BK Electronics MXF400 Bridgeable?
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=106495
Printed Date: 27 March 2026 at 8:18am
Topic: BK Electronics MXF400 Bridgeable?
Posted By: Ziptie Hifi
Subject: BK Electronics MXF400 Bridgeable?
Date Posted: 24 August 2021 at 10:44am
Hey folks,
I've just acquired 3 (Timewarped) MXF400's from a cinema. I'd like to use two in 'bridge mode' for my Martin Audio ICT500's.
From what I've read these amps love a bit of abuse but would they cook without fans etc.
I'm happy with the icts not being ran out at 700w as we're
 generally doing smaller gigs. Also they're only being ran as mid/tops not full range.
Cheers in advance
G
Posted By: kedwardsleisure
Date Posted: 24 August 2021 at 1:37pm
I think you'd have to knock up a little bridging preamp to run them as I think these amps have an unbalanced, ground-referenced line input, though that's just from memory. Happy to be corrected
North Staffordshire
Posted By: djeddie
Date Posted: 24 August 2021 at 2:11pm
As said above... if you're good with a soldering iron, http://sound-au.com/project14.htm" rel="nofollow - try this
Posted By: service dept Steve
Date Posted: 25 August 2021 at 2:38pm
Before bridging these I would check what output devices they have, There were several versions but if they have the H.pack mosfets, j82 and k226 you will not be able to replace these if you damage the module.
We are not "They", We are "The others" http://www.servicedept.co.uk" rel="nofollow - http://www.servicedept.co.uk -
