21 inch compatible driver list
Category: Plans
Forum Name: Scoops
Forum Description: One scoop or two ;-)
URL: https://forum.speakerplans.com/forum_posts.asp?TID=103015
Printed Date: 23 April 2024 at 10:39pm Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: 21 inch compatible driver list
Posted By: RealitySound
Subject: 21 inch compatible driver list
Date Posted: 20 December 2018 at 1:13am
Slowly compiling a list of 21 inch drivers (now that they are becoming alot more common) Thought I would share as I add to it.....
------------- When you gonna send me some $$ mate ?
Posted By: gen0me
Date Posted: 20 December 2018 at 1:33am
Xmaxes are written in different standards.
------------- I appreciate every like :)) https//www.facebook.com/genomesoundsystems Mixes: https://www.mixcloud.com/gen-ome/
Posted By: mini-mad
Date Posted: 20 December 2018 at 1:43am
gen0me wrote:
Xmaxes are written in different standards. |
....there's always one!
He's listing manufacturer quote TS para's. Let's not argue the toss ah
------------- If it sounds like a gorilla is trying to escape, turn it down.
Date Posted: 20 December 2018 at 1:47am
+/- mm inna?
Posted By: Marvin
Date Posted: 20 December 2018 at 3:36am
I will update you with the RMJ 21" Turbomax available
Date Posted: 20 December 2018 at 10:03am
Well yes actually, let’s - because if you try and sim them like this you’ll get incorrect results. It’s not exactly difficult to adjust so they’re using the same standard. Why post data if it isn’t useful?
Posted By: mini-mad
Date Posted: 20 December 2018 at 12:56pm
toastyghost wrote:
He's listing manufacturer quote TS para's. Let's not argue the toss ah | Well yes actually, let’s - because if you try and sim them like this you’ll get incorrect results. It’s not exactly difficult to adjust so they’re using the same standard. Why post data if it isn’t useful? |
I don't know... to upset people who just like to winge?
If you don't like them, don't read them. Trying to be offended by printed numbers seems a little extreme...
Date Posted: 20 December 2018 at 12:58pm
which ones?
Date Posted: 20 December 2018 at 1:23pm
If you don't like them, don't read them. Trying to be offended by printed numbers seems a little extreme... |
Eh? Nobody is offended. We’re just pointing out a relatively minor mistake and how it can be rectified in the name of helping people out with their research.
Why are you so defensive? If you don’t like our comments perhaps don’t read them? That ridiculous statement cuts both ways.
@RealitySound: B&C use a different method, see https://www.bcspeakers.com/resources/faq-frequently-asked-questions/" rel="nofollow - https://www.bcspeakers.com/resources/faq-frequently-asked-questions/
This is true if you compare by given Xmax. But again B&C is using a more positive formula for the Xmax then Eminence (or 18Sound) does.
B&C Xmax = (Hvc – Hg)/2 + unknown variable
18Sound = (Hvc - Hg)/2 + Hg/4
Eminence Xmax = (Hvc - Hg)/2
So as long you want to compare the B&C in a 'fair' theoretical competition you need to know it’s unknown variable… For example, you can compare the Eminence 3015LF to any RCF or 18Sound if you correct its Xmax to RCF/18Sound standards.
Xmax 3015LF (Hvc - Hg)/2 = 9,6mm
Xmax of the 3015LF by RCF/18Sound Standards= (Hvc - Hg)/2 + Hg/4 = 10,8mm |
https://www.diyaudio.com/forums/subwoofers/127908-jbells-set-tapped-horns-45.html
Posted By: MarjanM
Date Posted: 20 December 2018 at 1:44pm
We can agrue about whos formula is corerct tho. The (Hvc - Hg)/2 one is technically most correct, but in reality the movement goes way beyond that point because of the inertion of the mass. The (Hvc - Hg)/2 point is where the VC starts leaving the gap, but no cone suspension/magnet force is able to simply stop the vc at that precise point. Some do it betetr, some worse, but at all of them the excursion simply dont stop there.
