db mark bits
Forum Name: General Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=106707
Printed Date: 27 March 2026 at 5:30am
Topic: db mark bits
Posted By: teeth
Subject: db mark bits
Date Posted: 14 December 2021 at 10:30am
is someone able to give a run down of the different db mark models?
i think it's time to upgrade my ultradrive, but not sure which to get.
other than the inputs / outputs, i'm not sure what the difference between the XCA and DP series, though i'm sure either will be a decent upgrade on the berry!
Posted By: richardwatts87
Date Posted: 14 December 2021 at 12:16pm
I recently upgraded from an ultra drive to a 2 in 6 out xca. Not used it a shed load yet, but first impressions are:
- Better sound quality
- Intuitive and easy to use program on PC, I also found it alot easier to connect to.
- Display on unit isn't quite as easy to navigate and use as the ultra drive. Easy enough mind, and I mostly use my pc anyway
- I like the mute buttons assigned to each channel.
Thumbs up over all....
Posted By: shaun1264
Date Posted: 14 December 2021 at 1:12pm
XCAs seems to be well built, decent sound quality with some good A/D D/A chips and opamps.  It has a traditional linear power supply .
Posted By: paulus
Date Posted: 14 December 2021 at 2:01pm
not a hi jack but i have one for sale 4 in 8 dp48 out of an install no box but mint , never been on road 250 plus post if anyone interested, pm me 440 new
TRENDSETTER SOUND SYSTEM
Posted By: tomrotten
Date Posted: 16 December 2021 at 7:15am
PM'd
rotten noise soundsystem
1850s - A.S.S - FFA
Posted By: teeth
Date Posted: 16 December 2021 at 1:24pm
ah will take that please!
Date Posted: 26 December 2021 at 9:07am
Not long after posting on this subject my DB Mark XCA has started playing up. One channel seems slightly lower in volume than the other. I've narrowed it down to the input section . Swapping back to a JBL DSC260 both inputs are dead on equal. So definitely the XCA.
Posted By: teeth
Date Posted: 27 December 2021 at 12:18pm
you reckon that's a settings thing or there's an actual problem with the unit?
Date Posted: 27 December 2021 at 3:06pm
The easiest way to test that is to perform a factory reset or firmware flash on the device.
You can also verify the output difference by simply connecting a volt meter to the output channels.
Date Posted: 01 January 2022 at 8:14am
Update on this.  I fixed it.  The issue was a dry joint, high resistance joint to the input op-amp.  Everything else was fine on the board.  Not sure why it happened.
These active crossovers are built well, solid construction and decent chips. It's unusual that it has a linear power supply (transformer, full bridge rectifier and voltage regulators)  The only slight concern would be the cheap capacitors but that is the same to alot of modern products these days.
Posted By: teeth
Date Posted: 17 January 2022 at 9:01pm
well, i got a DP28+
my initial thoughts: i
interface isn't as bad as i remembered
behringer is still better (mainly due to the screen)
dear god that screen is BRIGHT (can it be turned down?)
decent features
i like the AGC on inputs, i was going to get a AVC (formula sound) but will so how i go with this
yet to comment on sound as i have yet to make some sound with it
no spaces or special characters when saving presets. weird
no manual, can't find one online anywhere.
it's pretty self explanatory, but i love reading manuals... anyone seen one?
Posted By: angus
Date Posted: 25 June 2022 at 8:55pm
I know it's a bit late but I found this if you're still interested  https://dbmark.co.uk/content/downloads/DP+manual.pdf" rel="nofollow - https://dbmark.co.uk/content/downloads/DP+manual.pdf
(I was searching for advice and info on alternatives or options relating to the classic AVC limiter and this thread popped up in search.)
They're complaining over there, but it's their fault!
Posted By: MarjanM
Date Posted: 26 June 2022 at 12:53am
After using a bunch od DB mark and other chinese DSPs over the last decade or so, i still belive that it is not an upgrade to the DCX. Untill your have 1K+ for a DSP, nothing touch the DCX.
Argue waht ever you want but i stay on my opinion. :)
Posted By: vertx
Date Posted: 30 June 2022 at 2:57am
I gotta say though, the new XCA+ add more features than the last revision. Playing around with a fresh XCA24+ at the moment. They've added Dynamic EQ, and the software is better, plus now they are IP based and can apparently link a bunch up on a LAN, so no need to use the dial on the front. Chassis build is way stronger/better than the DCX. Would like more than 6 EQ points on each output though for fine detailing that would be nice but I guess I'm used to Hypex where they give 15 per output.
I've had a DCX since maybe 2014 with 0 issues.
My XCA28 since maybe 2016 and no issues except for an orange comp light that gets stuck on once it triggers on output 5 every so often. Think it's just the light tho, no actual limiting occurring.
Posted By: vertx
Date Posted: 30 June 2022 at 2:59am
Plus you can now edit what shows on the front page of the XCA so you can write "leave this processor the f*^k alone" if you wanted LOL
Posted By: snowflake
Date Posted: 30 June 2022 at 12:09pm
does the password protection disable the front panel or does it just lock you out the control software?
