QSC PL380 vs QSC PL9 vs Powersoft K20
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=104234
Printed Date: 19 April 2024 at 10:18pm Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: QSC PL380 vs QSC PL9 vs Powersoft K20
Posted By: ReubGold
Subject: QSC PL380 vs QSC PL9 vs Powersoft K20
Date Posted: 10 September 2019 at 12:31pm
From what I've seen:
Powersoft K20 - Not warmest sound @ 2.66 ohm stereo, but plenty power, most reliable, decent power on 32A ring main
QSC PL9 - Most powerful when on Genny, most unreliable, fairly warm sound, often blows on 32A ring main
QSC PL380 - Ok reliability, warmest sound, ONLY really performs on Genny, or very strong mains spur.
Comment, opinions, thinking of trying Crown MA12000.
------------- If he turns me into a zombie, first person I'm coming after is you.
Posted By: spongebob
Date Posted: 10 September 2019 at 1:20pm
"Most powerful when on Genny"
Posted By: levyte357-
Date Posted: 10 September 2019 at 1:25pm
spongebob wrote:
"Most powerful when on Genny" |
Maybe should say, performs best when on Genny.
I have seen this many times..
------------- Global Depopulation - Alive and Killing.
Posted By: rosssss224
Date Posted: 10 September 2019 at 1:44pm
Is there any benefit running a K20 off anything other than a 13A standard socket if only running at 4ohms? In this case to power 4 PD1850's playing 30-85hz.
Looking at the fuse curve I can't see there being much point.
Date Posted: 10 September 2019 at 1:57pm
Looking at the fuse curve I can't see there being much point. |
Can't see the point of running 1850s downto 30hz, in most cabs.
Can forsee many disadvantages, and problems of doing it though.
Posted By: Elliot Thompson
Date Posted: 11 September 2019 at 2:50am
All QSC amplifiers sound the same. If the Powerlight 380 sounds "warmer" to you than the Powerlight 9.0, it usually stems from one amplifier running out of headroom faster than the other (which begins to clip). When this occurs, distortion (Not at all times a bad thing when you are aiming for a particular tone) is coming into play.
The above is very common when comparing two amplifiers of the same brand offering unequal output power. The QSC Powerlight 9.0 is 9000 watts RMS whereas, the QSC Powerlight 380 is 8000 watts momentary (Burst) Peak.
Best Regards,
------------- Elliot Thompson
Date Posted: 11 September 2019 at 10:05am
Where you should place your electronic HPF is very rarely where the acoustic output has dropped by 3dB. The HPF should prevent overexcursion but also aid cooling, and many reflex boxes can also take a large PEQ boost at tuning frequency too. You’d be very surprised if you saw many pro manufacturers’ settings, for any sort of design. They very rarely match what I see used in the DIY scene.
As for using a bigger mains plug, you should use the largest available, for thermal reasons if anything. A 13A plug fuse may not blow but the wire is thin comparatively and the plug top will get warm.
Posted By: Chris Grimshaw
Date Posted: 11 September 2019 at 10:38am
I have an MA12000i sitting around at the moment. Would be interested in selling it on. PM me if you'd like to work something out.
Chris
------------- Quality sound from Sheffield www.grimshawaudio.com
Posted By: U.Viktor
Date Posted: 11 September 2019 at 3:06pm
QSC PL380 is a crap Class-D, does not even have real output feedback.. Very poor sound quality.
Its PSU is also a nigthmare for circuit breakers, poisoning the mains with extreme current spike harmonics.
QSC PL9.0 is a half-finished yet over-complicated design. Not reliable, since ~10 or more years out of production, not a surprise!
Powersoft K20 is not sounding good but still works better than the two above^
Date Posted: 11 September 2019 at 3:15pm
Intrigued what's good sounding then?
Posted By: fat_brstd
Date Posted: 13 September 2019 at 5:54am
I have never seen you ever make a positive comment about any amp ever, pure negative vibes. We all know you are involved with PKN in some capacity but the product bashing is really getting tiresome now.