------------- Marjan Milosevic MM-Acoustics www.mm-acoustics.com https://www.facebook.com/pages/MM-Acoustics/608901282527713
Posted By: levyte357-
Date Posted: 20 December 2018 at 2:08pm
I see one driver in this list with a qes of 0.39, another with a qts of 0.37.
Either of which, tells me, this list is not actually based on Scoop design experience, or research.
------------- Global Depopulation - Alive and Killing.
Date Posted: 20 December 2018 at 2:09pm
Merely putting up T/S info found on their own sites as I shop around myself
Posted By: MarjanM
Date Posted: 20 December 2018 at 2:25pm
Add RCF LF21N551 to the list.
Date Posted: 20 December 2018 at 2:28pm
RealitySound wrote:
Merely putting up T/S info found on their own sites as I shop around myself |
Well then maybe the list should be renamed,
"Random list of T/S parms, for 21" drivers I found in the Shops".
Date Posted: 20 December 2018 at 2:35pm
Suddenly re-minded why I don't post sh1t on here anymore
Date Posted: 20 December 2018 at 2:39pm
Date Posted: 20 December 2018 at 2:42pm
Forgot I had to pay off Lev before posting in his scoop forum
Posted By: cravings
Date Posted: 20 December 2018 at 2:46pm
don't mind him, man. do your thing.
Date Posted: 20 December 2018 at 3:24pm
MarjanM wrote:
We can agrue about whos formula is corerct tho.The (Hvc - Hg)/2 one is technically most correct, but in reality the movement goes way beyond that point because of the inertion of the mass. The (Hvc - Hg)/2 point is where the VC starts leaving the gap, but no cone suspension/magnet force is able to simply stop the vc at that precise point. Some do it betetr, some worse, but at all of them the excursion simply dont stop there.
That’s why I posted the link to B&C FAQ explaining why they do it their way as well
Posted By: corell
Date Posted: 20 December 2018 at 5:17pm
Hey reality sound, nice idea, will add to that later. Suggestions: replace BL with BL/Re² to really be able to compare motor force between differenet nominal impedance drivers replace VAS with Cms for the same purpose (getting Sd out of the equation) State xmax as (Hvc-Hg)/2 as this is the only data every brand states add VC diameter and magnet type delete sensitivity as this only applies to the octave above EBP, so of no use for bass speakers. Maybe add EBP instead.
Posted By: mini-mad
Date Posted: 20 December 2018 at 8:10pm
Grow up fella. It's a forum...
Guy puts up a list of drivers with TS so people don't need to hunt and gets linched for just being a nice guy!
...anymore for the "victim parade"?
Or we gonna turn a nice gesture into 20pages of bulls##t like we normally do in the name of the #metoo 'I'm right' brigade
Posted By: gen0me
Date Posted: 20 December 2018 at 9:50pm
I wouldnt be on this forum if I had to read only marketing bullshit instead of pure facts.
MarjanM wrote:
Add RCF LF21N551 to the list. |
Omfg!!!! 18mm top plate thickness, 39mm winding heigh!!!! Thats something new. Real 15 mm acording to (hvc-hg)/2 + hg/4. This Paudio looks impressive too. I dont believe in Xmax without giving hg and hvc by manufacturer.
Posted By: mini-mad
Date Posted: 20 December 2018 at 10:19pm
Again still tied up on "who's right" the guy made a nice gesture and then gets water boarded for doing so...
Rather then "can I add to the list and have this param and that param" he got "THOSE ARE RIGHT ACCORDING TO WHOS MATHS??"
You lot need to lighten up!
Nearly every thread lately has been pages and pages of ALMOST nothing useful, jus the #metoo parade jumping on the band wagon of "how can I look intelligent AND take the piss out of somebody at the same time whilst not being very helpful...."
Posted By: MarjanM
Date Posted: 20 December 2018 at 10:38pm
Omfg!!!! 18mm top plate thickness, 39mm winding heigh!!!! Thats something new. Real 15 mm acording to (hvc-hg)/2 + hg/4. This Paudio looks impressive too. I dont believe in Xmax without giving hg and hvc by manufacturer. |
Its a beast. Working on a box for it.
