  New Posts New Posts RSS Feed - powersoft k10 no sound/dsp error
gimmebass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gimmebass Quote  Post ReplyReply Direct Link To This Post Topic: powersoft k10 no sound/dsp error
    Posted: 30 November 2025 at 6:48am
hello all,
i bought 2 broken k10's
1 had a the left channel that didn't work and a screen that was only lid.
switching the front panel solved the problem, channel was on mute.
contacts where heavely corroded en components where falling of.
that i cannot fix so thats being repaired by a professional.
now the next amp has everything working but started with a 'sharc error'
that was solved with armonia, after connecting the firmware was updated and the error was gone.
al the settings where set on factory settings.
my hands where itching to test my recently bought 13x mach ms118 cabs.\
so i hooked 8 of them to the amp, the bottom led's lid up after applying signal and bass came out.
then the bass stopped, whent back on for 3 min, then off.....take an other xlr cable to rule that out.
when the bass stopped the bottom leds where out, so no signal present, checkt the xta en yes it's giving signal.
took the amp inside for a closer look, discharged the capaciters en started checking.
after my experience with the first amp i checked the front panel for corrosion(ok).
took the amp board out and checked the link/stereo switch (ok).
checked the bandkabels(ok).took the dsp board out to clean the contacts but they looked in perfect condition.
put everythinh back together and hooked it back on my laptop,connecting was nog problem, all the basic settings and data was in real live and worked, dsp settings opend for a brief moment and then it flipt to (initalizing) en after a min it flipped over to a workspace that worked??opened somethin en that it when't back to (initializing connection)
i put in a xlr bluetooth audio device and when the dsp is working the bottom led's lid up.
they go out when it's(initializing connection)
i'm thinking powersuply, bad contact?something like that.
does this familiar to somebody??
16x mhb 46, mach slingshot ms1262
Elektro Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elektro Cat Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2025 at 12:06pm
Hello, there is an SMD resistor on the DSP board that is corroding after the conformal coating has dissolved after a few years.. I had the same problem with my k10 DSP, and replacing the resistor got the DSP working again.
The resistor is located directly to the right of TP2 on the top side.
Hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gimmebass Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2025 at 12:43pm
wow that one is easy to miss, just checked my board after cleaning with a brush.
indeed corroded, the one just under the red connector is also a bit corroded.
i will have them replaced! thank for your tip!! much apreciated!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote gimmebass Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2025 at 3:59pm
btw do you know the resistance of the component?in case its broken and can't be measured.
simonp1100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote simonp1100 Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2025 at 1:21pm
Hi,
I have the same problem.
The resistor in the middle of the capacitor and the connector is a 470R but cannot read or make out the other resistor (horizontal to the board edge) it reads 01 and sure the third digit is 0 (so 010) but cannot read the last digit and mine is also open circuit.
Does anyone know or has a board they could measure or a circuit diagram ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elektro Cat Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2025 at 1:24pm
One resistor is 470r and the other one is 01C/10k
Post Options Post Options   Thanks (0) Thanks(0)   Quote gimmebass Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2025 at 1:45pm
thnx guys! i will post my findings.there's not much information on the web.
this helps diy people a lot!
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2025 at 10:01pm
Hi I just put a new LCD on a k10 and still no letters on the screen . What did you do with the display board got a new one or ? Do you have any spare , it also seems some resistors are gone but I can't find no one to tackle that issue.
pic sorry on mobile not sure how to embed
Post Options Post Options   Thanks (0) Thanks(0)   Quote gimmebass Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2025 at 6:53am
Your problem lies with the resisters not the screen.
Mine is stil at the repair shop, so will get back to you when it's back.
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2025 at 8:53am
Yeah i found that out when i put in the new screen LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote gimmebass Quote  Post ReplyReply Direct Link To This Post Posted: 18 December 2025 at 6:52am
hi,
al the problems are solved, dsp works perfect and the screen of the other is also working.
cleaned both amps,  washed the filters and replaced the led's that where broken.
also took the powersuply connector out en made a permanent cable connection.
thanks all for the help!!!
dnbpc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnbpc Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2026 at 3:27pm
Do you have a link to the replacement screen you purchased? I have a k10 where the screen has a lot dead pixels but not been able to locate the replacement LCD screen part.
Pick & Mix Soundsystem
