Amp to run 4 x 18TLW3000 8/4 Ohms!!!
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=103000
Printed Date: 24 April 2024 at 9:17am Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Amp to run 4 x 18TLW3000 8/4 Ohms!!!
Posted By: tehnicar007
Subject: Amp to run 4 x 18TLW3000 8/4 Ohms!!!
Date Posted: 16 December 2018 at 11:11am
Hi guys ! What Amp you recommend to run 4 x 18TLW3000 8/4 Ohms!!!
Ciaaao
Posted By: bob4
Date Posted: 16 December 2018 at 1:01pm
Two crest pro 10001
Posted By: U.Viktor
Date Posted: 16 December 2018 at 2:27pm
PKN XE10000 (2 * 5000W+ @4R) is a very cost effective solution to drive two of 8R/2500W speakers per side.
If you want even more headroom H8-18002U (2* 10000W @2R) would be the best ever but that is expensive and not so common yet.
Posted By: Earplug
Date Posted: 16 December 2018 at 6:21pm
bob4 wrote:
Two crest pro 10001 |
And a forklift!
------------- Earplugs Are For Wimps!
Date Posted: 16 December 2018 at 9:49pm
deffo 10001 would be my choice too
no worries bout weight aslong them on castors , all good :-)
------------- Musical Roots Reggae Vibration is Life! for music is sound...sound is vibration...vibration is energy... and energy begets life. Therein lies my passion!...MUSIC IS LIFE...
Date Posted: 16 December 2018 at 9:50pm
And ovisly no stairs lol
Posted By: paulus
Date Posted: 17 December 2018 at 10:46am
i find it odd people moan about amp weight when wanting to run 4 or 8 cabs that weight 100kg each ?? obvz I expect it on big touring applications where they need minimum rack space and maximum output but not on smaller things
------------- TRENDSETTER SOUND SYSTEM
Posted By: U.Viktor
Date Posted: 17 December 2018 at 11:50am
The general misconception is that everybody thinks that the amp will drive a resistive load (all amps parameters stated by resisitive load) however the speakers are reactive. It means that the output current are usually OUT of phase with the coil driving Voltage! Why it so important? Most(if not ALL) analog amplifiers have a type of output stage which NOT allows to sink or source large current when the output devices see large momentary Voltage drop, especially when the output Voltage nears Zero but the load current still large.. Big big surprise than pretty large analog amplifier could be forced entering to output power dissipation protection of its power devices to prevent momentary overheating of junction layers if the current shift is unfortunate angle.. Here comes the advantage of modern switching amplifiers: with proper construction a good switching amp can deliver its max. output current at ANY output Voltage :-) So while a large analog amp loosing control movement of Volice coils due activated momentary output dissipation (UxI) protection, maybe even a smaller switching amp could work better.
Posted By: mini-mad
Date Posted: 17 December 2018 at 11:59am
...surely that's a topology problem... not a PSU problem.
------------- If it sounds like a gorilla is trying to escape, turn it down.
Posted By: wilidapili
Date Posted: 17 December 2018 at 1:58pm
I’m also interested in how powerful of an amp is recommended for 2x TLW3000
Posted By: U.Viktor
Date Posted: 17 December 2018 at 2:40pm
efinque wrote:
mini-mad wrote:
...surely that's a topology problem... not a PSU problem. |
I read class AB amps have the best efficiency. However, a linear PSU will dissipate heat much more effectively than a SMPS, although switchmodes are generally working at 70-80% while a typical linear PSU is somewhere around 50-60%.. they weight a lot more, whereas with a switchmode you get switching noise, which, depending on the quality may or may not be audible.
EDIT : people have been succesfully using SMPS' in effect pedals etc due to their size, and I've seen some amps using them too.. maybe for small speakers they could be ok, but for heavy duty stuff like driving subs I wouldn't put my money on one.
No. Class AB amp shave almost the worst conversion efficiency ~ 50-60% maximum. Also plagued by the problem I have mentioned above^.
Class-D ( high frequency switching ) amps could have efficiency above 85% while very few reaches ~ 95% or more.
