Speaker wring/ re-wiring
Forum Name: Electro Frying Forum
Forum Description: Talk about drivers, processors and mixers
URL: https://forum.speakerplans.com/forum_posts.asp?TID=100670
Printed Date: 28 March 2024 at 3:00pm Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Speaker wring/ re-wiring
Posted By: Safetyman
Subject: Speaker wring/ re-wiring
Date Posted: 14 November 2017 at 4:19pm
So, my amps running @ 4 ohms are producing 800,1,200 & 1,600 watts per channel.... My speakers are rated @ 200/8r,400/8r,400/4r & 1,200/4r for the passives. I, usually, wire/re-wire speakers with 1.5 mm tri-rated wire , whether they be bass bins or top/mids. This cable is rated @ 21 amps for 600V AC/1000v DC, despite it's diminutive cross-sectional area. So, is this ok, or should I go for the 2.5mm tri rated version, at least for the bass bins( 1,200w ) please ?
------------- Protect your hearing, and feel the music.
MU South East Roving Safety Rep.
Date Posted: 15 November 2017 at 8:26pm
Decided to go with the 1.5mm tri rated cable, as all my cabs are quite small and the cable required would be no more than 1 metre in length for every single cable run.
Cheers
