35hz to 110hz cab
Forum Name: Feedback Forum
Forum Description: How Your Projects Perform
URL: https://forum.speakerplans.com/forum_posts.asp?TID=101143
Printed Date: 26 March 2026 at 8:27pm
Topic: 35hz to 110hz cab
Posted By: bcs
Subject: 35hz to 110hz cab
Date Posted: 20 January 2018 at 2:14pm
Hi guys. I don't know if what I'm asking make sense. The music I play requires me to have a bass cab from 34/35 Hz to 105/ 110hz. I've seen a lot of boxes that drops off sharply at 40hz and wouldn't meet my requirements. Wanting to keep the cabs as a single driver for portibality. I do have a reflex dual 12 and comp for mid high I'm building atm. Ideally want it to be two sub cabs and one mid high cab a side for max 200 peeps.
Thanks guys
Mike
Posted By: sn95
Date Posted: 20 January 2018 at 2:43pm
A 18 ported box will work or a tapped horn.
Posted By: osse
Date Posted: 20 January 2018 at 3:11pm
The keystone will fit your need very well. It sounds very good upto about 110. Two of them will totally slam any 200 capacity party
Posted By: sn95
Date Posted: 20 January 2018 at 4:40pm
Keystone or TH18.
Posted By: bcs
Date Posted: 21 January 2018 at 3:52am
Thank you guys for the feedback. I sincerely appreciate it. But the keystone cab is one ugly looking cab. Any other cab that's out there.
Mike
Posted By: bass*en*mass
Date Posted: 21 January 2018 at 7:39am
..put fullface grills+foam on them - job done..
Posted By: bcs
Date Posted: 21 January 2018 at 7:44am
So true bass*en*mass. After looking at several designs I am leaning towards the fane 200l cab. Old school reflex and I'm sure with a phat bass line. Any opinions on this cab?
Posted By: nickyburnell
Date Posted: 21 January 2018 at 8:04am
Yes this is the sensible answer. Stick a Fane Prime in there if you can
Posted By: bcs
Date Posted: 21 January 2018 at 8:10am
Thank you Nicky. Problem is I only have access to Faital and beyma 18p1000fe drivers. Will have to sim and adjust port size accordingly.
Mike
Date Posted: 21 January 2018 at 8:34am
sticking to a certain "design/plan" using mismatched drivers doesnt help a lot, i would prefer to sim available drivers in different cab layouts matching your goals.. ;)
Date Posted: 21 January 2018 at 9:24am
Just use the 200l design size. The way Fane do it is on its long side. Spin in 90 degrees and then it's taller and if you ever want to stack two (or build 4) the height is good for your tops. ALL you have to do then is sort your ports for said driver. That might even be 2 x 150mm or 3 x 100 using the best you can for port noise etc.
 Just done 4 x fane 15 125l from same design pages, my drivers were happy with cabs tall side up and two 100mm ports at bottom
Posted By: bcs
Date Posted: 21 January 2018 at 9:28am
Thanks Nicky. You're a star.. that look like a beyma 18lx60.
Date Posted: 21 January 2018 at 9:52am
P Audio JBL "copy"
Posted By: Elliot Thompson
Date Posted: 22 January 2018 at 11:36am
The majority of Beyma 18-inch drivers are aimed for Reflex. The Beyma 18 LX 60 are no longer in production. However, Beyma does offer the 18 LX 60v2 which, should give similar results to the Beyma 18 LX 60.
Best Regards,
