15 inch bass horn for 40-200Hz
Category: Plans
Forum Name: Plan Requests
Forum Description: All plan requests here
URL: https://forum.speakerplans.com/forum_posts.asp?TID=102913
Printed Date: 27 March 2026 at 10:58am
Topic: 15 inch bass horn for 40-200Hz
Posted By: MrScy
Subject: 15 inch bass horn for 40-200Hz
Date Posted: 24 November 2018 at 3:14pm
Hi all,
I am looking for a plan of a 15" bass horn that play 40/50Hz-200Hz and it should be efficient.
Size is not an issue but I would consider something that is not very large and not very difficult to construct.
Was there ever a 15" version of the invader bin?
montek.co.za
Posted By: Jo bg
Date Posted: 24 November 2018 at 4:47pm
Horn loaded, small, easy to build and down to 40 Hz is not possible.
Horns need to be big and long to load down to 40 Hz,, and need to be bent if you don t want a 3 meter long box, so difficult to build.
Small, wide frequency range and easy to build means just reflex.
Modern drivers and amplifiers will give you great powerhandling with little weight, this should overcome the lost efficiency to an extent
Posted By: Meat
Date Posted: 25 November 2018 at 5:49pm
I don't think you'll find anything that'll do up to 200 and down to 40 although if you get a big enough pile of Martin 215 mkIII (6 or 8 of them) you should have an extremely high impact system which should do pretty much do that. Maybe more like 40-150. Can't remember what James F said his settings were.
http://hornplans.free.fr/martin_mk3.html" rel="nofollow - http://hornplans.free.fr/martin_mk3.html
