15NW100 BC Horn
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=105886
Printed Date: 26 March 2026 at 5:53pm
Topic: 15NW100 BC Horn
Posted By: KaphaSound
Subject: 15NW100 BC Horn
Date Posted: 23 November 2020 at 12:56am
Danley's BC sub horn designs seem to have specs that per cabinet/driver/power out-do pretty much anything else out there right now. Originally after seeing the BC218s I was wondering if the same principle could be applied to some 15inch drivers to lose some weight (BC218s clock in at about 500lbs) size and lose some extension but still remain solid down to 30hz. Since then Danley has released the new BC215 which when used in a stack of 4 has a continuous output rated up to 150db and a +/-3db of 33hz; this is madness. I don't have a need for 150db, but I think I've managed to come up with something that should be able to provide 140db continuous at a reasonably smaller size. The complete horn is designed as 4 cabinets stacked together, here's the attempt simmed in 1pi same as all of Danley's BC measured responses (EDIT Danley’s are measured in 2pi**)
Now I don't have great expertise with horn folding so I'd appreciate some critiques here. This was done in Blender and if there's enough demand I'd be glad to show everyone a walkthrough on how it's done, although I have yet to fully figure out how to export the data for CNCing but it does look like there's a way to do it, and for further context on the mouth and orientation of the horn you can see Citizensc's Akabak sims from an earlier discussion on the topic:  http://forum.speakerplans.com/bc-horns-from-standard-flhs_topic105665_page1.html" rel="nofollow - https://forum.speakerplans.com/bc-horns-from-standard-flhs_topic105665_page1.html
So some notes; a -3db of about 30.5hz, this max continuous SPL is driven by 1700 watts (that's just 425 watts a driver). Is there any reason that using a fair bit less than the rated power would be a negative? The 15NW is rated 1000 rms, 2000 peak which leaves us quite a bit of headroom for peaks. Displacement however hits xvar of 11mm at 3400 watts which is only 3db of headroom. My question here is what's the risk of hitting 14-16mm of displacement on peaks for 6db of headroom? I'm assuming xmech is substantially above xvar so distortion on peaks if you're really cranking these could be acceptable atleast for a little while. My intention here though is not really to ever run these at max output; 130-137db is probably plenty for my needs (50-500 people max, dub/dubstep/dnb/funk/hip hop/house and pretty much anything else that might use sub around 30hz). Group delay with filters enabled is a bit sub optimal, however this can be reduced to about 35ms at 32hz with LW filters and for most front loaded horns I haven't really seen anything that confidently beats this. Even the new Paraflex designs seem to have similar group delay. Compression ratio is 2.6. Current box dimensions are 46" by 29.8" by 20.5" (I'm really trying to save as much space as possible). Also similar to the BC215 design I'm planning on placing some corner reflectors on the top so I can cut handles directly into the frame. I'm also really hoping these will come in under 150lbs each, but I know this is probably way too optimistic especially with bracing.
SO any thoughts/questions/critiques here? I'm really looking to pull the trigger on buying parts either this week or next. Been learning and planning for about 8 months or so now and would like to have atleast a few of them built before the end of the year, but this is my first ever speaker build project and the last thing I want to do is rush into things and waste about 2-3 gs. Also as just a final note I’ll be cleaning up the precise folding and am curious about the best way to overlap the borders around the bends? Specifically the 180 degree bend you’ll see the sections are a bit sloppy.
Date Posted: 23 November 2020 at 10:30am
All Danley sub measurements are carried out on a large car park at 10m in 2pi (ground plane) with 28.3V input, then scaled back. It is however designed to be used in pairs, or a single box in a corner for say an install.
Your internals are quite different to the new box, but that’s to be expected. The key thing with these sorts of cabinets is the relationship between the “edge” and the diffraction for the maximum increase in forward energy when stacked.
Hornresp cannot simulate this effect, but there are tools from Tolvan that can. You’ll need to combine it with other data manually however.
For what it’s worth, you want to be aiming for a 9-16dB improvement in forward directivity/output when stacked at the optimal size/box ratio vs a single cabinet. That’s when you know you’re doing something relatively close to a BC loading.
For a lesser effect, albeit still useful, the short lived DBH218LC is maybe worth a look into.
