RCF LF18x451
Category: Plans
Forum Name: Scoops
Forum Description: One scoop or two ;-)
URL: https://forum.speakerplans.com/forum_posts.asp?TID=103277
Printed Date: 28 March 2024 at 2:06pm Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: RCF LF18x451
Posted By: Taariffj
Subject: RCF LF18x451
Date Posted: 08 February 2019 at 1:00am
The lf18x451, anyone using this driver in scoop? Or what is the best scoop for it? Please help with Some suggestions. Thx.
Posted By: levyte357-
Date Posted: 08 February 2019 at 10:08am
Some suggestions. Thx. |
This driver will "work somewhat" in a number of existing Scoops, but not optimally. Superscooper design modded to provide slightly larger chamber, would work.
Also reference efficiency of 1.90%, would put me off using this straight away.
Also would estimate the Xmax is closer to 11.5, not 14mm.
Also note cutout is 424mm, quite large.
------------- Global Depopulation - Alive and Killing.
Posted By: love2all
Date Posted: 08 February 2019 at 10:38am
I had these in scoops - went back to PD very quickly. Very power hungry and not optimum situation using heavyweight amps on 13amp supply - just doesnt get the best out of them...
You will need a big powersoft and hang 2 a side to give them the right headroom. Even when set up this way the driver will be surpassed by PD1850 and 1852. They Sound good and musical but not going to bring the house down...xmax figures are realisitic the cones certainly do move a lot.
Date Posted: 08 February 2019 at 10:51am
You will need a big powersoft and hang 2 a side to give them the right headroom. Even when set up this way the driver will be surpassed by PD1850 and 1852. They Sound good and musical but not going to bring the house down... |
I could see all of this happening, just by looking at the TS Parms. Driver like this, really needs optimal box, to give worthwhile results.
Ref efficiency 1.9% tells you will be very power hungry, and difficult to get going.
Qes = 0.29 tells will have warm sound, but not as efficient as some
PD1850/51/52, all have higher Ref efficiency, so will be more sensitive.
https://www.speakerplans.com/index.php?id=faq1" rel="nofollow - https://www.speakerplans.com/index.php?id=faq1
no: Free air reference efficiency.
Posted By: love2all
Date Posted: 08 February 2019 at 10:59am
Exactly why i send you TS params yday! Thanks for the insight
Posted By: Taariffj
Date Posted: 08 February 2019 at 1:29pm
How would the driver work in your lev .44 scoops? I have 10 of these they work ok in rog super scoop, But I want the best performance out of them. I’m running 2 a side on a k20.
Posted By: love2all
Date Posted: 08 February 2019 at 2:03pm
2 a side on k20 is the right amplification - whats freq band are you playing through them?
Posted By: Taariffj
Date Posted: 08 February 2019 at 2:24pm
I have been running them at 40-125 hz on the drive rack.
Date Posted: 08 February 2019 at 2:47pm
I’m running 2 a side on a k20. |
They would work fine, in my Lev .44, as I have tried drivers with "very similar" parms, but more sensitive.
If I were in your position, I would ideally sell these, and get more efficient drivers, more suited to the cab.
Void V18-1000s/B&C 18TBX100 In Superscooper, would allow 6x cabs per K20.
Date Posted: 08 February 2019 at 3:15pm
There would also be fairly simple Scoop mod, to change driver chamber from 44L to approx 65L, keeping Scoop throat same volume, which would allow even more drivers, to be optimal in your cabs.
Posted By: Taariffj
Date Posted: 08 February 2019 at 5:03pm
Are you saying with the 451/ k20 on 4 the pd 1850/2 Will have better performance/ spl/ louder?
Posted By: Taariffj
Date Posted: 08 February 2019 at 5:10pm
You will need a big powersoft and hang 2 a side to give them the right headroom. Even when set up this way the driver will be surpassed by PD1850 and 1852. They Sound good and musical but not going to bring the house down...xmax figures are realisitic the cones certainly do move a lot. |
Date Posted: 08 February 2019 at 5:22pm
Will have better performance/ spl/ louder? |
Have never used, heard PD1850/2.
I know the V18-1000/B&C 18TBX1000 work excellently in standard Scooper, and K20 could easily drive 3x per side, if on decent mains power source.
What makes of 18" drivers, do you have easy access to?
Posted By: Taariffj
Date Posted: 08 February 2019 at 5:31pm
I’m in Toronto, Canada., I can get basically anything I need.
Date Posted: 08 February 2019 at 5:36pm
Can you get Oberton drivers?
Oberton 18XB1500 may well appreciate the tightness of your Super Scoopers.
http://www.bluearan.co.uk/index.php?id=OBN18XB1500" rel="nofollow - http://www.bluearan.co.uk/index.php?id=OBN18XB1500
Posted By: Taariffj
Date Posted: 08 February 2019 at 6:06pm
http://www.bluearan.co.uk/index.php?id=OBN18XB1500 - http://www.bluearan.co.uk/index.php?id=OBN18XB1500
I will look into this driver, as I’m not familiar with the brand.
