Void Stasys X V1 - Ferrite vs Neo.
Forum Name: Advanced Discussion
Forum Description: Advanced discussion area for higher lifeforms
URL: https://forum.speakerplans.com/forum_posts.asp?TID=102702
Printed Date: 27 March 2026 at 12:52am
Topic: Void Stasys X V1 - Ferrite vs Neo.
Posted By: Shadrack
Subject: Void Stasys X V1 - Ferrite vs Neo.
Date Posted: 11 October 2018 at 7:47pm
Hello there.
 I currently have 6 Void Stasys X V1s.
 4 cabs have the Wooden ports on them, Loaded with the Void v-1400 Neo
The 2 other cabs have the Plastic Ports and loaded with Void v-1400 Ferrites.
When I play all 6 together, its no way near as loud as when I play the 4 neos on there own. I put it down to phasing problems if im correct? due to there being two different drivers and maybe difference in the two cabs designs ?
Im looking at buying 4 void news to re-load into the ferrite pair. I got told the cabs are same design and this would be fine.
can anyone shed some light?
Thanks !
Posted By: I-shen Soundboy
Date Posted: 11 October 2018 at 9:07pm
Wild shot in the dark here: Could the wiring phase polarity in the ferrite cabinets perhaps be the reverse of the neo ones?
Posted By: Guests
Date Posted: 11 October 2018 at 10:59pm
Wrong polarity
Posted By: Father-Francis
Date Posted: 12 October 2018 at 12:15am
drivers shouldn't give you that kind problem , i know cause we are runinng magnets in same kind of cabs with no sound problem just weight difference , cross check all cables in and outside the boxes
Posted By: Speaker Sol
Date Posted: 12 October 2018 at 12:55am
Yep i ran mix of ferrite and neo Stasys x for years. No problem.
Something else is going on.
Posted By: Noizyboysoundz
Date Posted: 20 May 2019 at 5:52pm
have you sold the v18-1400 ferrite drivers, and if not could I get a pair, just wondering
Date Posted: 20 May 2019 at 7:00pm
Never saw this thread at the time, but the cabinet with different drivers absolutely has different magnitude and phase response, so it will not play the same as using all of the same type in one stack.
Date Posted: 22 May 2019 at 9:55am
With all due respect, I think you are over stating the effect.
Yes of course, the use of different drivers will have slight differences in phase and magnitude.
But these differences are small and won't course the type of effect that is being stated (a large drop in output).
I know from experience and measurements, that the ferrite and neo drivers will sum just fine without any major issues with the response.
Maybe the issue lies with older cabs with the 'plastic' ports?
However I once used a pair of these along side 4 'standard' Stasys X, I didn't notice any issues at the time, but it was a long time ago...
I still feel that something else is wrong with the ops setup.
Date Posted: 22 May 2019 at 9:56am
'With all due respect' <- Just to be clear, I meant that sincerely.
Posted By: marv203
Date Posted: 29 January 2025 at 11:29am
Hi,
I am working on a preset for Void Stasys X v1 Neo version. I use:
Hi Pass : 30 Hz - 24 dB/oct But
Lo pass : 120  Hz - 48 dB/oct LR
but I am not sure for the limiters. The powersoft calculator say following:
RMS voltage 74 V
Attack Range 2-4 seconds
Release Time 4-8 seconds
Peak Voltage 169 V
Attack Time Range 16-32ms
Release Time 128-384 ms
Clipping voltage 222
What are you using, because I am not quite sure if this fits for those subs?
Posted By: smitske96
Date Posted: 29 January 2025 at 7:24pm
How did you conclude those settings are not accurate?
Posted By: marv203
Date Posted: 29 January 2025 at 9:34pm
I didn't choose the right expression. My question is rather whether this is suitable for the subs or would you set other limiters?