Posted By: snowflake
Date Posted: 23 November 2020 at 3:11pm
interesting post from Danley
https://www.diyaudio.com/forums/subwoofers/263812-danley-bc-subs-reverse-engineered-9.html" rel="nofollow - https://www.diyaudio.com/forums/subwoofers/263812-danley-bc-subs-reverse-engineered-9.html
Date Posted: 23 November 2020 at 5:07pm
Ahh was wondering if Danley uses Akabak! If you see Citizensc’s Akabak models linked in the thread above there are some interesting points made and charts with directivity/low corner extension depending on the size of the mouth. I know Danley here is saying that you can’t get a perfect sim of what you will actually measure, but it has been 6 years of updates to the software since that last post and the response behaved as predicted across both programs; the smaller the mouth opening the lower the extension at the cost of some sensitivity and not shown is also the cost of extra group delay. I believe this is the same principle behind the keystone sub as well? Initially I was uncertain if I was over exaggerating the added length by using half the depth of the cabinet since the mouth is on the usual “side” of a flh but the Akabak sims seem to confirm roughly that this is a correct approach. I suspect this “sideways” mouth orientation with the smaller mouth like the dbh218lc plus the central mouth positioning for the extra directivity gains are the secret sauce to this design.
I believe in the spec sheets you’ll see “measured in 1/2 space” (EDIT 2pi**) with the same voltage and distance you described; my question is and Ivan Beaver sort of briefly explained this to me but why aren’t they simply measured at 1W/1M again? I’m also wondering if they’re saying 1pi simply because of the size of the face of the stack?
Posted By: kipman725
Date Posted: 23 November 2020 at 5:45pm
More expensive but have you considered the 15DS115? it has a bit more xvar.  More recent design as well so has improved BL(x) curve which should mean better linearity within that.
Date Posted: 23 November 2020 at 7:35pm
I haven’t done extensive modeling but it doesn’t seem to sim very well. I haven’t found a way to really flatten it out it’s always very peaky, and a key goal of this project was to keep costs as low as possible so for my needs the 15nw has actually surpassed expectations.
Date Posted: 23 November 2020 at 8:55pm
I believe in the spec sheets you’ll see “measured in 1/2 space” (1pi) with the same voltage and distance you described; my question is and Ivan Beaver sort of briefly explained this to me but why aren’t they simply measured at 1W/1M again? I’m also wondering if they’re saying 1pi simply because of the size of the face of the stack?
half space is 2pi and in this case refers to a ground stacked measurement. It is done at 10m because you need to be far enough away that the speaker mouth is approximately a point source.
Date Posted: 23 November 2020 at 10:06pm
Woops completely overlooked that 1/2 space is indeed 2pi! Even so my real target was actually a low C (32.7hz) and in 2pi this is within the f3 with a continuous output around 137-138db. I’m thinking about taking a shot at Akabak considering that it takes the exact size of the face into account and therefore calculates just how much fractional space loading is taking place, but if this seems like a worthy project please do let me know!
Date Posted: 27 December 2020 at 10:28pm
Just wanted to post some progress on this. I've ordered the driver and all the trimmings and now I just need the wood; pretty set on this design as a prototype but I'd love to hear everyone's thoughts on bracing or anything else I'm missing. I've switched the fold which has given me the target rear volume of 60 liters including driver volume and I've added some more or less arbitrary pieces including right behind the throat since the length didn't quite line up and any longer would cause some significant changes (it's placed right in the middle so the space behind it isn't wasted); any reason why this style wouldn't be advised? I've also added an L-brace and curved brace right at the mouth based on the Danley designs but I'd love to hear if there's any other suggestions! The reflectors are there so I can cut handles in the top corners not for any particular acoustical purpose as I've read that they are relatively unimportant for sub frequencies.
Here's another angle. The idea again is to use these in stacks of 2s or 4s but a single sub can also be placed against a corner:
6ft Monkey totem for scale:
Posted By: citizensc
Date Posted: 29 December 2020 at 12:22pm
Looks cool, the big question I have is how the BC part of the BC horn will work.
Do you have any plans to do a more complex simulation that models the outside of the cabs or prototype the?
Either way id love to see the graph of a conventional stacking arrangement overlayed with the graph of a BC arrangement.
Date Posted: 29 December 2020 at 3:51pm
I should have my B2F horn prototype built in the next few weeks. Planning to do some experiments with that putting a board over the front and cutting progressively bigger holes in the middle of it. Also going to try pointing it at the ground and putting legs on to lift it up a few inches.
