply Direct Link To This Post Posted: 02 November 2004 at 1:02pm
Would a cabinet with 2 of those horns per cabinet would be an fit for my labhorns ?
Else i am going to build myself some FH's with Phase Plugs, because i am looking for an dual 12" hornloaded enclosure for my labhorns
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2004 at 7:11am
The labhorn suffers from the same problem as almost all folded horns, it provides energy content high enough to in theory be coupled at the top of its frequency spectrum, but in practice they don't sound good used that high. By most accounts 80Hz is about as high as you want to use them for quality sound from what I gather (I have never heard a LAB)
Rog mentioned that a big stack of Porn would get you a cross of 120 IIRC, but it is probably a better idea to cross them closer to 140. This leaves a gap of almost an entire octave and is the birth moment of a kick cab.
The porn horn is a very narrow dispersion horn and generally it would only make sense to use them with two per side or more for mono-stacks. 4 Porn horns might give you what you want in terms of output combined with the same ammount of kick-cabs when combined with 4 LABS IMO (depends on the music)
If you are thinking of a 3-way using LABS, I don't see anything getting the job done (perhaps at a push a bunch of Tops using really loud 15s, but this would be a compromize in my mind) The horn-loaded solution is much more elegant, but pushes you up to 4-way.
How many LABS are you using in a stack? 4?
Martin
Lasse Lukkari View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lasse Lukkari Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2004 at 12:09pm
I talked about this with Rog just before he left. This is a c/p from the email.
Originally posted by Rog Mogale Rog Mogale wrote:
Hi,
I would make two 2 x 12" horns per side. This is because you need the 12" horns to play to about 90 Hz. The LAB sub does not go very high, so you will need to have mids that go low. But two 2 x 12" horns will be very loud and you will need at least 4 LAB subs to keep up with them.
Or you could use two 1 x 12" horn per side but build something like the HD 15 for use fom 70 Hz up to 140 Hz.
Rog.
owentec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote owentec Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2004 at 12:24pm
There is a variation on the Labhorn (version 3, if memory serves) that has better response at the high roll-off. Supposedly, it'll work out to 160Hz.
If you modified your Labs (no idea if that is possible) to that version, you might be able to get away with it.
Owen
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2004 at 5:06pm
LAB v.3 is a domestic design if i'm not mistaken. It uses a 3:1 compression ratio and is even more involved a build than v.2/v.1 (v.2 is with the originally intended rear volume and a more accurate folding).
The Subs to Tops question is largely a question of music or rather the (peak) energy distribution. If you can get 12s to play down to 100-ish, you'd need a fairly big horn or a couple thereof.
@ vivo, are you perhaps responsible for that insane staight basshorn?
@ tdsje : Perhaps one should start at the beginning, meaning what is the application. I always shoot ahead with a right doomsday machine where you might have a different idea.
Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lasse Lukkari Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2004 at 5:19pm
No. Those 12" horns that rog is talking about in the mail are pornhorns.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2004 at 6:03pm
There was a post by Rog jsut before he left with a pic of two crazy basshorns underneath a balcony/stage somewhere in Scandinavia IIRC.
Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lasse Lukkari Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2004 at 6:59pm
Martin
I think those were from Norway.
quique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quique Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2004 at 9:02am
the distributor of paudio stuff in belgium is www.communitysa.com and in holland is www.audiobizz.nl . I hope ive spelled the www corectly. if not go to http://www.paudio-europe.com/ click on world distributors, choose europe...
bye
quique
This page was generated in 0.076 seconds.
