Punisher Extension Development Thread
Forum Name: General Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=104537
Printed Date: 19 April 2024 at 8:37pm Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Punisher Extension Development Thread
Posted By: citizensc
Subject: Punisher Extension Development Thread
Date Posted: 26 November 2019 at 12:28pm
This should be a relatively quick on, there doesn't appear to be much to this apart from following the flare rate of the punisher.
Goals for this design are: -One horn extension, covers two punishers and fits on 1.5 sheets of 15mm 2400x1200 birch ply -Liftable, up to a stack of three high by two people
-Does not add any annoying honks, rattles or other unwanted distortion
-easy to setup, shouldn't be more difficult than stacking 'n' strapping -Increase SPL by => 3dB
-Decrease low end by => 5hz
To meet this, I have settled for these dimensions. The added horn length is 590mm, this is so two panels fit on the width of a 2400x1200mm sheet of ply with 20mm to spare for saw blade/cnc head. This is a 26.6% increase in horn length on to the roughly 2222mm a punisher has.
Following the flare rate of the punisher this results in the extension having a 2115mm mouth width, an increase of 89% in mouth area when compared to the two punishers the extension fits on to. Here are some hornresp sims of this extension. All sims are for 6 punishers fitted to 3 extensions, take sensitivity with a grain of salt as it is slightly less than 8ohm. inputs used - S1-4 are the standard punisher, S5 is the horn extension. Ciare 12.00sw Black=extension, Grey=no extension
Beyma 12LX60V2 - Black=extension, Grey=no extension P.Audio SD12 - Black=extension, Grey=no extension The horn extension consistently adds 7-8hz low end extension regardless of driver which seem promising. Could this be due to the punisher being a relatively short horn, making it sensitive to added length? The extension only seems to add about 1dB of SPL which isnt very impressive. Should I be expecting a significant spl increase in the sim? or does the sim not account for increased directivity? Here are some drawings of my first attempt at a design.
-The cut outs in the bracing can be any shape you like, they are just there to remove weight.
-The little notches visible at the back of the extension are for feeding a ratchet strap through and strapping to the punisher -I may add more notches to allow multiple horns extensions on top of each other to be vertically strapped together -This version is for a double punisher, I will make another version, 15mm wider for two single punishers pushed together.
Link to sketchup file - https://www.dropbox.com/s/mnqokkmuko4jw8u/Extension%20-%20Speakerplans.skp?dl=0 Message me if it goes dead!
Let me know what you guys think! Are there any significant issues? Will the real thing make a meaningful difference to SPL and low end cut off? Is there enough bracing? Is it ugly? Is there any way you can see to improve it?
Posted By: Elliot Thompson
Date Posted: 26 November 2019 at 2:25pm
What are all the dimension of the extension? I only read 1200 X 2400.
The length of the horn determines the low frequency cutoff and, the width of the mouth determines how loud it will play. Based on your simulation, the mouth of the extension is not wide enough to offer more SPL beyond the two Punisher's ability to play on their own. The length of the extension is not long enough to extend the response to hear a significant difference.
You would achieve better results sticking both boxes in a corner.
Would it not be better to just add two more boxes so you can achieve an additional +3 dB gain plus the extension from having all four boxes coupling together to create a longer horn? I always thought the Punishers were designed (I believe the designer name is Yohan?) to be used in blocks of four not two with the Claire woofers?
Best Regards,
------------- Elliot Thompson
Posted By: cravings
Date Posted: 26 November 2019 at 3:57pm
punisher designer is walt de jong. he posts here as Contour.
Date Posted: 26 November 2019 at 4:28pm
cravings wrote:
punisher designer is walt de jong. he posts here as Contour. |
Thanks.
Best Regards,
Date Posted: 26 November 2019 at 6:27pm
First thing to point out, as I did in the other thread is that transporting this will be a right pain in the arse. Expect it to weigh as much if not more than two cabs, and the size means it takes up most of a van without stuff able to be stacked on top of it.
