New 3-way mid-top
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=104935
Printed Date: 26 March 2026 at 9:48pm Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: New 3-way mid-top
Posted By: ceharden
Subject: New 3-way mid-top
Date Posted: 01 March 2020 at 8:24pm
Another much overdue new design:
3-way mid-top for small venues. 12"+8"+1".
Getting the combined rear chamber and port design right took a bit of thought.
Drivers are all 18Sound. 12ND930, 8M400 and NSD1095 on XR1064. Runs 2-way active with a custom passive crossover between the 8" and 1".
Posted By: colint
Date Posted: 01 March 2020 at 9:49pm
Nice looking box
------------- Never criticise another man until you've walked a mile in his shoes. Once you have, call him what you like, you're a mile away and you've got his shoes!
Date Posted: 01 March 2020 at 9:51pm
Nice build , nice works..respect..
------------- Musical Roots Reggae Vibration is Life! for music is sound...sound is vibration...vibration is energy... and energy begets life. Therein lies my passion!...MUSIC IS LIFE...
Posted By: JonB67
Date Posted: 01 March 2020 at 10:53pm
really nice Chris.
bet it sounds great.
Posted By: VECTORDJ
Date Posted: 01 March 2020 at 11:21pm
Posted By: ceharden
Date Posted: 02 March 2020 at 1:06am
Luckily I'm able to get wood CNC'd fairly easily. I'm far too lazy nowadays to cut everything from scratch. Still took many hours working on the CAD though.
I haven't gigged them yet but testing so far is promising. The 8" is covering ~400Hz to 2.4kHz and the TiN diaphragm on the 1" is quite nice. The impedance lumps on the 1" around the crossover region caused a few issues with the passive crossover design but managed to make it work without adding lots of extra compensation components. If you're wondering, 2.4kHz was settled on because it's a half wavelength of the 8"/1" driver offset so you can effectively get them in phase at the crossover point. Yes you get issues either side but it works well enough.
It's the first cab I've designed for myself for a long time, have had the drivers lying around for years. Originally I was working on all kinds of complex horn loaded designs but realised for a lot of the jobs I do in small venues, something like this would be far more useful.
Next up is something new to do the bass underneath...
Posted By: odc04r
Date Posted: 02 March 2020 at 10:54am
Nice work there, I still have a load of your old bits in the garage and one day I'll do a similar project. Sometimes trying tomake the best thing you can out of a pile of odd bits is an interesting challenge.
You don't go back once you've got a decent CNC though do you. I was thinking the other day that with the right workflow angled cuts wouldn't be too hard or take too long.
Posted By: MattStolton
Date Posted: 02 March 2020 at 2:31pm
Sometimes, reflex is all you need!
Look tidy. Personally I may have tried a 15/8/1, just to help out lower, but obviously box size goes up, which I presume was not your aim!
Bit of a fan of a mid doing 400-2.5K ish. I have always had a worry about voice fundamentals 200-400, and then rest of voice in a different driver, but seems to hold together in my experiences.
------------- Matt Stolton - Technical Director (!!!) - http://www.wildingsound.co.uk" rel="nofollow - Wilding Sound Ltd "Sparkius metiretur vestra" - "Meter Your Mains"
Posted By: MPASOUND
Date Posted: 04 March 2020 at 10:05am
Very nice looking project! NSD1095n is my favourite 1" driver.
------------- It's just bits of paper flapping about in a box.
Posted By: dlyxover
Date Posted: 05 March 2020 at 7:37pm
tidy looking enclosure
------------- Lignum_ww@icloud.com GNKaudio@icloud.com
Posted By: BP1Fanatic
Date Posted: 10 March 2020 at 6:12pm
Nice work! Can you post some measured graphs?
Posted By: Mark James
Date Posted: 11 March 2022 at 1:39pm
Hey does your cnc guys charge much? I need to get some cabs sorted for someone and im not far away from you Love this new top btw
------------- insert silly sentence here
Posted By: Andylaser
Date Posted: 11 March 2022 at 7:46pm
That look excellent. Nice work.
------------- "music so loud, that if we move in next door to you; your lawn will die" - Lemmy
Posted By: UncleRay
Date Posted: 25 October 2024 at 12:35pm
Hi there, I have been planning to build a 12” 8” 1” speaker for use in my ‘sound room’ and have stumbled upon your build. I have joined the forum specifically to ask about your design. It looks excellent, may I ask if you would have done anything differently if you had the project to do over again?
Did you ever get the chance to do measurements of the speakers?
And what is the lower bass response like? I would be planning to cross over around 120hz but do you think I could achieve 100hz or even 90hz with a similar design (12, 8, 1”) ?
