LAMBDA LABS
Forum Name: General Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=106051
Printed Date: 27 March 2026 at 12:22am
Topic: LAMBDA LABS
Subject: LAMBDA LABS
Date Posted: 06 February 2021 at 11:09am
Posted By: JonB67
Date Posted: 06 February 2021 at 2:25pm
Are you selling this product?
Posted By: djeddie
Date Posted: 06 February 2021 at 2:37pm
If so, as adverts go, it's a great start. Got me hooked from the beginning!Big smile
Posted By: Noyzmunky
Date Posted: 06 February 2021 at 3:37pm
Some sort of european version of chinglish on the site..... Not quite esperanto...but...
my name is Inigo Montoya...you killed my father, prepare to die!.
Posted By: APC321
Date Posted: 06 February 2021 at 4:30pm
Nice website. Never knew of an Austrian speaker company before.
The horn loaded mid-top boxes remind me of Meyer MSL-10.
Posted By: Bams
Date Posted: 06 February 2021 at 5:17pm
As far as i can trace they grew out of a shed into a supplier of quite nice systems for the club scene eand from there diversified. Their austrian distributor Pro Performance by wolfgang sauter has a cool philosophy that room treatment is equal to a great sound system, so has a exotic mixture of Alcons and pro performance systems with sh*tloads of baffles and such installed..
Posted By: madboffin
Date Posted: 06 February 2021 at 6:36pm
Yes, I was thinking of somewhere between an MSL-10 and a Res 9.
Good luck to them, it's nice to see a manufacturer in Austria. Reminded me of my time at the Alt Fabrik in the 1990's...
I wonder who the owners are?
Posted By: bass*en*mass
Date Posted: 06 February 2021 at 10:55pm
the qx 12" lowmids are indeed quite oldskool, not much has changed physically since those msl10s have been developed.. they do work, just like they did in any previous "version", within reason.
the MHF of those qx tops does differ a lot to conventional 2"/1" comps arrays though.
basically those are multiple cone loaded mini unity/synergy horns, in an asymetrical, arrayable horn, they do work well imho, overall i was not that impressed with those though (edit, not in that configs/circumstances i have heard them, at least..)
the 215 kicks are very similar to msl5s, again, not much has changed significantly in terms of whats achievable within passband/volume/spl etc. ;)
the dh18s are a "custom" take on a mix of many Danley cabs, its basically a TH, quite similar to the th118 but with a `custom` 4ohm nlw9601 and the adapted mouth options of the dts10/thspud.., tbh. i didnt like them much, tuned too high, nowhere near its `specs`, loads of driver noise too imo
the k18 amps do sound clean, no hiss, no rumble, i am not sure about the 3ph tripple powercon input though, its not ideal imo, also theres not a single usefull measurement of those available since they have been launched about 3 years ago.. i highly doubt the informal 4x4kw RMS! at 4ohm figure..
Posted By: andariel
Date Posted: 10 February 2021 at 11:25am
It is some sort of horizontal line array with a fixed angle with a seamless overlap acting as one source. A synergy horn or the MSLs are totally different (point sources) and have interferences in the overlap area of the individual horns.
Throw can be much larger with such a technology.
Posted By: MarjanM
Date Posted: 10 February 2021 at 12:30pm
No mater which technology you use, the "throw" will be dictated by the SPL capability of the weakest section in the system. In this case it is either the 2x15 section or the 2x12 inch section. So having gazzilion HF drivers is of no particular advantage to me because the rest of the system can not keep up. Maybe in the marketing department it has advantages. 40 HF drivers in on horn, wooow :). I wonder now saturated is the sound coming out of a single 2/3/4 inch throat. Not sure how big is the throat, but that is the thing you can not avoid. It will get saturated very fast with so many drivers.
Posted By: andariel
Date Posted: 10 February 2021 at 1:12pm
Quote
Throw is a matter of technology. It is about how fast you loose SPL over distance and if you keep a linear response at larger hearing distances. It has nothing to do with SPL capability only.
At all large format line arrays the compression drivers cannot be strong enough and the limit when you bump up against air losses. For a single cabinet you might be correct, but this is likely not the intention of how the speakers are to be used.
Posted By: meister_gue
Date Posted: 10 February 2021 at 1:40pm
Quote ...tbh. i didnt like them much, tuned too high, nowhere near its `specs`...
I wonder where you heard them? I heard them at a few different events/locations and always had the impression of them going really low, so I`m wondering a bit.
Above the 12" section they are using 8*1" compression drivers and 32*2" cone drivers. Always sounds very clean and relaxed, no matter the volumen, but maybe I never heard it close to a limit...
Posted By: MarjanM
Date Posted: 10 February 2021 at 2:42pm
Quote
Its a bit different at line arrays.
Date Posted: 10 February 2021 at 6:13pm
folks, its my personal, subjective experiences after all..
i`ve a/b`d the dh18 in person to our old subs, both nlw9601 loaded, both had similar issues and lowend response, which isnt anywhere near the claimed 28hz f3..