Date Posted: 29 December 2020 at 6:43pm
I’d still love to learn Akabak I just can’t seem to find any tutorials on actually building the cab in the sim just on entering the raw data which you can also export from hornresp. I know in one of the threads above as well Danley mentions that he starts with Akabak but that it doesn’t seem to give the full picture which makes me think it could be worth jumping right into the build. Based on your previous Akabak work Citizensc I’m inclined to believe that hornresp lines up fairly well in terms of varying mouth sizes and their effects on response/group delay/displacement etc but I know the secret sauce to this design is in the forward directivity and potential bubble expansion around the face. As far as the sims go without the optimized cutout on the side it’s the same as we saw with the BG horn about a 3hz loss in extension with marginal (1-2db) increases in spl, and a reduction in group delay as well however the BC version is still well within 1.5 cycles. I’ve actually been experimenting with a vst plugin called disperser which adds group delay and I found the threshold of audibility to be much larger than 1.5 cycles; if anything it took over 4 at 35hz to become significantly perceptible but that’s another post.
Very curious about this!
Date Posted: 29 December 2020 at 10:47pm
Looks great, certainly easier movement splitting the horn in 4.
Date Posted: 30 December 2020 at 1:13am
Just to clear things up a little, Danley is talking about legacy AKABAK, I have been using AKABAK 3 which is completely different software. Legacy AKABAK is a very old program, so old that it doesn't run on modern computers but lots of people still use it. AKABAK 3 is for BEM modelling which is far more computationally demanding, simulations can take hours or even days to run on modern computers if they are very complex.
The basics to AKABAK 3 are
1. Getting your geometry in to the software, if you are feeling masochistic you could draw the whole horn in AKABAK 3 by setting coordinates and creating planes from those coordinates. I think the more sane method is to draw it in external software and import the drawing in to akabak. Make sure the drawing is as minimal as possible, I only include geometry that matters acoustically, eg. I don't draw internal cavities in detail.
2. You then have to define a lump element network which basically defines the electromechanical properties of the driver.
3. You then have to set up all the measurement stuff, which is basically like setting up a mic array in the software.
The learning curve to all this is a bit steep but once you get over it you start to realise you can sim pretty much anything you want in the software, including the room the speaker is in. It took me hours to get my first sim working but now I can build one from scratch in about 15 min.
I have been thinking about making a little tutorial series that covers the basics needed to get started, it wouldn't go in depth as I don't feel qualified to do that, I may mislead people.
If I do, it wont be soon, I have been super busy since getting out of lockdown and moving back to my home city, so much so that I haven't had time to prototype my unity horn despite having the components :(
Ps. The HF1440 is HUGE!! I have big oafish hands and it makes them look tiny.
Date Posted: 30 December 2020 at 2:06am
A tutorial sounds awesome already these points were very helpful! A synergy horn would be next on my list of builds but I think that could be some time down the line. I’ll take a look and see if I can’t figure out a bit more and give it a go, but if the local mill gets back and can CNC/mitre everything for me I may just pull the trigger we’ll see!
Date Posted: 30 April 2021 at 9:47pm
Still working on this, looking to get the first cab built this coming month (subject to wood costs and CNC work) and would appreciate any last input! The nature of this project is a bit experimental but again after seeing Citizensc's BG horn modifications and AKABAK 3/hornresp models I suspect the end result shouldn't be too far off. One real question is still how well the horn path will couple with the face and if we can expect to see much improvement in sensitivity, as well as what directivity might look like. Especially curious if we had 8 of these lined up what that would mean for directivity.
I modeled moving the volume of the cone around a bit and not much changed, but I just want to confirm S1 should start half-way across the driver, then the volume shaded in yellow here including the cone volume should be added to vtc?
Here's some possible stacking options, although I think the whole point of this design is to really use the perpendicular mouth for the low-frequency extension. I suppose you could use this as a seriously overpowered kick bin in the conventional orientation?
Here’s the inputs incase anyone sees anything that looks off:
Can’t say enough how much help this community has been. Started learning everything probably just before the start of the pandemic and I'm really hoping to build the first box and see/hear/feel the results. I’m also hoping this design will be able to keep up with the newer paraflex designs...
Posted By: DMorison
Date Posted: 01 May 2021 at 1:38pm
I haven't kept up with the BC and stacking parts of this, but for modelling the throat area Hornresp specifically has the Offset Driver option for this kind of layout - S1 becomes the section at the very end of the horn and S2 that at the entry point of the driver.
This does use up a horn section though, so you may need to condense your current s2-s4 into one section.
This doesn't always make much difference, but I'd try it both ways just to be sure.
Date Posted: 01 May 2021 at 5:17pm
it depends what sort of throat you use - letterbox, v-slot, full Sd cutout etc
Date Posted: 01 May 2021 at 8:03pm
Using full sd cutout, and I originally did model with the offset driver without the perpendicular exit then moved the volume of s1-s2 over to vtc freeing up S5 and that modeled the same.