You will also likely need four straps per horn extension to keep it attached, plus dense foam gasket to avoid rattling where it meets the subs.
If you can’t flat pack it to transport it; it’ll gather dust in the warehouse where everyone will curse its name for being in the way. Take it from someone who had 8 of the Void X Horns in their unit for the best part of a year, and used them twice in that time on actual gigs. Gigs where we had a 18 ton or larger truck and still had space issues.
Date Posted: 26 November 2019 at 11:52pm
Elliot Thompson wrote:
What are all the dimension of the extension? I only read 1200 X 2400. | Horn length is 590mm. The mouth is 2115x470mm.
| The sims are for 6 punishers with 3 of these horns stuck on them, not two punishers with one horn. I intend to use these extensions in 3s with 6 punishers behind them. The extension almost doubles the mouth area, are you sure that will have no impact on SPL? if that does nothing how big does it have to be to have meaningful impact?
You would achieve better results sticking both boxes in a corner. | This is rarely an option for us, we do shows in some odd rooms and we use ground stacks, the punishers have to be positioned with the HF positioning in mind.
Would it not be better to just add two more boxes so you can achieve an additional +3 dB gain plus the extension from having all four boxes coupling together to create a longer horn? I always thought the Punishers were designed (I believe the designer name is Yohan?) to be used in blocks of four not two with the Claire woofers? | Like I said, this is intended to be used in groups of 3 extensions, on 6 punishers, the sims reflect that.
Date Posted: 27 November 2019 at 12:03am
toastyghost wrote:
First thing to point out, as I did in the other thread is that transporting this will be a right pain in the arse. Expect it to weigh as much if not more than two cabs, and the size means it takes up most of a van without stuff able to be stacked on top of it. |
Transport is something very much on my mind, we use a box trailer to transport our system, right now our 12 punishers, 4 xtros, amps and other stuff pretty much fill it. No matter what what we build, we will need to do two trips, it isnt the end of the world as most gigs are <15 min drive for us. As far as the weight goes, im not sure it will be that extreme, a punisher take 1.5 sheets of ply and has a ferite driver that weights 11kg in it. This will be 1.5 sheets of ply and have no further components other than screws, glue and paint. Remember, this isnt as large as the void X-Horn, and this is made out of 15mm birch.
Why would we need so many straps? the horns would be ground stacked, the job of the straps would just be to prevent rattles and to stop the cabs from moving. The gasket tape is something I already had in mind, it will also stop the two cabs from stripping the paint off eachother and form a seal.
toastyghost wrote:
If you can’t flat pack it to transport it; it’ll gather dust in the warehouse where everyone will curse its name for being in the way. Take it from someone who had 8 of the Void X Horns in their unit for the best part of a year, and used them twice in that time on actual gigs. Gigs where we had a 18 ton or larger truck and still had space issues. |
There is a risk of this, the big thing for us is we cant really afford 12 more punishers and 2 more pl380s, we only do ~25 shows a year right now and we have other expenses. There is potential for some of our customers to out grow us as their festivals grow, this solution would bee about 20% of the cost and less build time than more cabs & amps.
Posted By: Keen
Date Posted: 27 November 2019 at 2:43am
what about making one extension system for a block of 6 punishers, that can be dismantled? i.e. top bottom, 2 sides, 2 big braces. just a thought...
Date Posted: 27 November 2019 at 3:47am
You cleared up a lot of
things. Particularly the expansion dimensions. It is a very wide
exponential horn indeed. I can only go by what the simulator is
showing based on the end results. Your issue may not be the expansion
but the Punisher Horn.
Horns are designed to
offer a particular frequency range (by the designer) when used in
groups of four or eight. Rarely, if ever, in twos. Since you are
using six Punisher horns, you are a smitten short of achieving
optimum low frequency extension the Punisher can offer which, is why
adding an extension offers no significant advantage in the low
frequency extension. The results you are seeing would be the end
result of adding two more Punisher horns equating to eight bins.