It will be my first attempt at building a speaker and I am just trying to learn the basics at the moment. I am finding the research fascinating and appreciate I have much to learn!
Thanks
Posted By: ceharden
Date Posted: 25 October 2024 at 7:41pm
Hi, I did do some measurements in order to do the crossover design but I don't think I saved them anywhere I could find them quickly sorry!
The bass response is obviously determined by the choice of 12" driver and the cabinet. It has a fairly gentle roll off from probably a bit above 100Hz and I think the tuning is around 60Hz. I normally run them with a crossover around 120Hz depending on what I'm using for the bass. The 12" driver I used has plenty of excursion available so there is some scope to apply some EQ to flatten out the low frequency response and you could cross over lower, especially running at lower volume levels.
I'm very happy with the design, it sounds really good, there's nothing that I can immediately think of that needs changing.
Posted By: UncleRay
Date Posted: 25 October 2024 at 9:19pm
Thank you for the reply, good to know. I can imagine it sounds very nice indeed. I was initially going down the horn route but decided it less than ideal for a smallish space. Do you happen to have any plans or the CAD that you would be happy to share?
It definitely ticks all the boxes I am looking for.
Posted By: ceharden
Date Posted: 26 October 2024 at 12:12am
I can give you as many pointers as I can to help you design something similar but I don't really have any plans I can share sorry.
Have you looked at which drivers you want to use yet? I happened to have some 18Sound drivers I'd bought years previously but there are e.g. B&C alternatives that would work as well.
Where are you located?
Posted By: UncleRay
Date Posted: 26 October 2024 at 10:14am
Ah no problem, thanks anyway. I’m trying to get my head around an app called speaker box lite in order to figure out the ideal box volume and port details. Do you know what your box volume was? I’m finding it tricky to work out with horn and mid fitted.
Would you mind sharing the box dimensions?
Also did you put the 8” driver in a sealed chamber?
I thought it would be nice to cross the 8” mid into the compression driver as high as possible (maybe 4K?), are there any drivers you know of that could do this while still maintaining 90 degree dispersion to match the horn?
I was only thinking this after hearing Tony Andrew’s speak of his dislike for comps in the midrange. Don’t know if this is possible with an 8” though and I may be just being suckered in by his biased opinion!?
Really appreciate your replies, thanks
Posted By: FOO
Date Posted: 26 October 2024 at 11:03am
You have to take whatever Andrews say with a pinch of salt. He is very skilled, no doubt about it. But plenty of very high end manufactures don't agree with it. It all comes down to the ears that are listening.
I don't like the sound of Yamaha speakers. But I like RCF. Others will strongly disagree. It's all about taste
Posted By: ceharden
Date Posted: 26 October 2024 at 12:51pm
The 8" definitely needs it's own sealed enclosure, unless you pick one of the very fancy, very expensive ones that have their own sealed back e.g. https://www.lean-business.co.uk/eshop/18-sound-8nm610-8ohm-400watt-very-high-output-neodymium-mf-p-1559.html" rel="nofollow - https://www.lean-business.co.uk/eshop/18-sound-8nm610-8ohm-400watt-very-high-output-neodymium-mf-p-1559.html
I cross over just over 3kHz from memory, in my opinion that's still high enough to get it out of the critical range. I'm using a 60deg wide horn so trying to match the dispersion of the 8" is less of an issue.
The overall dimension of the box is 800mm tall, baffle is 320mm wide and 355mm deep, including the curve on the front. It's a 15deg trap angle. I think the total volume available to the 12" once you take out the chamber for the 8" and the ports either side is probably around 45litres.
Posted By: UncleRay
Date Posted: 27 October 2024 at 8:06am
Thanks for that info, yes 3kHz sound like a good place to cross over. I often see compression drivers running down to 1kHz or below which seems like a lot of range for them to cover.
What mm ply did you build from?
I was thinking of maybe modifying the port to run horizontal below the 12” driver - purely for aesthetic reasons, but might add too much unnecessary height!
Posted By: snowflake
Date Posted: 27 October 2024 at 1:21pm
using the back chamber of the mid to make the reflex ports is one of the clever things about this design. Not even sure why you think it would look aesthetically better moving the ports to the bottom.
Posted By: UncleRay
Date Posted: 27 October 2024 at 1:29pm
It would just fit my system a little better as the rest of my cabs have single horizontal slot ports, that’s all. You’re right that they are a great part of the design though.
Posted By: ceharden
Date Posted: 27 October 2024 at 7:32pm
They're made from 15mm ply.
The top and bottom of the ports, which also form two sides of the rear chamber, are also rebated into the side panels and provide significant bracing to the cab without needing any extra parts.
