  New Posts New Posts RSS Feed - PPX failure
PPX failure
GAZ. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GAZ. Quote  Post ReplyReply Direct Link To This Post Topic: PPX failure
    Posted: 15 April 2018 at 9:47am
For the first time ever, had one of my PPX go down last night. 1600 on bass. Lost one channel, clip light constantly lit. Fearing the worst swapped a cable and ran both subs off the one channel. Carried on for about 30 seconds more then click! No more bass. Both clip lights lit. Could smell something was hot so had a look with a torch and saw the fan wasn’t working and realised it had overheated and cut out. Managed to get a desk fan, gaffa taped that round the front of the amp rack. Felt like the heat from a P3000 out the back! Left it for 5 minutes, switched it back on and away it went again! Carried on all night like that no problem! you can depend on your PPX that’s for sure!
100% Earth Moving Bass
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2018 at 2:53pm
Thermal switches! Also, while you've got the top off to fit the thermals, check the caps for bulging. Had a 1200 that did that and it kind of roasted them!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2018 at 4:04pm
Wow Gaz
just shows ya man , real amps lol
GAZ. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GAZ. Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2018 at 4:29pm
Yeah I’m expecting the thermal switches. Undecided about replacing them or just re wiring the fan to run constantly.
GAZ. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GAZ. Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2018 at 4:36pm
Definitely. I can’t see any of these modern amps still going in the future like a PPX does.
jammin75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jammin75 Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2018 at 5:09pm
shud carry an inuke 6000 put that in front of your amprack and that will keep it cool  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 20 April 2018 at 12:28pm
Probably best to wire the fan permantly on as it's a 1600 Gaz, you wont get the same problem again. Get really hot these 1600's. It wont do it any harm having the fan on continuely.
