  New Posts New Posts RSS Feed - precision devices 154??
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Topic: precision devices 154??
    Posted: 05 October 2006 at 7:16am
i am making two HD15's. the recomended drivers are PD154's. should i use 8ohm or 16ohm? what is the difference. any sugestion of amp? (no other bins are being used)
al_x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote al_x Quote  Post ReplyReply Direct Link To This Post Posted: 05 October 2006 at 12:05pm
perhaps this should be in the 'newbie' section (remember for next time)
to answer your question, an 8ohm driver will be easier to drive from the amp because as the impedance of the driver increases, the amount of power it receives from the amp becomes less.
unless you have an amp which you want to use at 1200w/8ohm bridge and drive two 16ohm drivers in parallel, then i suggest you go for 8 ohm. drivers.
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 05 October 2006 at 9:45pm
Infact,Id call the 8ohm driver a harder load - more amperes required,more heating effect in the amplifier.
al_x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote al_x Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2006 at 5:21pm
no, i meant it will be easier to power 2 x 8 ohm drivers on your wallet....
not on the actual amp.
an amp powering 600wpc @ 8r will cost less than one powering 600wpc @ 16r...
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2006 at 8:19am
LOL I Get you
gingerbiscuit69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gingerbiscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 07 November 2006 at 6:15pm
just go 8ohm if its only 2!
al_x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote al_x Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2006 at 3:58pm
i would use 4ohm if i only had two bins. easier to power.