I use the PL380 to drive my subs, I really like it, loads of power, spanks PD1850 right to their limits and most importantly sounds clean and good. I regularly run 6 drivers off it on a 32amp supply and have never had it pop a breaker even when being drive right up to clip.
Personally I think it sounds a lot better than the K20 which I have also played with. TBH I have never been a fan of the Powersoft K series when it comes to tone, oodles of power but the tone is just not for me.
------------- Adrians Wall Sound System Melbournes Rootical Warrior Roots - Dub - Steppers
Date Posted: 13 September 2019 at 8:44am
Personally I think it sounds a lot better than the K20 which I have also played with. TBH I have never been a fan of the Powersoft K series when it comes to tone, oodles of power but the tone is just not for me. |
Have to agree with 99% of that, PL380 on proper mains/genny can properly spank 6x PD1851s, with warmth and tone.
K20 loses bit of warmth, when you play > 2 "8 ohm" cabs a side.
But K20 is possibly the most likely amp to survive heavy gig, at 4x cabs a side.
Notice I didn't mention terms like 4 ohm/2 ohm stereo, as most cabs are never 8 ohm exactly.
Posted By: Sinai Sound
Date Posted: 13 September 2019 at 9:14am
Notice I didn't mention terms like 4 ohm/2 ohm stereo, as most cabs are never 8 ohm exactly. |
If I've got 4 x "8ohm" cabs to run from a K20.......I'll put them all on a single channel personally
Posted By: taurusty
Date Posted: 18 November 2019 at 4:03pm
Have to disagree with last 3 comments. Used a QSC PL 380 vs a Powersoft K 10, and was totally dissatisfied with the 380. As Elliott said, this company now buys into the Behringer type wattage specs. and it shows. As far as I am concerned, QSC has no real heritage in reliable very high power amplifiers, compared to crown, Lab Gruppen and Powersoft.
Posted By: citizensc
Date Posted: 19 November 2019 at 2:04am
taurusty wrote:
Have to disagree with last 3 comments. Used a QSC PL 380 vs a Powersoft K 10, and was totally dissatisfied with the 380. As Elliott said, this company now buys into the Behringer type wattage specs. and it shows. As far as I am concerned, QSC has no real heritage in reliable very high power amplifiers, compared to crown, Lab Gruppen and Powersoft. |
I have no experience with the K10 but a lot of what you are saying about the pl380 is objectively wrong. The PL380 exceeds its specs, putting out over 2900 watts at 4 ohm @ 40hz before clip while stating 2500 in its spec sheet. https://www.abeltronics.co.uk/amptesting/amp-meet-three.php" rel="nofollow - https://www.abeltronics.co.uk/amptesting/amp-meet-three.php . The pl380 not some new amp that has a questionable reliability and power output. It has existed for more than 10 years, people have a lot of experience with it; it almost has a heritage of its own. This ignores the fact that the PL9.0, RMX5050 and mx3000a exist.
I cant comment on your personal experience using it, but I guess sound is subjective.
Date Posted: 19 November 2019 at 3:37am
The problem is likely this constant fixation on watts. Yes, an amp needs to be able to supply sufficient current to handle the number of cycles asked of it, but much more important is voltage swing and efficiency. Music is dynamic, we aren’t cooking food in a microwave or trying to light a room with a filament here.
Posted By: U.Viktor
Date Posted: 19 November 2019 at 6:48am
Powersoft K10 is better in every aspects than PL380.
Posted By: FOO
Date Posted: 19 November 2019 at 11:21am
Forget them all, and get a LAB PLM. Works every time. Or FP if you dont like having your DSP in the amp.
They walk All over everything, so its a good investment.