Linear (50/60HZ transformer) and poor switching power supplies without PFC are equally bad due their mains current distortion originated from 'peak rectification', which end sometimes as bad as they consumes 5X or 10X of the output power. For example a 1000W SMPS(without PFC) or toroidal transformer would needs 4.3A average (6.2A peak) from the mains if the power factor would be correct (1.0) but unfortunately - due peak rectification - usually pulls out 50 or 100A peaks with very narrow conducting angle which is bad for the mains, generators and could create dangerous over Voltage spikes on the opposite phases. Learn and understand why good power factor are so important.
Posted By: smitske96
Date Posted: 17 December 2018 at 3:05pm
efinque wrote:
I meant in the analog domain.. a quality class D amp will cost around 2-3 times more than a class AB.
What do you mean with this?
Posted By: valve head777
Date Posted: 17 December 2018 at 6:00pm
smitske96 wrote:
What do you mean with this? |
Waiting for the edit 😉
------------- Freedom of choice, choice of freedom.
Posted By: Jo bg
Date Posted: 17 December 2018 at 6:52pm
I GOT IT ! Efinque is somehow writing from the 80s!
Posted By: U.Viktor
Date Posted: 17 December 2018 at 8:01pm
It is not about the weight, it is all about the sound. Normally a good and efficient modern technology switching amplifier can be realized in just a fraction of size and weight of a linear amp. Those Crown XLS is a joke, just like some 99% of the switching amps. There are just very few really good products on the market and tons of scrap. I can count them on a single hand of mine!
Date Posted: 17 December 2018 at 8:32pm
I’m curious to know these ones you can count with a single hand!
Posted By: imageoven
Date Posted: 17 December 2018 at 9:06pm
efinque wrote:
it's hard to tell whether it was AC or DC
I think you need some more test gear.
------------- Keep pushing on, things are gonna get better.
Posted By: Earplug
Date Posted: 17 December 2018 at 9:26pm
Yes - agree that the Crown are bad - but even some fairly expensive Class D have their issues, eg:
https://www.abeltronics.co.uk/amptesting.php?z=Funktion-One_F60Q_-_FFA6004" rel="nofollow - https://www.abeltronics.co.uk/amptesting.php?z=Funktion-One_F60Q_-_FFA6004
Give me a decent Class H any day!
Posted By: king david
Date Posted: 17 December 2018 at 9:41pm
i have FFA 6004 since 2011 and been very happy with its sound quality and reliability, 8 years, no issues with the amp, no burned speakers...
------------- http://www.warriorcharge.noblogs.org
Posted By: Elliot Thompson
Date Posted: 18 December 2018 at 1:05pm
Ciaaao |
Powersoft K20
When you start to focus on drivers that require 3600 watts program power, you are placing yourself with very limited options in terms of amplifiers.
Best Regards,
------------- Elliot Thompson
Posted By: Father-Francis
Date Posted: 18 December 2018 at 1:16pm
Don't forget FFA10000
------------- Music is the strongest form of magic.(+45 31879997)blakmanpro@gmail.com, foa@sweetboxaudio.dk
Date Posted: 18 December 2018 at 1:26pm
Father-Francis wrote:
Don't forget FFA10000 |
I always liked the sound of FFA. I would imagine the lack of popularity on Speakerplans is due to not having an on-board DSP.
Best Regards,
Date Posted: 18 December 2018 at 1:52pm
Best Regards,
i like them too , I'l be heading over to visit Dave after the holidays , i got three powersoft racks now i need an FFA rack , Dsp or no dsp sometimes we should just think of the sound we provide
Posted By: concept-10
Date Posted: 18 December 2018 at 2:07pm
As there are thousands of inukes and old toroid amps being driven to with an inch of their lives every weekend why are we not seeing the problems you harp on about in every thread? Seriously if the world is going to end when using one then why has it not ended?
Posted By: mini-mad
Date Posted: 18 December 2018 at 3:13pm
As there are thousands of inukes and old toroid amps being driven to with an inch of their lives every weekend why are we not seeing the problems you harp on about in every thread? Seriously if the world is going to end when using one then why has it not ended? |
Never expected both ends of the spectrum when I made that comment
..you want to solve this problem then I suggest redesigning the power transistor!
Efinque. You many want to look that up again AB are awful when it comes to eff%
Vicktor. Stop scare mongering... distortion on the current entering the PSU being a problem? I suggest building your own power station. And current being out of phase on ANY type of AC circuit it just one of those thing inherent in the system. It won't trigger an apocalypse. Less caffeine mate and try to get out in the sun a bit more.