You are already
literally flat with six Punisher bins. This basically means you have
achieved optimum performance level for the horn from an extension
standpoint. There is no where left to go but louder by increasing the
mouth size.
I recall when Contour
introduced these boxes on Speakerplans. I distinctly remember Contour
saying he did not want the boxes to go low based on the type of music
he was using. He wanted a very potent attack and, bass extension was
not the priority. So the expansion rate of the Punisher Horn is
maxmised to a frequency to achieve those results using the Ciare 12
inch woofer.
Unfortunately, it
becomes extremely difficult to achieve the low frequency extension
you are aiming for when the designer was not on favour of it. Even if
you stacked 12 Punisher Bins (6 high Horizontally & 6 across
Vertically) standing upright to increased the mouth size, you would
not get a lower frequency response.
However, you would get
a higher SPL level as the mouth is now bigger horizontally in
addition to vertically. That is pretty much how horns work and, why
having the extension standing 470 mm tall is more questionable to
give you the +3 dB increase terms of SPL you are seeking. Sometimes
bass smacking you in the face will do a better job than having all
the bass focused on your trousers legs waving them like a flag.
Providing you are stacking one extension on top of the other, you
should attain more noticeable SPL.
How much SPL?
Theoretically, +3dB. Realistically, unknown. This is what happens
when you start thinking outside the box. You have to accept there is
a 50/50 chance your idea may or may not work. I go through this all
the time so I am letting you know in advance.
Is it worth it? At the
end of the event, you will be the one that needs to tote the
extensions back home so, only you can answer that question.
Bear in mind the width
of these extensions would not overcome having the same width using
more Punishers from an SPL standpoint. Six woofers can only go so
loud even with the extension added on. The coupling affect of
multiple drivers working as a team will always win in the end. If you
are willing to move 2115 mm in length horn flares then, you can carry
an equal amount of Punishers to equate a width of 2115 mm.
Just remember, which
ever route you choose to take, you have achieved optimum low
frequency extension with your current Punisher Horns.
Best Regards,
Date Posted: 27 November 2019 at 11:38am
he was using.
Why is the will of the designer relivent? Will the horn not just follow the laws of physics? Do longer horns with bigger mouths not reach lower frequencies?
The sims support this, look at the one for the Ciare 12.00sw, the efficiency starts to fall off about 7 or 8 hz lower with the horn extension.
How much SPL?
This bit im not really sure of, I dont think hornresp accounts for directivity (someone correct me if im wrong here) so it wont show the real improvement. The punisher does have a small mouth for a bass horn and is a rather small cab so I would imagine its directivity control is quite bad meaning there is a lot of room for improvement. Would it be naive to have expectations of 3-5 dB improvement measured on axis from 5m away?
Date Posted: 27 November 2019 at 11:45am
Keen wrote:
what about making one extension system for a block of 6 punishers, that can be dismantled? i.e. top bottom, 2 sides, 2 big braces. just a thought... |
I have been thinking about this but I have no idea how to make it work, there would be a lot of challanges with the design. -How do I add enough bracing to make it completely rigid, will making the bracing detachable? -How do I make rock solid detachable joins that dont rattle, wobble, are reliable and easy to use? -How could I design this to be setup in a reasonable amount of time? If this is a feasible thing to do, why wouldn't companys with real R&D budgets design something like this rather than the infrahorn and X-Horn.
A stack of rigid cabinets seems far more reasonable.
Posted By: Jo bg
Date Posted: 27 November 2019 at 12:49pm
Hornresp can sim directivity only with single segment horns (exp or con, nor shure about par), try to model a single segment horn similar to yours and you can get a feel of the boost you will get.
