  New Posts New Posts RSS Feed - Pre-amp & Mixer
Pre-amp & Mixer
Rich99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich99 Quote  Post ReplyReply Direct Link To This Post Topic: Pre-amp & Mixer
    Posted: 17 April 2020 at 4:05pm
Just wondering for those of you that have a 3/4/5 way pre, do you also use a DJ mixer and wire your sources into the mixer and then into the pre? I was advised that I'm missing a mixer as the cd's and decks would go straight into the pre-amp but surely there's no need or am I just being thick?
No, I really don't know what I'm doing...
Sinai Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sinai Sound Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2020 at 7:03pm
Depends on the mood!
With a sage I can wire in two line inputs, a turntable, a SPDIF input and a USB input
Pretty much the only time I used a DJ mixer is if I have a guest DJ who doesn't know how to use the Sage
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich99 Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2020 at 10:19pm
Thanks so much, glad I wasn't losing it! That makes sense.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sinai Sound Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2020 at 10:56pm
It's a cleaner signal path NOT having a DJ mixer as well
I did an 8 1/2 hours solo session in Poland from a single CDJ with 500GB USB SSD
This page was generated in 0.093 seconds.
