15" W Bin plans
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=101636
Printed Date: 27 March 2026 at 8:37am
Topic: 15" W Bin plans
Posted By: Jackalous
Subject: 15" W Bin plans
Date Posted: 08 April 2018 at 11:26pm
Hey everyone
Has anyone had any experience building this design?
https://boyzpc.home.xs4all.nl/Bouwtekeningen/18Sound/115%20Wbin.pdf" rel="nofollow - https://boyzpc.home.xs4all.nl/Bouwtekeningen/18Sound/115%20Wbin.pdf
I'm having some trouble working out the missing dimensions. It seems the distance of the trapezium (which holds the ports and driver) from the front and back of the cab are missing, but the design image clearly shows it is slightly set back.
Any ideas?
Date Posted: 08 April 2018 at 11:39pm
Dont thnk its the same tbh?
bit ive built these ones
deffo not the same ,sorry
Posted By: DMorison
Date Posted: 09 April 2018 at 12:57pm
Scaling from the other dimensions in the diagram gives 140mm from the inside back wall of the cab to the face of the driver baffle, FWIW.
That depends on the diagram being drawn exactly to scale though, so it could be off a little.
Can't be off by a big margin as you can see that it has the be greater then the 10cm depth of the rear centre wedge and less than the 16cm of the corner reflectors though.
Date Posted: 17 April 2018 at 6:28pm
What plans are these ones? And what is their usable frequency range?
Date Posted: 17 April 2018 at 8:36pm
EV Eliminator W-Bin
not sure about the freq range now, forget
Posted By: BJtheDJ
Date Posted: 17 April 2018 at 10:13pm
EV Eliminator W-Bin
Had 4 of them back in the 70s (before I switched to Mike Turner's stuff), ran them of H|H TPA100d amps using 1/4 inch jack plugs, damn they were loud.
Leaflet copy here http://medias.audiofanzine.com/files/notice-anglais-472670.pdf" rel="nofollow - http://medias.audiofanzine.com/files/notice-anglais-472670.pdf
Orange did a direct copy of the cab with an EV driver inside and sold heaps of them, called it the Orange Eliminator with a pair of (I think) Celestion horns mounted and bottom edit: two pairs of (I think) Celestion horns mounted top and bottom; saw The Emperor Rosco at Acton Town Hall with 16 of them on stage with him - only 4 of them plugged in; roadies told me that onlt 8 cabs actually had speaker sin Smile
I still have most of it left.
Posted By: KB109
Date Posted: 18 April 2018 at 7:33am
All the info you need is there. Gonna have to add a lot of figures up then subtract from the width.
Date Posted: 18 April 2018 at 9:55pm
wow thanks for that dj
i did look online , and couldnt not find it at all
nice find that, yes agree too ,tha are loud lol
Posted By: nickyburnell
Date Posted: 19 April 2018 at 7:22am
EV Eliminator W-Bin
So did Marshall.  Pair of Celestion horns with a metal waveguide (LOL) across the front of both. Chipboard. I had two with 100w drivers from Baker in Croydon. Loud things.
Posted By: APW
Date Posted: 19 April 2018 at 10:47am
I had a pair of 2nd hand Deltic w bins back in the 80s, they were made of chipboard and had casters mounted to the bottom 45° reflector in the horn, it wasn't uncommon for the chipboard to get damp, the chipboard to become powdery and weak resulting in the caster going straight threw the side of the cab. The cabs fell to bits in about 1989!!
After all these years it seems Deltec still make exactly the same cab, but now in birch ply and with a more modern driver.
http://myweb.tiscali.co.uk/deltec/bx40.html" rel="nofollow - http://myweb.tiscali.co.uk/deltec/bx40.html
Posted By: I-shen Soundboy
Date Posted: 19 April 2018 at 12:54pm
SPL: 99db
Pfft...  They're still using 1980s 1w/m measurements.
Time to dubiously inflate that to a more modern figure like everyone else?
