Power limiting approach |
Post Reply | Page 12> |
Augusts
Registered User Joined: 07 January 2017 Status: Offline Points: 180 |
Posted: 28 January 2020 at 2:01pm |
Hi
Could you share some insights about how you limit your speakers? Using longer attack time, release and hold and using treshold by speaker RMS rating, or using the shortest attack time and limiting the power by speaker Program Rating or in this case it would be called Peak power I guess - so that the limiter would not let any signal through the wall. I understand that one value to be voice coil RMS and the other would be Xmax. If you would use powersoft amps for example that would not be a problem. I use a simple DSP and an amp that has variable Peak Power and RMS power. I think the advantage of limiting by Peak is a controlled Xmax, as I build my own speakers, I know the value. The disadvantage would be a flat sound when reaching the limit and a danger of blowing the voice coil if the driver RMS rating is below the Xmax Power rating value. Thanks A
Augusts
I used the RMS standart approach but noticed that when pushing the limiter really hard, the woofers blurp. So I shortened the attack time from a recomended 16ms to 5ms.
I dont like long attack times because that lets through power that is of an uncontrolled amplitude until the limiter sets in.
4D
if your consistently hitting the limiters on the system in order to get the coverage you need, then best practice is to "bring more boxes".
Edited by 4D - 28 January 2020 at 3:18pm |
fatfreddiescat
Your on the right track, take a look at this: and also the powersoft limter setting guide, that should answer your questions.
Augusts
yes, I would love that but at first I have to be humble.
Augusts
I meant to reply
Augusts
Even if I had more boxes, I would still have to limit them for times when someone got crazy with an eq for example.
The question is how to do it with a one level limiter to get out the maximum of the system and not damage the drivers.
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5176 |
The last thing you want is the Attack Level of a compressor to be increased for it will increase the Dynamics/Transients. You want the Attack Level set to minimum. The same thing applies to the Release. The Release will determine how long the compressor will maintain the compressed signal on the program material before reverting back to a non-compressed signal. So minimum settings of the Release will focus on preventing all means of Dynamics/Transients from escaping the compressed signal at all times. Minimum Settings: RMS Compression Maximum Settings: Peak Compression Minimum & Maximum Settings: Somewhere in between
You will have to drive your mixer to idiot levels, and configure the limiter from exceeding a certain amount of output voltage. Since I look at everything electrical based on volts and current only, the following is based from an electrician standpoint.
Pull out your
multimeter and set the dial to AC Volts and, attach the probes to
back of your LMS output channel.
Drive the mixer with music content to idiot levels into your LMS and measure the output voltage
Adjust the limiter on the LMS until the output voltage of the LMS does not exceed the input voltage of the amplifier with the input gains set to maximum. The manual of the amplifier will tell you what is the maximum input voltage required (with the input gains set to maximum) to achieve maximum output volts (watts).
Best Regards,
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2544 |
Not possible, you either risk damage with low crest factor material when using peak limiting or throw away a bunch of output with thermal/RMS limiting. If you are doing an event with a single known type of music you can adjust limiters to suite that event but if the system has to cover a wide range of music you are SOL. |
ceharden
Thanks(1)
My preferred limiter is a 4ft stage leg triggered by me seeing the red lights on the mixer...
ceharden
Thanks(1)
Forgot to say, for a faster attack time, stand closer!
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4949 |
the simple idea is to adjust the limiter so it acts purely to reduce gain without reducing the dynamics. IE fast attack and slow release (the release on an F/S PM80 for example could be set to around 20 seconds from memory). It's not rocket science. If the crest factor increases in limiting then it's set up as a compressor not a limiter.
A limiter should no more increase the power dissipated in the speakers than a big angry man with his fingers on your master fader who steadily pushes it down. If a DJ is determined to run the mixer up to the limit of its output voltage, then the limiter should be, by then, in such gain reduction with the high input levels that the amps are merely farting out a distorted noise at background levels, harming no one but the DJ's reputation. The longer the release time, the longer the crowd will be able to appreciate his incompetence and the less he'll want to risk it. Sometimes of course nothing short of a Sentry limiter tripping the amp contactors will convince a DJ to keep it in the green, but for live music one would hope the FOH engineer would be awake. Formula Sound really are the units for speaker protection but a good LMS with limiter is next best. Formula Sound |
North Staffordshire |
