Suggested Amps for 4 x Oberton 18XB1600
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=106992
Printed Date: 23 April 2024 at 9:37pm Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Suggested Amps for 4 x Oberton 18XB1600
Posted By: Tj23
Subject: Suggested Amps for 4 x Oberton 18XB1600
Date Posted: 05 April 2022 at 1:56pm
I'm looking for suggestions for amps to power 4 x 18Xb1600 in my SBH.
I'm pretty new to the whole Soundsystem thing but am I right in saying as these cabs will be wired in parallel the speakers will essentially have 4ohms of resistance meaning I could run 2 horns/channel of a Crown Xti 6002(this is the height of my budget)
Is there any other amps I should considering? I'd like to keep it easy to source, and im reluctant to buy second hand.
Thanks
Posted By: levyte357-
Date Posted: 05 April 2022 at 2:01pm
Would forget all about Crown XTI's, if I were you.
------------- Global Depopulation - Alive and Killing.
Posted By: Tj23
Date Posted: 05 April 2022 at 2:03pm
Why? What do you suggest in its place?
Date Posted: 05 April 2022 at 2:11pm
Thanks
Quality, proven 2nd hand, is always better than cheap new crap.
Date Posted: 05 April 2022 at 2:12pm
See PM
Posted By: Tj23
Date Posted: 05 April 2022 at 2:13pm
Granted I won't disagree with that at all, but sourcing stuff becomes a bit silly.
Posted By: Elliot Thompson
Date Posted: 05 April 2022 at 2:27pm
The Crown Xti 6000/6002 is the only model in the Xti Series that is a re-badge I-Tech. Many were using the Xti 6000 as a more budget constraint option instead of the I-Tech 6000 in the late 2010's. The Xti 6002 is an Xti 6000 with an on-board dsp.
Best Regards,
------------- Elliot Thompson
Date Posted: 05 April 2022 at 2:49pm
Not even an ITECH-8000, would properly power 4x Oberton 18XB1600s.
I've seen ITECH-8000 attempting to power, 2x "8 ohm" 800w drivers, per channel, and self limiting, almost thermalling, even on rigid 32A supply.
Some of the output specs, of "some" branded lightweights, are absolute..
Date Posted: 05 April 2022 at 3:07pm
I am talking about Xti 6000 not the first Generation of the I-Tech in which, the I-tech 8000 falls under. Crown made many modifications from the first Generation of the I-Tech which, is why they discontinued the whole first generation of I-Techs and introduced the I-Tech HD Series. This is when Crown introduced Macro-tech I, and the Xti 6000. They do not cut back every few seconds like the First Generation of I-Techs.
Best Regards,
Date Posted: 05 April 2022 at 3:16pm
Best Regards, |
Thanks Elliot.
What is your opinion of the ITECH 12000 HD?
Heard good things about the sound and power, but they are now almost impossible to repair, hence very scarce !?
Posted By: Lucasdude
Date Posted: 05 April 2022 at 3:29pm
Best Regards, |
I feel like breaking stuff when I hear the compressor on Radio 6 messin with Miles, I would quickly become very enraged if my amps started softening my sub bass.
Date Posted: 05 April 2022 at 3:36pm
Best Regards, |
Thanks Elliot.
They discontinued Macro-Tech 1200i by Crown. Its the same power as the Itech 12000 HD. The voltage rails are around +/- 205 volts so, they still fall short in terms of output power compared to the discontinued Powersoft K 20 and, the current Admark/Morin/WASI amplifiers that all offer around +/- 220-230 volt rails.
Best Regards,
Date Posted: 05 April 2022 at 3:45pm
Best Regards, |
Pretty much all limiters embedded in the amplifier's circuitry will start to soften the bass once the amplifier approaches its limit. That high degree of amplifier distortion (which is favored by some), which would only get louder, once you push the amplifier harder into clipping is not present anymore with modern-day amplifiers.
Best Regards,
Date Posted: 05 April 2022 at 3:46pm
Best Regards, |
Thanks Elliot.
It's discontinued by Crown. The voltage rails are around +/- 205 volts so, they still fall short in terms of output power compared to the discontinued Powersoft K 20 and, the current Admark/Morin/WASI amplifiers that all offer around +/- 220-230 volt rails.
Best Regards,
Think many don't really know the potential of K20, when on proper mains.
This
is video taken, from my gig in 2013, with Powersoft K20 on proper 32A
supply, powering 4x of my design Scoops, with "then" PD1852 prototypes.
3 Phase distro with meters, records the excitement..
https://www.youtube.com/watch?v=MuwACcXKBTA" rel="nofollow - https://www.youtube.com/watch?v=MuwACcXKBTA
Date Posted: 05 April 2022 at 3:54pm
Best Regards, |
Best Regards, |
I feel ya, E.T. Just like driving aids on modern cars, these "effects" are angelic to some but the devil to others. I would prefer my electronics to allow my ears to be The Judge.
Date Posted: 05 April 2022 at 4:07pm
This
Feeding the amplifiers proper power has always been something many never pay attention to.
Best Regards,
Date Posted: 05 April 2022 at 4:13pm
Best Regards, |
Best Regards, |
When the clip lights are not solving the problem and, the customer does not know how to use his/her own judgement on when to back-off, the manufactures have to resort to on-board limiters.
Best Regards,
Posted By: Tj23
Date Posted: 05 April 2022 at 6:15pm
levyte357- wrote:
See PM
I'm unable to view any PM's I don't have an inbox for some reason?
Date Posted: 05 April 2022 at 6:18pm
Tj23 wrote:
levyte357- wrote:
See PM
You don't have enough posts yet.
QSC PL380, could power 4 ohm driver per channel no Problem.
I have 2x of these for sale.
Posted By: Esc4pe
Date Posted: 05 April 2022 at 9:20pm
Thanks
Is weight an issue my man?? When on lower budget multiples of the heavier stuff always prevails! The issue you have is with your drivers needing so much juice it pushes you towards needing the big dogs like powersoft to use multiple of them on one amp!
I don’t see 2 prolines, 1 bridged to each 2 drivers, not being up to the task! Just use a good limiter or don’t thrash and have an eagle eye!
2 4050/5050s too!
Posted By: Esc4pe
Date Posted: 05 April 2022 at 9:21pm
Thanks
2 4050/5050s too! |
Or as others have said and many hate to admit, people have had good experiences with CVR, Admark and Morin
Posted By: Tj23
Date Posted: 06 April 2022 at 1:02pm
Weight isn't a problem for me, majority of the time rig will be used at one venue not far from my storage. However I think I've been sold on the QSC PL380 it does everything I need and can be bought brand new.