Posted By: JonB67
Date Posted: 20 December 2018 at 11:15pm
RealitySound wrote:
Suddenly re-minded why I don't post sh1t on here anymore |
Please dont let it get to you. I for one and I'm sure many others quietly read through the list with interest and appreciated your effort.
While i understand the idea of a regularised list, anyone wanting a resource now has a list of manufacturers spec in one placr to start from, which is all they'll get if they go hunting the manufacturers websites.
Date Posted: 22 December 2018 at 1:32am
Thank you. I had all this info on my desktop as I was searching around the net comparing drivers. Wasn't expecting such a backlash for sharing on the forum.....lordy lordy
Posted By: Father-Francis
Date Posted: 22 December 2018 at 1:45am
jo boss some chicks learn to fly ,and want to fly to the sun , some become birds that fly in groups , we are like animals , not all of us think the same bro , chill man , just make your list ,we'l chip in or just read ,
------------- Music is the strongest form of magic.(+45 31879997)blakmanpro@gmail.com, foa@sweetboxaudio.dk
Date Posted: 22 December 2018 at 2:37am
Father-Francis wrote:
jo boss some chicks learn to fly ,and want to fly to the sun , some become birds that fly in groups , we are like animals , not all of us think the same bro , chill man , just make your list ,we'l chip in or just read , |
Yes I
Date Posted: 22 December 2018 at 8:54am
LAVOCE SAN214.50 1700 98.5 39 30 .28 .26 226 15.5 I've been looking at this guy for awhile now looking to make a ported bin tuned at around 20hz but the B&C is much better in the sim , need to get one them to test .
Date Posted: 22 December 2018 at 3:54pm
LAVOCESAN214.50 1700 98.5 39 30 .28 .26 226 15.5 I've been looking at this guy for awhile now looking to make a ported bin tuned at around 20hz but the B&C is much better in the sim , need to get one them to test . |
I was tempted to get a couple to play with by the price alone. $450 vs $600-$710 for the B&C's I dunno the price differences by you....
Date Posted: 22 December 2018 at 5:01pm
524euros This is the highest I’ve seen so far most are sell at around 499, but am sure I could get for 350euros ,simmed in a cab that’s 72*61.6*80, got 22hz it’s a ported Br , still have to work on Simms, cause my kicks are 636 so need to move some figures around, so my kicks fit flash on top , they are cheaper than most of the others.will pm you when I get there Boss
Date Posted: 22 December 2018 at 8:02pm
https://ibb.co/QmxQprR" rel="nofollow">
Posted By: sajti
Date Posted: 22 December 2018 at 8:48pm
And what about Beyma 21LEX1600Nd?
Sajti
Posted By: Miles
Date Posted: 23 December 2018 at 1:24pm
efinque wrote:
I dislike 21" drivers for some reason though. |
nothing beats a 12 inch scoop
Posted By: Tonskulus
Date Posted: 23 December 2018 at 9:36pm
lots of talk about xmax.. there are also different behaviours as soon as xmax is exceeded. Some drivers sounds horrible immediately after that, some others can be pushed even further without too much problems like cone flapping/farting etc.That's why some real world comparsion / tests should be high in priority when comparing different drivers to each other.
Date Posted: 24 December 2018 at 2:04am
I have only ever heard cheapy Techincal Pro 21 (they were $125, had to try em...) 18sound 21LW1400 which are ok for the price. They were great till I put some REAL power into them, then they were TOAST. (stonelove few years ago- red-lining signal no doubt) 18sound21-9601- beast of a driver. Haven't blown one yet! Had 5 out for Mighty Crown last year (guys still talking about it) Had all 8 out for StoneLove summer gone. Not entirely impressed with them in my scoops though, even with 2k+ into each driver. They are now in Marjan's single reflex 21's running off a chinese LAB 20000K. Something serious. However winter time is upon us, very small window of time I have to build. Toying around with the idea of 21" folded horns (similar to Tony's) or some 21 hybrid hog like cab.