I love SP. You guys remind me I could be a lot (mentally) worse off...
Date Posted: 18 December 2018 at 3:28pm
lol , Mini-Mad you are just alittle mad
Posted By: mini-mad
Date Posted: 18 December 2018 at 3:59pm
lol , Mini-Mad you are just alittle mad |
Agreed... but my wife does her best to keep me inline. I'm not sure I'm cut out for the 21st century. To much nonsense everywhere forced on you on a daily basis.
So.......... back on topic.
...sorry
Posted By: Battered
Date Posted: 18 December 2018 at 4:03pm
mini-mad kind of reminds me of the midget fortune teller that escaped from prison............
Small medium at large!!
Yeah, I don’t know what that means either, but it has been a **** of a few weeks and my brain is fried. And now I’m going to sleep to forget all about working with w***ers!!
------------- Touching cloth at 200 mph
Date Posted: 18 December 2018 at 4:25pm
I know that feeling, if I get to the point of feeling a bit mental I spend half an hour on Facebook then realise life could be a lot worse.
Date Posted: 18 December 2018 at 5:00pm
Best Regards,
Dave has world class DSP in his amps for a few years now
I'm all about headroom but if you get a huge amp, even on a driver with this high AES rating, and you don't limit it and filter it properly then be prepared to smoke some coils. For that reason, if you don't have a SERIOUS DSP and know how to use it, you'd be better off with K10, or K20 with DSP, or a Linea 44M20, or XTA APA4E8 plus paying someone to actually measure your driver in cabinet to calculate the long term RMS rating in volts and the heating threshold of the coil.
Date Posted: 18 December 2018 at 5:54pm
ppl being running crowns, crest hh , c-audio ect ect for donkeys years flat out , even me on 8/12 hours sessions no problem
tha keep chuggling along nicely lol, yes do understand not as powerfull for nowadays drivers , but still
comments concept lol cracking up
Date Posted: 18 December 2018 at 6:06pm
Best Regards,
I'm all about headroom but if you get a huge amp, even on a driver with this high AES rating, and you don't limit it and filter it properly then be prepared to smoke some coils. For that reason, if you don't have a SERIOUS DSP and know how to use it, you'd be better off with K10, or K20 with DSP, or a Linea 44M20, or XTA APA4E8 plus paying someone to actually measure your driver in cabinet to calculate the long term RMS rating in volts and the heating threshold of the coil. |
we got XTA's in the racks bro , not all powersoft amps have dsp , will be sending them for upgrading , got a good price for that .
Date Posted: 18 December 2018 at 6:20pm
[QUOTE=Dub Specialist Sound]ppl being running crowns, crest hh , c-audio ect ect for donkeys years flat out , even me on 8/12 hours sessions no problem
comments concept lol cracking up[/QUOTE
Welcome dude
Date Posted: 18 December 2018 at 6:29pm
Best Regards,
From the pre-dsp days, many of us would train our ears to
detect any issues taking place throughout the event. Although, Aphex Dominator
was common in those times, many still gauged the levels based on common sense. I
would imagine this is why I over power all my speakers.
One of the biggest issues I’ve seen are those trying to
cover a venue that requires 8 – 16 bins and expect to get the same output as 8 –
16 bins using 4 boxes. No amount DSP protection is going to prevent loudspeaker
failure if the user is reckless.
Sophisticated DSP protection is very helpful however, should
never be looked upon as “My DSP is protecting everything so I can raise the
fader higher.” Continuous average levels that offer a minimum Average to Peak
Ratio can damage a loudspeaker with an unclipped signal just as fast as and
amplifier being clipped to the point the clip light remains on like a light
bulb.
If someone is investing in four Eighteen Sound 18 TLW 3000
speakers, they are supposed to be familiar with every means of precautionary
methods to prevent any loss in their investment.
Best Regards,
Date Posted: 09 May 2019 at 5:42pm
We are now running 4x 18TLW3000 drivers on a Powersoft X4. One bridged channel for one double 18" cabinet. When we build two more subs, we will be running 8x 18TLW3000 on the X4, this time unbridged channels. Not optimal regarding headroom, though. We have our eyes on the X4L in the distant future, but we'll build some more cabs first. Maybe we should look into some other type of cabinets for efficiency, let's see.
