port of x1 |
t.geessounds
Young Croc Joined: 10 May 2010 Location: US... New york Status: Offline Points: 908 |
Posted: 28 December 2011 at 4:35pm |
hey guy am lookin to build a pair of x1 using the 18sound 12w700 or the 12mb600 but on the plans it say 18MM dept is this right?? 18mm sound like the thickness of a plywood can i just glue an piece of 120x120mm behine the speaker baffel an just cut out the 100mm hole??
Risc_Terilia
Young Croc Joined: 15 December 2007 Status: Offline Points: 698 |
Presumably you're talking about the X12 rather than X1? If so the port depth is 18mm, the thickness of the ply IE just a hole. Not sure what you mean about the 120mm x 120mm hole.
cravings
yeah the ports are just a hole through 18mm ply. made to be easy in this case.
t.geessounds
lol my bad not the x1 but the x12 so all i need to do is cut a 100mm hole in baffel an dat it?
cravings
well, cut 2
the box was designed around different drivers so i dunno if you'll want to sim your ones or whatever to check the tuning... i'm sure people have said the 18sound ones work lovely in a box like that though. |
t.geessounds
thanks for the reply
