powering x6 18tbx100 |
Post Reply | Page 12> |
_Natty_
Young Croc Joined: 01 April 2007 Status: Offline Points: 663 |
Posted: 09 May 2022 at 12:42pm |
I know having 6 speakers and not a multiple of 2 is a crap...but here we are...
I have to powering x6 superscooper 18tbx100 rms 1200W. IT can handle 2400w in continuos. All speaker are 8ohm, many possible connection with lots of series/parallel conttector that i can use! I've varius options but id like to feed them with the best possible combo, my aviable amps are: 9001 crest x2 powersoft k10 ab class amp 3200w @8ohm bridge mode. having different ohm loading on the same speakers could be a problem? for example if im wiring them from different amps channlel... es 4 of them 4ohm loading and 2 of them 8ohm.
levyte357-
Do your venues have decent mains supply or UK 13a plugs?
Forget Crest 9001, if not decent supply in your venues. Would not suggest K10, have seen this amp, eat 4x drivers, when it clips. B&C cannot handle 2400w continuous, don't believe the hype. Powersoft K20, Void Infinite 8 MK2, MC2 E90, would power 6x of those quite easily. Don't buy cheap Chinese lightweights, will cost you more in the long run. QSC PL380, would also easily power 6x of these, I have 1x for sale. £1K
_Natty_
those amps are good but mine are from the list above and are the actual only possibility. so ive to arrange something with them. yes the venue have a 64A plug, so i guess nuff current. my 9001 is feeded by a 32A monophase plug i belive in b&c parameters actually ive pushed them for now almost 15 years with no complaint at all...arent f1 but is a good compromise. with a good kick and processing sounds proper to me. thanks
levyte357-
In a building with that supply, I would prefer the QSC PL380 to the 9001, for those 6x drivers.
The PL380 is completely different beast, on decent mains, so is the K20. |
csg
3 8ohm drivers per channel (2.6R) is ideal for many modern high power amplifiers. PL380 is a good, reasonably priced option however if you already have a K10 that too will power all 6 properly 3 per channel in parallel
Edited by csg - 09 May 2022 at 1:41pm |
levyte357-
I've never liked the sound of the K10. To me K20, sounds much better, not just the power, but more natural sounding bass notes. |
_Natty_
no QSC PL380 available at all, but i've instead x2 k10...less natural but still i have just those :D
csg
Sound quality is subjective, one man’s meat is another man’s poison.
The K10 will properly power those drivers. As to what sound quality is appropriate, well i know what i like but i am in no position to tell someone else what they should like.
_Natty_
so for you x1 k10 is enough thanks
The B&C 18 TBX 100 are approaching 20 years in production. Fourteen years ago, one 8-ohm B&C TBX 100 would burn-up it's voice coil on a single channel of a Powersoft K10. So, three B&C TBX 100 in parallel mode would be an ideal fit on a Powesoft K10. It won't be louder than the Crest 9001 however, if weight is the reasoning for moving towards a lighter weighing amplifier, the Powersoft K10 will be fine.
Best Regards,
_Natty_
thanks for the adivse and comment! what id like to understand is if for example having 4 scoop on a k10 and others 2 with another amp, from the list above(x2 k10, 9001 or ab not chinese amp)... id like to have a good powering, in venue nuff current aviable and the rack have more W to spent.... thanks to all |
knet94
Old Croc Joined: 31 March 2008 Location: NW London Status: Offline Points: 1510 |
Another couple of options to consider:-
Put 2 drivers per channel on 3 channels of the 2 K10s and keep a channel spare. Run 2 drivers per side on one K10 and 1 driver per side on the other. With careful limiting and gain control no reason this cannot work. Have done both these options many a time in the past.