Date Posted: 27 November 2019 at 1:20pm
Thanks for the idea, unfortunatly it doesnt appear to be much use in the bass frequencies, it also wont work for coupled speakers, I can only do it for a single punisher with a half sized horn extension. Here are the results:
Without horn extension
With horn extension
Even at 90 degrees it doesnt show much, -0.1dB with out the extension, -0.3dB with the extension. I Guess it shows that the extension is doing something but how much is unclear.
Date Posted: 27 November 2019 at 1:53pm
Because time is money. The guys in Ireland made one out of steel plates tensioned with steel bar and stretchers, and it worked very well and of course took up a lot less space in transit, but it was only feasible to build for a multi day festival event, again delivered by truck due to the extra weight.
Posted By: Jo bg
Date Posted: 27 November 2019 at 2:07pm
Try to model a single horn the size of the whole stack plus extender, with horn mouth as large as the three stacked extensions.
If you look at Art Welter empirical findings on "barn doors" in diyaudio forums, extending the frontal area and disregarding horn path, you see a rise in dBs but not as much low corner shift as in your Sims, so I believe you are only visualizing one side of the effect. If I remember correctly he talks about something like a 3 dB gain from doubling of frontal area, more gets impractical. I agree that without making this foldable or at least nestable , it will be a pain to move. (Even 15 mins one way, 30 mins roundtrip means one more hour of travel, not accounting loading and unloading)
Date Posted: 27 November 2019 at 2:12pm
he was using.
The expansion rate to the mouth plays a factor. If the box is already expanded to a particular frequency at the mouth, adding on an extension to the mouth can just make the box louder without any means of low frequency extension. You need to have pressure buildup in order to achieve lower frequencies at a greater intensity. So what happens when there is no pressure buildup below the Punisher's horn cutoff point and, you add a large exponential horn extension in front of the Punisher's horn mouth to extend the low frequency response? Nothing. This is due to no low frequency pressure buildup at the extended frequencies you are trying to achieve. There are principals of a horn you need to follow and, you are just looking at one part of the equation.
How much SPL?
You should not put all your trust in simulations. It only tells half the story especially when it comes to output. There are too many variables that come into play which, can only be answered by literally measuring the box in the real world. Using a simulator under 1-watt/2.83 volt is fine. However, once you start focusing on high sound pressure levels, you need to put down the simulator software and start using a measuring software.
Best Regards,
Posted By: mobiele eenheid
Date Posted: 27 November 2019 at 6:20pm
This is the on axis directivity of the stack of 6 Punisher plus extension versus the power response/ standard simulated response.
And this is the on axis directivity of 6 Punishers versus the on axis directivity of 6 Punishers with the extension.
Date Posted: 28 November 2019 at 9:59am
How did you do these sims? I am not able to replicate them.
Thanks in advance
Date Posted: 28 November 2019 at 2:17pm
yours and you can get a feel of the boost you will get |
That ;)
Posted By: Dutchman
Date Posted: 28 November 2019 at 11:38pm
Like the idea! Do you already have a cut sheet? Maybe we can build and test it in Belgium , friend of mine has 12 punishers :)
------------- We need more SPL!
Date Posted: 28 November 2019 at 11:49pm
That ;)
But what were your inputs!? I cant seem to make a single horn sim similarly to 6 coupled punishers
Dutchman wrote:
Like the idea! Do you already have a cut sheet? Maybe we can build and test it in Belgium , friend of mine has 12 punishers :) |
I don't yet, What software would you like the cut sheet made up in?
Posted By: Dutchman
Date Posted: 28 November 2019 at 11:52pm
Maxcut, dxf or just simple pdf :D.
I can buy quality birch sheets for 39 pounds so it can’t go wrong! It must go lower, i’ll try and measure :)
Date Posted: 29 November 2019 at 12:01am
I can buy quality birch sheets for 39 pounds so it can’t go wrong! It must go lower, i’ll try and measure :) |
No problem, will get it done next week, good a large booking (for us) this weekend.
Posted By: Dutchman
Date Posted: 29 November 2019 at 12:09am
Awesome mate! Have a good one!