End of discussion :)
Posted By: U.Viktor
Date Posted: 19 November 2019 at 2:28pm
End of discussion :) |
How still they get bipolar power Si-transistors since no company making them anymore? Does it have the usual LabGruppen's Switching Buck pre-regulator followed by a linear Class AB stage for signal smoothing, right?
Posted By: FOO
Date Posted: 19 November 2019 at 3:58pm
I really dont care whats inside. They turn on every time i ask them to do so, and they never fail. Loads of power and control. Really good sound regardless of what you hook them up with.
Posted By: Earplug
Date Posted: 19 November 2019 at 6:13pm
"How still they get bipolar power Si-transistors since no company making them anymore?"
What? That´s an absurd statement!
Of course they are. Here are a few high power devices:-
https://www.digikey.com/products/en/discrete-semiconductor-products/transistors-bipolar-bjt-single/276?k=&pkeyword=&sv=0&umin2109=100&umax2109=400&rfu2109=W&sf=1&FV=-8%7C276&quantity=&ColumnSort=0&page=1&pageSize=25" rel="nofollow - https://www.digikey.com/products/en/discrete-semiconductor-products/transistors-bipolar-bjt-single/276?k=&pkeyword=&sv=0&umin2109=100&umax2109=400&rfu2109=W&sf=1&FV=-8%7C276&quantity=&ColumnSort=0&page=1&pageSize=25
No shortage there.
------------- Earplugs Are For Wimps!
Date Posted: 19 November 2019 at 8:21pm
I've been on this forum for far, far too long, and it's only in the last couple years that I've really started to see whose posts you can actually take with a very large pinch of salt
Date Posted: 20 November 2019 at 12:50am
QSC make good
amplifiers however, you need to understand what the general public
wants. That has always been the concept of QSC. They were the first
manufacture to revolutionise our industry offering lightweight
(Powerlight & PLX) amplifiers. Their amplifiers were also very
tolerant when faced with low voltage which, is essential in parts of
the world where voltage is very dodgy.
This is the most
important thing that many of us tend to forget about amplifier
manufactures. Their main objective is to attain the specified wattage
with the lowest distortion possible. So, as technology moves forward,
the distortion will be reduced from the previous models based on new
innovative parts. For Mid to High frequencies this may be all in
favour however, for bass it may not be wanted by some.
I recall a Crown
Representative stated a decade ago after numerous complaints about
the I tech 8000 not sounding as “Warm” (I know poor choice of
words) as the MA 5000vz on a forum to just load the Itech down until
it sounds like the Crown 5000vz. Although, a lot of users were not
happy with the answer, there was some truth in his reply. The Itech
had no parts of the Macro-Tech other than a logo stating “Crown.”
The same thing applies to the QSC Powerlight 3 compared to the
Powerlight.
The market today is
powered speakers. Don't be surprise within a 10 year period many of
these brands we tend to debate about merge with a loudspeaker
manufacture and do away with their stand alone amplifiers altogether.
Remember we are hitting a new decade and, a lot of things are going
change in our market whether we like it or not.
Best Regards,
Date Posted: 26 August 2020 at 5:20pm
Recently went to amp/driver test, and one thing I learned, bench testing amps with purely resistive load, proves nothing.
Posted By: simonp1100
Date Posted: 26 August 2020 at 5:26pm
Date Posted: 27 August 2020 at 4:18am
It says nothing about tone and I am aware that amps like Powersoft X series don't perform well in to a resistive load but do when driving program in to a speaker, however, I cant imagine an amp that can push a sine wave with more power than its spec in to a resistive load would struggle with the greatly reduced crest factor of program material... Or is there something you know that I don't?
Also would be interested to hear about some of the results the test, were there any unexpected winners or losers?
Posted By: D_S
Date Posted: 24 October 2021 at 2:19am
Best Regards,
Hi, does the PL380 sound like a RMX5050?
Posted By: ropilas
Date Posted: 13 October 2022 at 3:37pm
Hi,
Any body knows where to buy control board for QSC PL9.0?