(th118 doesnt go low enough either for my liking tbh. ;))
to my ears the qx top just doesnt sound right, its clean, its loud but theres something i dislike about it compared to the j3-94 for example, which do sound more natural/unifom to my ears at similar spl..
qx mhf is a fixed vert. dispersion, `seamless` hor. arrayable unity `linearray` horn - no control on vert. hf throw by design, other than the asymetric WG, hor. theres passive+active "shading" options.
..its pretty easy imo to make "clic clac techno/goa etc." sound well enough, which is what qxs are often used for, with more complex signals things happen to change quickly, imho.
my main gripe with the lambda `marketing` is the constant lack of facts/proof/measurements available - if i`d claim to have a unique/superior product i`d try my best to back those claims up with independant tests.. no usefull data came up since those cabs were launched a couple of years back.. although there was money available to cover the dumping price strategy to undercut the usual festival hire rates just to get the cabs/systems out.. ;)
Date Posted: 11 February 2021 at 5:30pm
Someone in a German forum ( http://www.hifi-forum.de/viewthread-127-3178-3.html" rel="nofollow - http://www.hifi-forum.de/viewthread-127-3178-3.html ) measuered the DH18 in a stack of 4...
... With/without preset but always without highpass:  http://www.directupload.net/file/d/4505/u95shjhv_png.htm" rel="nofollow - http://www.directupload.net/file/d/4505/u95shjhv_png.htm
...Burst decay:  http://www.directupload.net/file/d/4505/u95shjhv_png.htm" rel="nofollow - http://www.directupload.net/file/d/4505/u95shjhv_png.htm
In the post it is described, that the measurements were taken outside 2 meters away of the subs, the next surface was 10-12 meters away. Level is calibrated to give 1W on the stack of four (-6dB for a single sub).
And it does play more than electronic music ;)
->  https://www.youtube.com/watch?v=JV8i7dJsfBU&t=70s" rel="nofollow - https://www.youtube.com/watch?v=JV8i7dJsfBU&t=70s
And no, I don`t work for them or earn any money with LL products. I just heard some of their things and found them very impressive compared to pretty much anything else...
Posted By: Racks&Stacks
Date Posted: 12 February 2021 at 9:29pm
2m is too close to properly measure subs
Date Posted: 13 February 2021 at 6:52pm
exactly..!
(that close, specially with larger stacks you would measure partial nearfield rather than true 1/2 space farfield, which adds a boost/gain according to the stacksize/half WL it supports, afaik, for easy comparison the 10m, fixed voltage setup seems a better way)
"1w 1m" - at what impedance of the not available plot?
no highpass? - that "measurement" is clearly with a hpf and lpf in place.. + propably 1/6 smoothed too
Posted By: Jo bg
Date Posted: 14 February 2021 at 9:50am
Yes actually the German text on the graphs says "without low pass".
Posted By: Jo bg
Date Posted: 14 February 2021 at 10:00am
Also states that the sub is in S mode, that from specs trades 2 dB on sensitivty for 2hz Lower extension...
Posted By: andariel
Date Posted: 19 February 2021 at 7:02pm
I don`t see this 2db exactly, but the frequency responses look very solid and clean with a nice 30Hz -3db corner frequency.
When you move your mic further you usually get more SPL than in the nearfield, because of directivity... Maybe there is more difference when measured in 10m.
The spectral decay look fine too.
Posted By: Keen
Date Posted: 18 February 2026 at 1:41pm
And now with this HOQS paraflex rubbish doing the same.
Posted By: teeth
Date Posted: 18 February 2026 at 1:57pm
i believe the lack of specs / pricing / info is down to their distro model (and marketing) - they seem to really want each deployment to be done properly by their approved partners. i can respect this.
this is sort of what funktion one have lost over the years, their pool of distributors has become dilated with poor quality. Void seem quite good at this.
my girlfriend has played on two Lambda rigs over the years and she has nothing but amazing things to say.
i personally own a pair of CX2A coax wedges, and they are fantastic, easily the best monitors of that style i have heard. i got given them which was quite nice :)
Posted By: MarjanM
Date Posted: 18 February 2026 at 2:12pm
Which rental companies in Europe has the LL system?
My impression is that all the festivals that i have seen the LL system are the one supplied by LL them self. I ma not aware of anyone that actually invested in LL system.
I might be wrong.
Posted By: Keen
Date Posted: 18 February 2026 at 2:44pm
Bottom of page 2 says something, no names though.
https://irp.cdn-website.com/5bb0c925/files/uploaded/Lambda+Labs+QX-3+-+Deep+Technical+Research+Summary.pdf" rel="nofollow - https://irp.cdn-website.com/5bb0c925/files/uploaded/Lambda+Labs+QX-3+-+Deep+Technical+Research+Summary.pdf
Posted By: teeth
Date Posted: 18 February 2026 at 3:17pm
it looks like these guys do
https://www.properformance.audio/brands" rel="nofollow - https://www.properformance.audio/brands
looks like they did Elysia in Basel
Posted By: Sypa
Date Posted: 18 February 2026 at 3:27pm
Heard it last summer , but it wasn't pushed far enough for my liking at any moment which was disappointing but sure enough sounded really good .
Also walking just a bit off stage felt bizarre , some directivity witchcraft being done expertly.