Posted By: angus
Date Posted: 30 June 2022 at 1:55pm
Looks like you can lock all the hardware functionality on the device with a password or just some of it:
edited for image issues
Posted By: angus
Date Posted: 30 June 2022 at 2:03pm
[duplicate post]
Posted By: angus
They do seem like good units and I did like my DCX a lot when i had it but sadly I had to sell it a while back. I've since picked up a BSS Soundweb 9088iis for a good price, which is working ok for me at the moment with the control software, but I'm not so sure about its relative sound quality - it might be a bit noisy as far as I can tell in my initial tests but I'm not sure if it's the rest of my system of the device itself. Have you used these Soundwebs much before MarjanM?
Posted By: SamV
Date Posted: 23 September 2022 at 10:28pm
I have both the DCX and XCA28 in active use. I've done A/B testing side by side and I swear the dbmark sounds better.
Posted By: teeth
Date Posted: 26 September 2022 at 10:28am
post from andy detailing the two models...
https://blog.bluearan.co.uk/db-mark-dp-vs-xca/" rel="nofollow - https://blog.bluearan.co.uk/db-mark-dp-vs-xca/
Posted By: Sypa
Date Posted: 26 September 2022 at 6:44pm
Im using the xca28+ in a studio setting used a dcx before.
First thing that was obvious was much much less noise making the sound more transparent and clear in the start. Now the nuances i dont know but the dcx was definately not made with studios in mind.
But the xca has a small fan which has a horrid buzz , I got used to it tho.
Wonder if it could handle the heat without it Smile
Posted By: teeth
Date Posted: 03 November 2022 at 9:02am
is it possible to link two units together for more outputs as you can do with xilicia stuff?
Posted By: cravings
Date Posted: 03 November 2022 at 9:06am
I didn't know you could do that with xilica..
Posted By: Andy Kos
Date Posted: 25 September 2024 at 6:02pm
Managed to get some more detailed tech specs from the factory, and did some investigation of our own.
Little summary here:
Feature wise, the new plus series of DP and XCA is exactly the same, same limiters, compressors, EQ, noise gates, filter, all pass filters and dynamic EQ. Programs are transferable between DP and XCA, as all features are the same,
Key differences:
1. DP series uses 'impedance balancing' on outputs - which isnt a true balanced output - used by Behringer and virtually every other budget audio product this is a kind of pseudo-balancing. XCA uses true active balanced outputs, which offer enhanced noise rejection on longer cables.
2. XCA series has better quality ADC and DAC chips for higher dynamic range, higher SNR, and lower distortion.
The new HDX series has even better ADC and DAC chips, and also better op-amps and improved output circuitry.
Posted By: Andy Kos
Date Posted: 25 September 2024 at 6:04pm
The Fan can be disconnected, the fan was added in the XCA series as they had a few customers in Middle East (where it can regularly be 40 degrees plus) with the occasional overheating issue.
In the UK, ambient air temperature is much lower, so you can just unplug the fan
Posted By: SamV
Date Posted: 01 October 2024 at 9:14pm
Any other new differences with the HDX?
Posted By: Sypa
Date Posted: 03 October 2024 at 10:58am
Anyone know where can I buy the hdx series in Europe ?
Posted By: Andy Kos
Date Posted: 03 October 2024 at 8:55pm
We can ship from the UK. A couple of places will be taking stock in Germany and Romania in next few weeks.
Posted By: Andy Kos
Date Posted: 03 October 2024 at 8:58pm
No, its just an audio quality upgrade with a view to competing with the high end DSPs out there. Yes I know they need FIR filters... maybe in the future...
Posted By: Sypa
Date Posted: 04 October 2024 at 11:03am
I know Andy , bought from BA before Brexit . Don't wanna pay double tax ofc and Croatian customs are an unorganized hellhole.
Posted By: cravings
Date Posted: 04 October 2024 at 1:36pm
Andy has been exemplary in his handling of brexit from my perspective as an overseas buyer. No Messing with customs or anything here like nearly every other UK seller I've tried with.
Great job Andy.
(Edit to correct spelling of brexit)
Posted By: Andy Kos
Date Posted: 04 October 2024 at 8:44pm
So if you're a private individual, we can ship with taxes/duties prepaid. Our courier will make the customs clearance (usually in France/Calais or Netherlands/Rotterdam) and charge the VAT back to us. The goods then continue to final destination unhindered as they are inside the EU.
It gets trickier if you're a VAT registered business - we wont charge any UK VAT, but what happens on entry to your country is a minefield. France is OK, but in the past we have found some countries (e.g. Greece) to be hassle, with the customs apparently controlled by the local mafia and holding your goods to ransom for extortionate fees.
Posted By: Andy Kos
Date Posted: 04 October 2024 at 8:46pm
double post - sorry
