powersoft K6 and scoops |
Post Reply | Page 12> |
astroroots
Registered User Joined: 09 January 2007 Status: Offline Points: 27 |
Posted: 13 January 2017 at 9:24pm |
hi,
Just wondering if a powersoft K6 can drive 4 scoops pd1852 loaded as they should be , considering the K6 is a limited K10 ? thanks for your advice |
jacethebase
K6's hardware is not the same as a K10, however the K8 is and that's a blinding amp.
www.stage2sound.com |
astroroots
hum , I think that K6 , 8 et 10 have the same hardware , isn't it ?
that's ok for 4 pd 1852 ? |
DJ123
Registered User Joined: 02 March 2010 Location: UK Status: Offline Points: 60 |
I seen K6 run 8 scoops sounding great played some heavy bass
ReubGold
Registered User Joined: 09 April 2012 Location: Essex/JA Status: Offline Points: 271 |
I have seen K10 blow 4x PD1851s in scoops, because it went into clipping.
So if K10 can't do it, K6 won't either. I guess different people have different idea of heavy bass. |
If he turns me into a zombie, first person I'm coming after is you.
fatfreddiescat
jacethebase
Or some people understand how to set a limiter. There is no other reason for blowing a driver other than malfunction or stupidity. |
jacethebase
K8 & K10 are the only two the same.
csg
K6,8 and 10 are identical hardware. Upgrade cards are available to take a K6 to a K8, then K10. If the K6 were different, this would not be possible.
K3 and K20 are different off course. I suspect you really want a K10 or preferably a K20 for this job.
MarjanM
You can only update K6 to K8. Not to K10.
PuppaBB
Registered User Joined: 09 January 2011 Location: Bilbao Status: Offline Points: 112 |
"Per Step-up card a K6 can be upgraded to become a K8" "Per Step-up card a K8 can be upgraded to become a K10 ". - But only sometimes...
www.facebook.com/PuppaFran www.facebook.com/CrucialRuler www.facebook.com/DUBFever
astroroots
thanks , I was aware about the upgrade , need 2 step up upgrade to a K6 to become a K10
so a K6 won't drive 4 scoops pd1852 properly , need to be upgrade to K10 ? regards |
