PD 186 V1 ported small sub plans?
Category: Plans
Forum Name: Ported Enclosures
Forum Description: Post all your reflex and bandpass and 'other' boxes with holes in stuff here...
URL: https://forum.speakerplans.com/forum_posts.asp?TID=102653
Printed Date: 26 March 2026 at 5:30pm
Topic: PD 186 V1 ported small sub plans?
Posted By: T-Bone
Subject: PD 186 V1 ported small sub plans?
Date Posted: 02 October 2018 at 5:45pm
Can anyone help me find a small ported reflex type sub plans for the PD186 V1? I am interested in using these for small to medium venues not more than 250 peeps indoor for playback DJ stuff. I already have tops 12/6/1" but cutoff is 60 hz I need 35 or 40 Hz to 70 Hz to cover the lower frequencies. I will need 2 subs built and since these are heavy woofers I need a smaller compact sub 24" cube. Will post pics on the build.
Thanks everyone!Tongue
BASS, how low can you go!
Posted By: djeddie
Date Posted: 02 October 2018 at 8:32pm
Download a copy of WinISD and have a go. Put the results up and you'll get help.
Posted By: vertx
Date Posted: 03 October 2018 at 9:25am
Half a GSub is probably a decent starting point
www.instagram.com/translate.sound
Posted By: levyte357-
Date Posted: 03 October 2018 at 11:54am
Old BC Sub 18 Plan.
First pair of 18" Subs I had, loaded with PD186, unmodified, scandalous sub notes.
https://www.toutlehautparleur.com/media/catalog/product/datasheet/bc/K-SUB18.pdf" rel="nofollow - https://www.toutlehautparleur.com/media/catalog/product/datasheet/bc/K-SUB18.pdf
CVA 18" Design, with PD1850s, Are much louder, cover more people, not as smooth though.
Posted By: T-Bone
Date Posted: 03 October 2018 at 9:35pm
Thanks guys for the reply apparently I read on another forum the PD 186 V1 has a high Qts compared from original published catalog numbers it has a Qts of .50 so horn cannot be used. i was going to sell these on eBay since these are brand new never mounted from 2009 shipped from a friend in UK. So I have 2 PD 186 I was going to use in F1 Infra Bass cab plans on the net. But I need more compact bass cab since i only have 2 of these for a smaller cab size maybe ported or reflex 22' x 22" x 22" for mobile DJ work and a 2 way top. Thanks
Posted By: JonB67
Date Posted: 04 October 2018 at 7:34am
No one's suggested you build a horn... of four suggestions 3 are bass reflex and the fourth suggests you learn winISD which isn't that hard and will let you build the box for your needs.
Date Posted: 04 October 2018 at 7:43am
PD186 V1 does not have qts of 0.50, or it would not work in some of the Scoops and Horns that it does.
People here have been using PD186 V1 for years, try taking some tried and tested advice.
Wink
Posted By: T-Bone
Date Posted: 04 October 2018 at 8:40am
Ok I will just use the Old B&C sub 18, its pretty compact.