Condensing S2-S4 to keep offset driver mode with the perpendicular exit of S5 did seem to make a decent difference in the sim but I would imagine that’s to be expected since that would be quite a drastic change in the expansion rate throughout the mid section? This particular horn seems to benefit a lot from a very slow expansion rate to start really until S3 to S4 (the traditional end of the horn).
Date Posted: 30 November 2021 at 11:03pm
Still keen on creating this but would really appreciate one last look through the inputs and design before I go get wood cut. Here's the inputs where VTC encompasses the volume of the driver cone + volume of the cutout + volume of what s1+s2+s3 would be in the OD arrangement:
And here's another look at the design where VTC is highlighted. After reading through previous posts including citizensc's 15BG horn I believe this should be the correct approach in order to free up the additional segments:
The last "gamble" on this design that I'm thinking is really S4 - S5. Currently I have S4 - S5 as half the width of the cab (24.1cm), but I've experimented with slightly more and slightly less and each scenario is pretty close. This is also assuming that the path touches S4 at the bottom left then moves out directly towards you, but I've experimented with a shorter path and smaller S4 area and it would also take quite a difference to see drastic changes. If there's any thoughts here I'm all ears!
Date Posted: 01 December 2021 at 12:56am
Unfortunately Hornresp won't model anything beyond the designated mouth S5, and the use of an axisymmetric condition means that it doesn't really represent the three exits you have. Results for a single horn in of this configuration might be quite far off.
You also don't get to choose the 'stacking arrangement' for the multiple horns option in Hornresp. It doesn't really make a stack, the segment areas are simply multiplied by a factor to produce a single horn of equivalent volume as the individual horn paths of a stack.
The issue is the lack of any simulation of directivity, diffraction and the like. Once you get to 'big horns' the model starts to become much less valid. I'd treat the design as a single box and see how it compares to other horns of similar size and volume if you're limited to Hornresp models. The prediction of throat impedance and therefore magnitude response on-axis is reliable and good, if the source mouth radius is small compared to the wavelength of the intended operation range.
If you did want to play with the new Akabak, you can build an equivalent model to Hornresp (with unlimited elements in series or parallel) in the LEM section, and couple the 'mouth' element to a mesh of the cutout in a model of just the external cabinet for the BEM part.
That way, you can ignore all of the internal stuff for now, and get some results that will inform any further development.
Date Posted: 01 December 2021 at 3:03am
Has Akabak been updated recently or are there any tutorials you’d recommend? I know it’s much more powerful but I haven’t been able to piece together all the steps quite yet. Having said that though you can see citizensc’s previous Akabak work on this same idea here:  https://forum.speakerplans.com/bc-horns-from-standard-flhs_topic105665_page1.html" rel="nofollow - https://forum.speakerplans.com/bc-horns-from-standard-flhs_topic105665_page1.html
As far as orientation it is still a bit of a guess with respect to directivity but the idea would be to always use the smaller exit for the lower extension. You could consider it a corner horn as well since the corner would cover all exits but S5.
Date Posted: 01 December 2021 at 11:50am
Akabak 3 is almost totally different software to the classic Akabak which causes great confusion.  Akabak 3 includes a BEM simulator and an LEM simulator which can be coupled.  Whereas Akabak was only an LEM simulator.  Hornresp is also an LEM simulator but with a more limited interface than Akabak which makes it easier to use but also means some very complex boxes can't be simulated.  The software you want to simulate a BC horn is Akabak 3 as you need BEM simulation to take into account the mouth shape and coupling of box mouths.  The linked thread uses Akabak 3.
There are some video tutorials around for Akabak 3:
https://www.youtube.com/watch?v=I5dvgBgtbos" rel="nofollow - https://www.youtube.com/watch?v=I5dvgBgtbos
(I haven't used this one just came up in search)
I would recommend following some to get an idea of what it does and the interface.
Also the program includes some examples.  I wouldn't say its the easiest thing to learn but its well worth learning.  The only limitation of the free version is that you can't save results so have to re-solve the model every time you open the file and want to look at the results.
Posted By: PTSD
Date Posted: 06 January 2025 at 9:20am
Hey have you actually ever done your prototype of your design? just curious :)
Posted By: Hallowell Hi Fi
Date Posted: 28 January 2025 at 12:09am
Yes! (Apologies for the confusion with name changes... having a real MouseRat moment. FKA Kapha Sound and Salix Sound here.) Been meaning to make a report, thanks for the reminder. Will post an update over on this post shortly: https://forum.speakerplans.com/bc-horns-from-standard-flhs_topic105665_page5.html