Posted By: UncleRay
Date Posted: 15 November 2024 at 12:28pm
So I’m getting closer to getting started on this build, thanks again for all of your help so far.
I have a couple more thoughts and questions before I begin to finalise my plans.
Due to the small room these speakers will be placed in I was wondering whether I may be better off with a wider dispersion horn, in order to avoid dead spots in the room and maximise coverage. The listening zone will be near field and I am concerned there may be a gap in the coverage when stood between the speakers, unless further back where the horns’ output meet as it were.
Obviously a wider dispersion will also result in more reflections however the room is quite well treated so I am slightly less worried about this.
So my question is whether there are any other drawbacks to choosing a 90 degree horn that I may not have considered? Such as getting the directionality of the 8’ to match that of the horn around the crossover point for example. Or just general sonic qualities etc.
I can’t seem to find any directivity plots of the 8’ driver anywhere online so am completely unsure of its specs in this regard. Would it be safe to assume anything based on the driver specs/data of the 8M400?
I have also been simulating using a Fane 12MB for the low mid unit, it seems to give a better low end response for the ~45 litre box volume. However I am not sure whether gaps in my knowledge are making me blind to it’s suitability for this build, are there any reasons that are obvious to you as to why it would not work well for this build?
Apologies for all of my questions, I am aware I have a lot to learn but am getting excited now to begin this build.
Many thanks
Posted By: ceharden
Date Posted: 15 November 2024 at 1:18pm
Do you need coverage over a wide area? If not, just 'toe in' the speakers so that they are angled towards the centre of the room? This will also reduce how much goes onto the walls.
The Fane Colossus 12MB was historically a very good driver, I don't know whether the modern production ones are as good but if it is, I see no reason why it would be a bad choice for the box. You can of course make the box larger if you need more volume to get a better low frequency response. If you leave the ports the same size, that will naturally reduce the tuning frequency.
Posted By: fatfreddiescat
Date Posted: 15 November 2024 at 6:06pm
Listening to a 2 year old pair of 12MB's as I type, very nice, I have 8 in total from 2 batches of 4, approx 2 years apart and they all seem identical.
Posted By: ceharden
Date Posted: 15 November 2024 at 7:58pm
This probably warrants a new post but I'm now working on another new design, this time a 2x10+1.4". Uses the same external panels as the 3-way 12+8+1.
Posted By: JulianDA
Date Posted: 15 November 2024 at 8:40pm
Very nice craftmanship on both of these designs!
Posted By: UncleRay
Date Posted: 15 November 2024 at 8:43pm
Top stuff! Love the look of this, especially the port design, it gives the speaker a very nice symmetry.
How would you say it compares with the 12, 8, 1 design?
Posted By: jeff generik
Date Posted: 15 November 2024 at 9:55pm
Heard a few 2x 10 D’appolito pa tops before, they work very well! Yours looks great!
Posted By: ceharden
Date Posted: 16 November 2024 at 1:17am
Too early to really know how it's going to perform, only got the first one loaded and started testing late afternoon. Pretty sure it'll be capable of going louder than the 1281, but I think the dedicated midrange and 1" compression driver means that one will always be more hi-fi.
It's intended as more of a scalable design, I've used 16Ohm 10" drivers so that I can drive 2 or even 3 boxes off the same amp channels. Initial thoughts are it's got amazing transient response, probably mostly due to the light coned 10" drivers. Vocal presence is great (important because I mostly do live work) and the sound is very clean. There's a massive overlap in terms of frequency range between the 10" and 1.4" drivers so plenty of scope to play with the crossover frequency to see what works best.
Posted By: ceharden
Date Posted: 16 November 2024 at 1:20am
I must admit that I didn't actually do the woodwork on this one. I did all the drawings and asked my CNC guy to assemble them as well.
Date Posted: 16 November 2024 at 3:24pm
The double 10s look great. What size VC does the CD have?
Posted By: Xoc1
Date Posted: 16 November 2024 at 8:52pm
I was interested to know what 10" drivers you used, Modern 10 mids seem to have a bit more x-max which allows a bit more bandwidth on the bottom end.
Posted By: ceharden
Date Posted: 17 November 2024 at 1:09am
The 10" drivers are the new B&C 10MBX64. Not massive power handling but very high efficiency and being light coned, very fast with a great midrange.
The compression driver currently is the 18Sound NSD1424BT as I had a couple left over from a project many years ago, they're a 2.5" diaphragm. They're quite expensive nowadays so I've got a couple of alternatives shortlisted which are slightly more cost effective if I want to have more than one pair of them.