Date Posted: 29 November 2019 at 12:25am
But what were your inputs!? I cant seem to make a single horn sim similarly to 6 coupled punisher | You make a single segment horn that resembles your Punisher, with or without extension, exponential gets very close. Multiply S1, S2, Vrc, Vtc and Atc by a factor 6. In the input screen go to Tools - Loudspeaker Configuration - Set 6 drivers with series/ parallel. Adjust Eg for new impedance.
Posted By: Phil B
Date Posted: 29 November 2019 at 9:25am
You could make that a flat pack with a bit of thought ? Our main issue was attaching the extension to the subs in the same place every time. Our subs are Top and bottom L+R with interlocking skids so they stay in the same position. We also always try to stack on the same pallets we carry.
The extensions all just clip on with the latches starting with the bottom panel then sides, top and braces last. Those latches have a screw adjustment so can be adjusted if things aren't totally level. Every joint edge of the extension panel has a wood batten with foam to make a rattle free fit
Over the years we can now build them pretty quick, solve any rattles with a quick test track and pretty much forget after that ... I would like to add a horizontal brace at sometime but can't find any of that elusive time stuff kicking around !
AND they pack neatly into the trailer ...
.p.
------------- Mostly harmless.... except if catering is shut.
Solar Sound System Shennanigans.. http://diyhifi.biz/" rel="nofollow - http://diyhifi.biz/
Date Posted: 17 December 2019 at 9:22am
Update:
I have made cut sheets and solidworks drawings for this, there are two versions, one to fit a double punisher mk2, and another, 15mm wider to fit 2 x single punisher mk2s. I have removed the strapping points from the drawing, going to leave it to the builders to design a method of attaching it to the punishers.
I am not exactly experienced with autocad/solidworks and made these using trial versions of the software... I have done my best but would love suggestions for how to improve the drawings and make them more accessible so anyone can read and understand them.
Here are the files - please check them before you build anything from them, just make sure the cut sheets match the drawing and the drawings are the right width to fit your punishers.
For single punishers - https://www.dropbox.com/sh/cfpqqwb3dxnnj2n/AAClo4G6urnDpAq11a31me6Ca?dl=0" rel="nofollow - https://www.dropbox.com/sh/cfpqqwb3dxnnj2n/AAClo4G6urnDpAq11a31me6Ca?dl=0
For double punishers - https://www.dropbox.com/sh/ekvinl4tdwd6259/AADSoeBMtZ7hu07iNRSpLmqTa?dl=0" rel="nofollow - https://www.dropbox.com/sh/ekvinl4tdwd6259/AADSoeBMtZ7hu07iNRSpLmqTa?dl=0
PDF is for the double punisher version but you can apply most of it to the single punisher version just add 15mm to the width - https://www.dropbox.com/s/k56cocuhx4ym1aw/p-extension%20-%20double%20drawing.pdf?dl=0" rel="nofollow - https://www.dropbox.com/s/k56cocuhx4ym1aw/p-extension%20-%20double%20drawing.pdf?dl=0
Also does anyone know what software was used to generate this PDF? I would love mine to be that detailed and clear https://www.dropbox.com/s/djam4g1oqirwmsj/TH18%20Xoc1%20%2B%20CUT%20LIST.pdf?dl=0" rel="nofollow - https://www.dropbox.com/s/djam4g1oqirwmsj/TH18%20Xoc1%20%2B%20CUT%20LIST.pdf?dl=0
If you have any feedback or questions please comment or message me! and feel free to make your own modifications to the design - I consider this open source.
Date Posted: 19 December 2019 at 1:01pm
It is good to read (yet I am not surprised)that you are pursuing this project. Based on your replies, it was obvious you wanted to create this project. You might want to consider making a new thread in the Punisher and X-tro forum so no one will be looking for the design 10 years from now and, can't find it in the General Forum.
Best Regards,