Posted By: MarjanM
Date Posted: 08 February 2019 at 8:54pm
Why would that rcf not work? If you listen to Lev, the 18NLW9601 is the crappies 18 inch for a scoop. Which took him about 4-5 years to finally realize that it actually spanks almost everything out there in a right scoop.
------------- Marjan Milosevic MM-Acoustics www.mm-acoustics.com https://www.facebook.com/pages/MM-Acoustics/608901282527713
Posted By: Taariffj
Date Posted: 08 February 2019 at 9:47pm
MarjanM wrote:
Why would that rcf not work?If you listen to Lev, the 18NLW9601 is the crappies 18 inch for a scoop. Which took him about 4-5 years to finally realize that it actually spanks almost everything out there in a right scoop. |
The woofer works ok, I was asking if anyone using it in scoops or which design Would be best suited for it.
Date Posted: 09 February 2019 at 7:51am
13amp supply - just doesnt get the best out of them... |
@Marjan, maybe you should have read the above first !?
And here endeth my input on this thread..
Posted By: Father-Francis
Date Posted: 09 February 2019 at 10:04am
Not all of us play from 13amp soc’s so sometimes the info or advice shouldn’t be important.
------------- Music is the strongest form of magic.(+45 31879997)blakmanpro@gmail.com, foa@sweetboxaudio.dk
Posted By: spongebob
Date Posted: 09 February 2019 at 10:36am
I don't really understand the whole 13A thing. A 13A plug with 13A fuse on a sensibly loaded 32A ring would in all likelyhood give you more power on tap than a 16A ceeform
Date Posted: 09 February 2019 at 12:02pm
spongebob wrote:
I don't really understand the whole 13A thing. A 13A plug with 13A fuse on a sensibly loaded 32A ring would in all likelyhood give you more power on tap than a 16A ceeform |
Might as well smash your head against a wall mate. Never mind that if you aren’t melting the plug, popping a fuse or tripping a breaker you have 26A to play with for peaks. Not that said K20 will rarely draw over that unless you’re loading the shit out of both channels and playing some waves at the impedance minima.
Posted By: Taariffj
Date Posted: 09 February 2019 at 3:35pm
Anyone ever did any simulation with the 451 in scoops Or can do it?
Posted By: haystacK
Date Posted: 25 April 2019 at 6:08pm
I've been running the LF18x401 in Wardrobes and quite like it though I haven't yet measure output.
Levyte, any chance you can share any opinions on the specs for the 401 based on your experience?
http://www.bluearan.co.uk/index.php?id=RCFLF18X401" rel="nofollow - http://www.bluearan.co.uk/index.php?id=RCFLF18X401
Posted By: RealitySound
Date Posted: 27 April 2019 at 2:37am
You only get to ask so many questions before you get a bill via PM.....
------------- When you gonna send me some $$ mate ?
Posted By: MarjanM
Date Posted: 27 April 2019 at 2:24pm
RealitySound wrote:
You only get to ask so many questions before you get a bill via PM..... |
Posted By: SUFFERER
Date Posted: 29 April 2019 at 2:12pm
The driver is great but not really suited to scoops, or there isnt a DIY or known designed scoop that it would perform well with. Maybe shortman full??
Stick two of these in a double reflex and the driver will be much more at home.
Posted By: ReubGold
Date Posted: 29 April 2019 at 2:32pm
Pretty sure Lev has been answering questions for over 10 years, without charging anyone..
Also heard he gave someone a free Scoop plan, that they loved, and when they said they where going to build 8x for tourist season, the tw*t went off, when Lev asked for $50.
Just what I heard..
------------- If he turns me into a zombie, first person I'm coming after is you.
Date Posted: 29 April 2019 at 5:47pm
Just what I heard..
Sugar coated story he told you I'm sure. Who you calling a twat? You don't know me bwoy......
Date Posted: 29 April 2019 at 5:56pm
Date Posted: 29 April 2019 at 5:58pm
Aye ReubGold.....you see me going off like a twat? You see mention of $50?
Posted By: corell
Date Posted: 29 April 2019 at 6:03pm
erm, that doesnt belong here! sharing private messages through a forum is a nogo.
Apart from that, is this scoop plan you are talking about anywhere on the net or did he sent it to you via PN? If the latter, it would be good manners to ask again when you build more. It also would be good manners to tell in advance if you expect any money for something.
Date Posted: 29 April 2019 at 6:52pm
scoop plan being an emmy, standard width, with reflectors? Had one built and this guy asking for handouts.....
Posted By: Wini
Date Posted: 14 June 2019 at 7:14pm
Hi,
Any more feedback or advice on the RCF LF18X451 ?