Date Posted: 12 September 2019 at 12:22am
http://usspeaker.com/Eminence%20NSW6021-6-1.htm?fbclid=IwAR3KQvTit1dPbIKUjQiV-R-qXTqGvjxxv5E0lEPHeIEFDO7458U3B2-f4XA" rel="nofollow - http://usspeaker.com/Eminence%20NSW6021-6-1.htm?fbclid=IwAR3KQvTit1dPbIKUjQiV-R-qXTqGvjxxv5E0lEPHeIEFDO7458U3B2-f4XA
NEW TOY
Date Posted: 12 September 2019 at 4:27am
NEW TOY |
It’s a very, very good driver.
Posted By: Sypa
Date Posted: 12 September 2019 at 11:11am
Anyone in Europe selling these?
Curious about the price.
Posted By: snowflake
Date Posted: 24 October 2019 at 11:41am
the NSW6021-6 looks like it beats the RCF LF21N551 in a ported enclosure. If it is doesn't cost much more in Europe - I can't see anyone with stock
nb calculating xmax for the eminence driver from spec sheet data gives 19.4mm xmax (((Hvc-Hg)/2)+(Hg/4))
Date Posted: 24 October 2019 at 2:57pm
Blue Aran are your guys for Eminence here.
Date Posted: 24 October 2019 at 5:40pm
"We're expecting Eminence's NSW6021-6, along with the rest of their new
Tour Grade range, to be available in Europe some time early next year.
We don't have pricing for it as yet."
Date Posted: 24 October 2019 at 6:16pm
Impressive looking T/S parameters, however sensitivity, seems a little, "optimistic"..
Non Hornloaded designs, will need gazillion watts, or large pile of cabs, to impress with this beauty.
Posted By: MarjanM
Date Posted: 24 October 2019 at 11:53pm
Its a 6ohm driver. Hence the sensitivity part.
Posted By: fat_brstd
Date Posted: 25 October 2019 at 2:28am
Would that mean it would be around an 8ohm load once put in a half decent sized horn?
------------- Adrians Wall Sound System Melbournes Rootical Warrior Roots - Dub - Steppers
Posted By: torpedo22
Date Posted: 22 February 2020 at 4:51pm
Hello, Was wondering if not the 21NLW9001 would better fit than the 9601? Looking at the tsp of both and especially the fs is making me wonder.
Anyone has experience with one of both drivers or could explain the differences?
9001: http://www.eighteen.com/en/products/lf-driver/21-0/8/21NLW9001 - http://www.eighteensound.com/en/products/lf-driver/21-0/8/21NLW9001
9601: http://www.eighteen.com/en/products/lf-driver/21-0/8/21NLW9601 - http://www.eighteensound.com/en/products/lf-driver/21-0/8/21NLW9601
Many thanks
Date Posted: 02 December 2020 at 11:28am
anyone had a play with the NSW6021-6 yet? Blue Aran have a price for them now...
Posted By: fatfreddiescat
Date Posted: 02 December 2020 at 12:29pm
Looks like a serious driver but the price
For that you can have two B&C 18DS115 also available from Blue Aran, pro's and cons but even so it seems like a hard sell.
Review here:
https://audioxpress.com/article/test-bench-eminence-s-nsw6021-6-21-neodymium-low-frequency-woofer" rel="nofollow - https://audioxpress.com/article/test-bench-eminence-s-nsw6021-6-21-neodymium-low-frequency-woofer
Posted By: smitske96
Date Posted: 02 December 2020 at 12:47pm
The price is the main problem in the EU. The US price of 750 dollar is definately more affordable.
Regarding performance it comes just under the 21iPal (so very good). Personally I just went for Lavoce SAN215.30 drivers, those are half the price of the NSW.
Date Posted: 02 December 2020 at 3:24pm
I have 12. So far so good, only used one night, but had them full tilt off K20's. Unbearable to stand in front of the cabs when on....
