PQM 13 is louder at 1300w than UKP2100x at 2100w?! |
Post Reply | Page <1234 6> |
cravings
do a quick refresher on logarithmic scale vs linear scale to understand one reason why a pot being half way up won't make it half the volume.. but there's more to it than that even.
charlysays
Registered User Joined: 16 June 2015 Location: Wales Status: Offline Points: 413 |
Oh my god... Is there no end to it 😂
I've not had any speaker issues in over a year doing it that way, so it must roughly cut the output in half! I'll do some reading |
cravings
there is absolutely no end to it...
Timebomb
As Cravings said, also doubling the voltage gives you 4 x the power (6dB), not 2 times.
charlysays
Oh dear... Good job I never tried to do that then! Whilst I'm reading should I order a couple of nl4 male speakons so I can make a couple of bridge cables? Would that be one way of doing it? The only thing I feel sure of now is that I know how to set the limiters to 0.775v, set a good gain structure and use the right hp and lp filters which must be why I've not come unstuck 🤔 |
cravings
get red or green nl4s so you'll always know which end of your bridged cables are for the amp. and don't ever use that colour speakon for anything else.
nickyburnell
I'm glad about this, because one thing that era of Matrix's are is LOUD
charlysays
I'm glad to hear that too nicky! Ukp2100x seems to be a cracking lightweight amp considering they can be had for less than 200 in good order.
I've ordered two red nl4 now. Been reading about the db scale, linear vs logarithmic and how it's really a ratio against a given reference. I'm still finding it confusing and it'll be a while before I do any of the formula on paper, but I can see how it'd be even worse if we just used linear scales. With regard to preventing excessive clean power blowing a speaker and how to limit that I can see why using a gain control on the amp is not precise at all. Would I be right in thinking that to reduce the output I should leave the limiter setting as it is (0.775v) but subtract db on the output band on the ultradrive? So to halve the volume I'd have that LMS output gain at -6, the limiter at -22 and then I can run the amp gain flat out but not exceed 50% of the power available from the amp? |
nickyburnell
Who has these for 200? Who got one? :)
charlysays
Thanks(1)
I got one for 220, the other for 180, both pretty much mint and only needing a quick clean internally ☺
You don't see them for sale much, I guess people hold onto them and I suppose if one went bang Robin would repair it reasonably. |
charlysays
Got them working properly today... bought a couple of NL4FX in red and wired the positive to 1+ and the negative to 2+ and the output is as I imagined it to be.... physically debilitating in my small lockup and not even flat out.
It doesn't make any difference to output having channel B at zero or on full- it's out of circuit in bridge mode. With regarding limiting output from the amps turning the gains down on the ultradrive works well. When I subtracted 6db from an output band it had a similar effect on volume as turning the amp gain down to half, so in future I'll run the gains flat out and attenuate with the ultradrive. Edited by charlysays - 03 September 2016 at 3:10pm |
cravings
good stuff.
yeah running amps fully open and using lms to control gain is the done thing. you can password lock your lms which will stop any random person turning things up more than you want. |
