Powering Bms 4590p |
goodgroove
Young Croc Joined: 21 December 2005 Status: Offline Points: 631 |
Posted: 30 January 2018 at 8:12pm |
Hi what would u consider the minimum wattage to power a bms 4590p using the passive bms filter, the total wattage of driver is 230w at 8r, remember running with passive filter.
Thanks |
goodgroove
I have been offered a qsc cx404 4 channel , class ab 250wpc at 8r, 400wpc at 4r is this suitable I know headroom is preffered ?
gen0me
Choose the amp here by hearing test dont care about wattage. Usually Qscs sound good. I would also search for Chevins. My A1004 sounded nice on 2" and ugly on 0.5"
You could disconnect crossover and make it active for 4 channels. It may not be as good idea thought. |
ceharden
The CX404 sounds very nice, I have one running my hi-fi bi-amped! However I normally reckon on about 4x RMS power for compression drivers because the crest factor tends to be so high on HF and you definitely don't ever want clipping on HF drivers.
Be a bit crazy but you could bridge the channel pairs to turn it into a 2 channel amp! CX702 or 902 would be better from that range.
Conanski
How much output do you need from these things? From the spec sheet they do 110db@1w with the passive xover so you'll get 130dB with only 100w which still leaves some headroom in the amp. I say set limiters so the amps cannot clip and run it.
knet94
Old Croc Joined: 31 March 2008 Location: NW London Status: Offline Points: 1509 |
Running them active without the crossover is definitely the best choice. |
