  New Posts New Posts RSS Feed - Port Placement
Port Placement
kr1sounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kr1sounds Quote  Post ReplyReply Direct Link To This Post Topic: Port Placement
    Posted: 05 May 2015 at 5:35pm
Can ports being in different places affect the sound in term of depth, spl etc..?
fostonshfs.webs.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2015 at 6:12pm
The only way the port placement can play a factor on the results is if they are blocked.
Best Regards,
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2015 at 8:29pm
Or to the rear if no where near a corner in a big place?
 Coats on
Post Options Post Options   Thanks (1) Thanks(1)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2015 at 10:26pm
It depends on the tuning frequency. At 30-40hz wont mater. But if you tune mid top at like 90-100hz then it surely does.
HR have that feature you can check it.