Date Posted: 03 December 2020 at 2:52pm
Never heard of the brand
Posted By: BJtheDJ
Date Posted: 03 December 2020 at 5:18pm
smitske96 wrote:
Never heard of the brand | That'll cheer up Marjam
------------- It's a difficult choice, would you rather have:
A: A vegan son. B: An OnlyFans daughter
Posted By: bob4
Date Posted: 04 December 2020 at 8:39am
BJtheDJ wrote:
smitske96 wrote:
Never heard of the brand | That'll cheer up Marjam |
MarjaN
better than some people confusing shabby BFM cabs with his new monster top
I'll get my coat......
on a serious note though, interesting to see that Marjan has ended up with an elongated form factor somewhat similar to Mykey's last iteration of the DubSub, which was cruelly ridiculed by some orthodox scoopists on this very forum...
Posted By: MarjanM
Date Posted: 05 December 2020 at 2:30am
bob4 wrote:
BJtheDJ wrote:
MarjaN
Well the principle is same as with our 18 inch subs, the M4.18. Those were released back in 2014 and Ben (RealitySound) has also a substantial number of those too. 21s surely needed more internal volume and it was only natural to simply go longer.
Since RCF LF21N551 (originally used in the M4.21) was discontinued, the Eminence was the logical choice for an ultimate weapon. Yeah its not cheap, but at 2500W the driver has still 4mm of x-max left in our box. Unlike the RCF which was at he limit or any other 21 that i have simulated.
Ben, send me some better pictures man. i need to brag about this all over internet :)
Oh, i almost forgot. One of the reasons why i chose this shape lies within EAW SB1000 that i used a lot back in the days. I always loved the small front format. It allows you to place more subs in smaller frontal area.
Posted By: jammin75
Date Posted: 05 December 2020 at 3:19pm
RealitySound wrote:
I have 12. So far so good, only used one night, but had them full tilt off K20's. Unbearable to stand in front of the cabs when on.... |
thats a nice view with a nice set
------------- feel the vibes !!! "Who Feels it Knows it" Strong like Lion
Posted By: Crashpc
Date Posted: 09 February 2021 at 6:50pm
Heya. How come they discontinued the beasty LF21N551, and all that without any substitute? I'm trafficking two pieces now, and they are awesome. Will gonto up-to 20.5mm excursion before they start to really struggle with noises and thermal compression from suspension, way better than 21DS115 I had before.
Looking for some new IPAL entries or at least "21DS152“, but there is still nothing.
------------- Nikon and Canon people should not be married to each other. Why did you let this happen?
Posted By: bass*en*mass
Date Posted: 09 February 2021 at 8:02pm
have you had a chance to try the new emi yet crashpc? its not really suitable for horn loading but it should work well in reflex/ported cabs?!
Posted By: Crashpc
Date Posted: 10 February 2021 at 5:16am
Heya. No, I haven't. It certainly has predispositions to be better. Everything on the driver is at least half class more massive. And it is kinda downfall of the driver in my approach. I need compact mobile bins. Eminence does not support that, while RCF just barely does. Maybe a massive 18“ driver could do that. But Eminence 18" nsw is nothing like its bigger brother. And Eminence is quite expensive in Europe. 18IPAL with its 4.5" Al coil is not that tempting for the price either.
Posted By: MarjanM
Date Posted: 10 February 2021 at 3:00pm
Looking for some new IPAL entries or at least "21DS152“, but there is still nothing. |
I think they just stopped selling it to others and decided to keep it for them self only. It was too good to be true that 21. I hate them for doing that.
Posted By: Crashpc
Date Posted: 10 February 2021 at 4:42pm
Wow that is unexpected. In our country, it was priced right under IPAL, maybe $200 on already overpriced $1350 product, so I thought it was not that price competitive on the market, or maybe some reliability issues. But RCF pulling that product because it is too good, that sounds rather evil.
So I guess there is nothing like new IPALs or smaller M-force drivers on horizon. Saaad times. Anyways, thanks for the info.
