Preamps anno 2023... |
Post Reply | Page 12> |
Maze
Registered User Joined: 13 April 2014 Location: China Status: Offline Points: 179 |
Posted: 02 March 2023 at 8:55am |
Hi forum, What's a good preamp these days? Been looking to try one out, but I don't have access to trying one as I live in country with none. It doesn't have to be the best of the best, but good and fun to play on. Who has experience with Ras EFX? I like the look of his stuff. Other suggestions? Would a mini one be the way to go for home use and sessions when the chance is there? What are the drawbacks of mini preamps? Any advice welcome, thanks. |
vibes92
Registered User Joined: 25 January 2020 Location: united kingdom Status: Offline Points: 59 |
mostec
King Simeon
Young Croc Joined: 13 January 2007 Location: United Kingdom Status: Offline Points: 788 |
A pre amp I a tool to do a job, so ideally needs to suit what you need it for.
A traditional pre will likely blow your home speakers or slowly kill them. Mini pre may give more cost effective result as you won't need too many extra features. Have you considered the software options, can use a midi controller to give a hands on feel.
https://www.facebook.com/KingSimeonSound?ref=stream
https://soundcloud.com/king-simeon |
JamesH
Registered User Joined: 24 August 2022 Status: Offline Points: 60 |
AmpFreqq is killer software , I'd check that out for a start
dj jammin
Young Croc Joined: 10 April 2010 Location: southampton Status: Offline Points: 770 |
Go for a known builder such as Mostec or Jah Tubbys if you want a reliable preamp and any chance of selling later should you want to upgrade in the future..
Reverence Sound system
DamballaT
Registered User Joined: 05 December 2022 Location: Belgium Status: Offline Points: 11 |
We used a ras efx preamp for a good while, they're decent. Fairly neutral sounding preamp, build quality is good like all of his gear. Have since moved on to a mostec though.
For home use a mini preamp is probably the most logical, I personally use either a 3 way mostec or 90's 3 way Jah Tubbys at home and it's been more than fine.
Maze
Thanks all for the answers. I'll check out the AmpFreqq too. That looks like a great option for club gigs as well. King Simeon mentioned the signal from a preamp being too hot for home setups. Is this also an issue when you run it into a DSP? My current setup for outdoor events is 4xsubs + 4xTops +DSP and two amps. For a long time I thought that a preamp had to match the speaker boxes, so say a 4 way preamp would only match a 4 way speaker system. However, a friend said they run their preamp through a DSP. This is actually why I changed my mind about getting a preamp. The reason I want a preamp is to have the options of kill switches and other all the fun sound shaping features etc. A mini or AmpFreq might be the more sensible choice though, since most my gigs are in clubs and my own speakers are in storage most of the time.
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4539 |
Most preamps have a mix/full range output also so it doesnt have to be a 4way setup etc
Norseman
Registered User Joined: 04 March 2013 Location: Torquay Status: Offline Points: 124 |
hey mate
ii have the RAS EFX 5RU 4 way pre, its good, it doesn't add "tone" or "colour" beyond how you apply your EQ and so on, so in that regard its v transparent but the kills are super tight and it has a fullrange output also as well as the 4 way mono outs
Maze
Thanks for the info Norseman, the Ras EFX stays on my short list of options. I'm also looking into the Mostec, I think it will end up being one or the other.
Sypa
Young Croc Joined: 21 February 2013 Location: Croatia Status: Offline Points: 921 |
Klementz 1u stereo preamp is pretty good !
teeth
Young Croc Joined: 05 July 2021 Status: Offline Points: 566 |
i'm glad you made this topic because i can finally ask:
wtf does a preamp actually do in a contemporary sound system? what's the point? tone control?
