  New Posts New Posts RSS Feed - £500 bass amp..?
£500 bass amp..?
 Post Reply Post Reply Page  <1 234
Lucasdude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lucasdude Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2025 at 1:42pm
I would also add that the power supply for amps is really important too. I've lost count of the times I've seen a massive wall of impressive looking brightly coloured horn bins powered by insufficient amps, but worse is the use of woefully underpowered generators. Having good amps and speakers is pretty pointless if the amps don't get enough clean juice, and the voltage sagging under load leads to the volume levels pumping and dumping, with distortion in the upper frequencies to boot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2025 at 3:50pm
"the voltage sagging under load leads to the volume levels pumping and dumping, with distortion in the upper frequencies to boot."
Yes, that's the problem with weak PSU's in the cheaper amps. Clipping & distortion.   Dead
The "2000W" Skytec amp I mentioned in another thread had what looked like a 250VA transformer. Magyk watts don't exist...
